NEAS on 87-88 1100 forks help : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-16-2009, 03:24 PM   #1
nervoptik
nervoptik's Avatar
Motorcycle: gsx-r 1100 88/J
Hi there,
Is there any way to test that the NEAS units are working properly ?
I've searched google long time before asking this, and there are not so much about it.
I know that when I break the front with ignition on, some relay makes a click, but that's all ... looks no difference to me when I'm pushing the fork down with power on or off. I've checked the wires between NEAS units and relay ... seams to be ok.
Is there a way to check their functionality ?
Thanks .
gsx-r 1100 GU74B
intake air volume = intake gas volume ... or so
nervoptik is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 04:51 PM   #2
shmokica
Save water, ride an oiler
shmokica's Avatar
Motorcycle: Gixxers
Re: NEAS on 87-88 1100 forks help
Mine feels different when pushing the front end down and up.
shmokica is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 05:23 PM   #3
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
neas working when you drive
and when you BRAKE with FRONT brake...........
otherwise you cannot feal really difference.......
ghostrider.1127 is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 05:34 PM   #4
nervoptik
nervoptik's Avatar
Yeah .. thanks, that's what i've wrote ... but the question is if there is a way to test them (electronically or any other way then pushing the fork)
Thanks.
Old 12-16-2009, 05:46 PM   #5
ghostrider.1127
disconnect the neas lead wire couplers,right and left,from neas units
check the solenodicoil for "open","ground" and ohmic resistence.
the solenoidis in good conditions if the resistance is as follow 5.4-8 OHM
from dealer manual
(maybe you can find one )
Old 12-16-2009, 10:06 PM   #6
GertRam
GertRam's Avatar
Motorcycle: GSXR 750 '87, GS 1000 '78, Triumph SuperIII '96, KTM GS 500 '87
I guess you could test it with a tie-wrap around the inner fork tube. Slide it against the bottom tube, ride 60 and use the front brake. Measure the distance between the tie-wrap and the top of the bottom leg. Then do the same thing with the neas wiring disconnected. Compare measurements. Might be advisible to place something between the brake lever and the handlebar, so you know you pull the lever the same distance.
GertRam is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 10:16 PM   #7
posplayr
posplayr's Avatar
Motorcycle: GS1100ED,GSXR1100G
from dealer manual
I had two sets, so I put 12V across each one (all 4)and each one buzzed. That is about all I can say to confirm the electrical is working. The resistance test would do about the same but wanted to hear something mechanical when activated.
FYI they were not mounted.
posplayr is offline   Reply With Quote Quick reply to this message
Old 12-17-2009, 02:18 AM   #8
rogerlee
rogerlee's Avatar
I often wondered if mine worked too. After unplugging them and riding the bike, the bike dives hard when braking. Plugged them back in
rogerlee is offline   Reply With Quote Quick reply to this message
Old 12-17-2009, 03:05 AM   #9
nervoptik
nervoptik's Avatar
I tried to to the same, but not to put 12v on them, just break and listen for any noise on them ... nothing ...
I'll try to do like ghostrider.1127 says, check if the resistance is between 5.4-8 OHM, also I'll try to do as GertRam, to measure the distance ... I was doing the same, but I just appreciate the distance and the stiffness ... and looked the same.
I also have to say that one tube is leaking ... so measurement may be not accurate.
Thanks guys! I'll keep you posted about this in a couple of days.
gsx-r 1100 GU74B
Old 12-17-2009, 03:10 AM   #10
Ragnar
Old Skool Moderator
Ragnar's Avatar
Motorcycle: 88/1100, 1 pile of parts for a "Big Papa".
Surprised to hear that, a lot of people disconnect and leave them.
Ragnar is offline   Reply With Quote Quick reply to this message
Old 12-17-2009, 05:10 PM   #11
posplayr
posplayr's Avatar
Disconnected in your hand it is a light buzz. If it were mounted the forks/tire might absorb so much of the vibration till you dont hear anything unless you put your tooth to it.
Old 06-14-2010, 05:32 PM   #12
jaskat05
Motorcycle: 1986 GSXR 750
My 86 750 is missing the relay for the NEAS Unit. Anyone tell me what kind of relay I need to get. Front end dives hard when braking.
jaskat05 is offline   Reply With Quote Quick reply to this message
Old 06-14-2010, 05:55 PM   #13
ghostrider.1127
86 750 came without neas
maybe you have a limited ???
(sure isn t a 87 ???)
Old 06-14-2010, 05:58 PM   #14
87gix750
Motorcycle: '87 gsxr750, '90 CR500, '86 IT200, 2 '74 DT175's, '75 DT175, '91 RM125, '88 GSXR1100 streetfighter project, another '87 GSXR750 streetfighter project, '86 GSXR750 Dragbike
I thought the 750 was the inertia activated ones and not electronic.
At least all the 750's I have seen are that way
87gix750 is offline   Reply With Quote Quick reply to this message
Old 06-14-2010, 06:26 PM   #15
ghostrider.1127
87 in europe came with 41 mm fork and neas......
Old 06-14-2010, 07:00 PM   #16
Joselsgil
Joselsgil's Avatar
Motorcycle: '86 GSX-R 750 resto project
I am switching my front forks and brakes from an '87 1100. What relay would I need and is there a plug in the stock '86 750 wiring harness to plug it into? Or is there a power source that I can splice into?
Since the '86 750 LTD had the NEAS units stock, did the LTD model have a different wiring harness compared to the standard '86 750?
I know some of you GSXR gurus have the answers.
Joselsgil is offline   Reply With Quote Quick reply to this message
Old 06-14-2010, 07:12 PM   #17
ghostrider.1127
you need rele , diode and few cm of cable......
Old 06-14-2010, 07:19 PM   #18
87gix750
you have to modify the stock wiring to make it work
Old 06-14-2010, 08:00 PM   #19
posplayr
posplayr's Avatar
I was looking at that schematic and it seemed very strange. It finally occured to me what the diode was for.
Normally the brake lights are activated by wire "OR"ing the F and R brake light switches together on the low side (i.e. either gets grounded the brake lights go on)
With the NEAS, you want to power the NEAS when only the F brake is on so the diode is required to block the rear brakes from activating the NEAS. (note the relay is switching the NEAS low side)
I added a schematic
Old 06-14-2010, 08:07 PM   #20
ghostrider.1127
yes ,
also for this use i think is possible use a suzuki s slinghy diode (sidestand/neutral light)
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
