Valve Shim Size : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 01-04-2010, 03:46 PM   #1
alpo
alpo's Avatar
Motorcycle: K6 600
Valve Shim Size
I have a K6 600 and an extra K6 750 engine. I want to check the valves before this coming season.
After looking around it appears that the 600 takes 7.48mm shims - is this correct?
I haven't been able to find any size information on the 750 shims. Does anyone know what it takes?
TIA!
alpo is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 04:55 PM   #2
Chugs
Lets go racing!
Chugs's Avatar
Re: Valve Shim Size
Search "service manual" download it for the 750 and check to see what it is.
Chugs is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 05:02 PM   #3
alpo
alpo's Avatar
Motorcycle: K6 600
Re: Valve Shim Size
I have both service manuals, thank you. They both reference "TAPPET SHIM SET (12800-05830)", but don't specify the size of the shims.
Old 01-04-2010, 05:33 PM   #4
1qwik6
Superbike Champ
1qwik6's Avatar
Motorcycle: 07 600 track bitch
Re: Valve Shim Size
Refer to the tappet shim selection table (2-10 and -11) for details.
1qwik6 is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 05:37 PM   #5
Chugs
Lets go racing!
Chugs's Avatar
Re: Valve Shim Size
^^+1 what he said.
Old 01-04-2010, 05:41 PM   #6
SVS
Bearded Viking Admin...
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '99 SV650S, '84 XL600R
Re: Valve Shim Size
Yes, those would be the ones. All the Suzuki bucket-over-shim engines take the same diameter shims as far as I know. But you need to open it to find out which thicknesses you need anyway Or are you looking to buy a complete shim kit? Just get a Suzuki one
SVS is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 06:03 PM   #7
alpo
alpo's Avatar
Motorcycle: K6 600
Re: Valve Shim Size
I guess I wasn't asking the question correctly. The tables show the shim thickness; I want to know their diameter.
Thank you. Just to make sure, those are 7.48mm (7.5mm) diameter shims?
I'll get a kit (probably not the Suzuki kit - mucho expensive) because I have a Yamaha that also uses 7.48mm shims. I've seen Hot Cams kits on eBay for $64 that should suit me fine.
Old 01-04-2010, 06:32 PM   #8
Dave H
Re: Valve Shim Size
Found this (http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT).
This is in the ad: "Includes three 7.48 MM o.d. shims in each size from 1.20 mm to 3.50 mm in .05mm increments".
Where'd you find it for $64 ?
Dave H is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 06:36 PM   #9
Dave H
Re: Valve Shim Size
Nevermind. Found it here (http://cgi.ebay.com/ebaymotors/HOTCA...item4a9d6ca646)
Real Name
What is your real name?
Search this Thread:
Advanced Search
