Oil leak at water pump fix : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-10-2009, 09:16 PM   #1
SuperMotoRuss
Motorcycle: 05 Husqvarna 510smr, 07 GSXR 750
Hey everyone,
I think I finally got a handle on this type of leak. It seems that the O ring that Suzuki uses on the water pump snout is of dubious quality. I miked the pump and the machined opening in the case it fits into and it appears ok. O ring seems too small in diameter to fill the gap consistently so here's what I did...
1. Remove left side fairing assy.
2. Drain the oil.
3. Remove the two bolts holding the water pump into the case. Do not drain the coolant or remove the two hoses on the water pump. There is enough slop in the coolant hoses to pull the pump straight out if you use two small prybars or screwdrivers to evenly lever the pump straight out.
4. Remove the old O ring and carefully clean the hole in the case and the pump snout, be careful not to wipe any chain crud into the engine. I used brake clean sprayed onto a shop rag as it disolves quicker.
5. Install a new O ring (I used an OEM from bikebandit) and then apply two 1/16 inch beads of Permatex UltraCopper RTV behind the Oring towards the pump side about 1/8 inch apart. Let it "skin" for a minute or two and then be sure the slot in the pump drive aligns with the drive in the engine and carefully and as straight as possible, reinstall the pump.
Apply a little oil to the threads of the two pump bolts and reinstall them and torque to 8-10 inch lbs.
6. Refill with oil and reinstall left side fairing assy. Let moto sit for 12-24 hours for RTV to cure and then fire it up and let it get to 200 degrees or so. Shut it off and retorque the water pump bolts.
So far so good after this, I have not had any leaking at all from the pump since I did this. Be sure to use UTRACOPPER RTV! Regular RTV does not seem to have the same sealing qualities.
Hope this helps, any questions let me know
SuperMotoRuss is offline   Reply With Quote
Old 10-31-2009, 06:49 PM   #2
bumblebeegsxr
Re: Oil leak at water pump fix
Thank you for this post. Its EXACTLY what I was looking for! I had it start leaking last weekend just out of nowhere while on a ride. Oil EVERYWHERE! Found where it was leaking, thought it was just the o-ring. Replaced it and it continued to leak! WTF!
So is this a common problem on these things?
And WHAT CAUSES this????
bumblebeegsxr is offline   Reply With Quote
Old 11-01-2009, 04:45 PM   #3
drhawkinz
drhawkinz's Avatar
Motorcycle: k6 600 Black/Silver
nice post. I just noticed last week that mine had a small leak so I'll definitely be using this info to help fix it. thanks
drhawkinz is offline   Reply With Quote
Old 11-02-2009, 07:51 AM   #4
bumblebeegsxr
Well after a few phone calls and all, TURNS OUT I was given the wrong part number O-Ring. Even though, asking if they were 100% ON THIS BEING THE CORRECT ONE BEFORE i WALKED OUT THE SHOP!
OH well stuff happens. Lil disapppointing but Im sure it was unintentional, so Ill have to see what happens with the real and correct part/application!
Old 02-25-2010, 09:29 PM   #5
nickgphx
my bike has the same issue, leaks alot, started suddenly from behing water pump, replaced the seal with a factory seal 3 times and didnt work, did using the utracopper rtv work?
nickgphx is offline   Reply With Quote
Old 02-25-2010, 11:04 PM   #6
brocklanders
brocklanders's Avatar
Motorcycle: 07GSXR750
why not put a fatter o ring on.
brocklanders is offline   Reply With Quote
Old 02-26-2010, 07:31 PM   #7
SuperMotoRuss
If you have replaced the O-ring and sealed it with Ultra Copper RTV the way I described and it still leaks you have a bad seal in the water pump. When the seals go bad you will get antifreeze or oil or a combination of both dripping from the lowest bolt on the pump. I don't recommend pulling the pump, disassembling it and replacing the seals as there are too many things to go wrong and then you will be pulling it again. If you suspect the pump is bad just replace it. Best price I found is from Cheapcycleparts dot com about 160 bucks I think.
You also don't need to do it the way the svc manual describes, there is no need to drain the coolant, do it this way.....
1 Pull the left and right side fairings.
2 Have the moto on a rear wheel stand so it is level and the rear is higher than the front.
3 Use two pair of locking hose clamp pliers (harbor freight) to clamp the hoses just behind the pump clamps.
4 Loosen and remove the two coolant hoses from the pump, have a drain pan handy as you will lose a small amount of fluid.
5 Remove the bolts holding the pump assy to the engine.
6 Have the new pump ready to install as you gotta be quick so you don't lose a lot of oil.
7 Wiggle the old pump a bit and pull it STRAIGHT out, align the slot in the new pump to match the orientation of the old one and push the new pump STRAIGHT in. It helps to lube the new O-ring on the new pump with a little oil or I use trans gel/vaseline. You don't want to damage or tear the new O-ring on assembly.
8 Reinstall the two coolant hoses then loosen the bleed screw on the pump till a bit of coolant starts to come out, tighten the bleed screw and top off your coolant level in the radiator, you lose about a pint that was in the old pump.
9 Add about a pint or half quart of new engine oil that was lost when the pump came out. Your amount will vary by how fast you worked, just top it back off.
10 Let the moto sit for 24 hours for the RTV you put behind the O-ring as posted previosly to cure.
11 Fire it up and let it get to full operating temp, the fan needs to cycle at least once. Retorque the mounting bolts and hose clamps. If nothing leaks you are golden.
12 Reinstall the left and right fairings, put on your helmet and go for a ride.
You might see a little (like a drop) oil or antifreeze come out over the next couple of rides, no worries it's the seals getting conditioned/ softened as a little fluid works into the labyrinth of the seal.
If you do it it like I explained it should only take you 20 minutes or so to replace the pump. If you do it as described in the manual you will be farting around trying to bleed the air from the coolant sytem forever it will seem like.
Then go in the house and pop a cold beer while patting yourself on the back 'cuz you just saved some fat cash from what the dealer would have charged you! Cheers
Old 03-03-2010, 09:56 AM   #8
gixersean
has anyone the part number of the seal behind the water pump, just took the fairing off my k5 to change the oil and filter, and noticed that oil is leaking from behind my water pump too
i haven't takin the pump off yet but hope to do it at the weekend
when i drained out the oil there was a small bit of water in with it, a tiny bit of pancake mix!! i hope this is just because of this seal?
gixersean is offline   Reply With Quote
Old 03-03-2010, 10:00 AM   #9
1qwik6
Superbike Champ
1qwik6's Avatar
Motorcycle: 07 600 track bitch
Dunno what bike you have but you can find it on Ron Ayers.
http://fiche.ronayers.com/Index.cfm/...oup/WATER_PUMP
1qwik6 is offline   Reply With Quote
Old 03-03-2010, 10:08 AM   #10
gixersean
Old 03-03-2010, 10:09 AM   #11
1qwik6
Superbike Champ
1qwik6's Avatar
Ok, so navigate on RonAyers to your bike's water pump. SHould be the same but just make sure.
Old 03-03-2010, 10:14 AM   #12
gixersean
thanks a million
Old 03-03-2010, 08:02 PM   #13
throwed_dc
throwed_dc's Avatar
ok heres my deal, tryiong to get this leak fixed but confused now.
I took off pump and one blot was blk and other wasnt, dont know if that was important but i removed pump and saw where the small seal goes but how should i remove it? just cut it? And the other seal i ordered also goes to water pump but dont see on housing wherre it should mount. i took a pic of pump how it looks after i removed it and theres no spot for it. can someone open those pics i posted with paint and walk me through it? please if you can or guide me a little more id really appreciate it. dont wanna just cut old seal off put new one on and this damn thing to leak again.
throwed_dc is offline   Reply With Quote
Old 04-07-2010, 09:06 AM   #14
wmx124
Motorcycle: k7 750 blk/silver
OP... I'm confused about how much RTV to apply?
Are the beads 1/16" in width around the entire circumference of the pump?
These beads are being used to seal the o-ring to the pump? Right?
wmx124 is offline   Reply With Quote
Old 04-07-2010, 07:35 PM   #15
SuperMotoRuss
After you remove the pump take a pipe cleaner and run it around the inside of the weep hole on the bottom of the pump snout, if it comes out dry it indicates the inner pump seal is good. If it's wet with oil/af or a mixture of the two you will need to replace the pump, the o-ring was ok. If the pump is good install a new o-ring and run a 1/16 in bead of ultra copper rtv behind the o-ring on the pump side and between the o-ring and the weep hole and reinstall the pump. Don't get real nutty with putting on too large of a bead or you will push rtv back over the weep hole when you reinstall it. If you block the weep hole off if the inner pump seal should fail it will leave nowhere for the oil or af to escape and it will be forced into either the oil or the coolant system. 1/16 inch is about the diameter of a pencil lead give or take a little.
Old 04-07-2010, 07:38 PM   #16
SuperMotoRuss
Run the rtv bead all the way around the pump snout, you are creating a flexible secondary "o-ring" behind the oem one.
Old 04-07-2010, 07:50 PM   #17
SuperMotoRuss
The o-ring in the pic near your finger tip on the pump snout is the one to replace, the other one (the big one) is the seal between the two halves off the pump itself. You don't need to disassemble the pump and change the big one, it's rare that it would ever leak. Be sure you check inside the weep hole on the bottom of the pump snout as installed for any af or oil, if it's wet in there you need to replace the pump. If your pump is ok use a small awl or hook tool to remove the old o-ring, don't cut it, you might nick the slot it is in and cause another leak. Run a small bead of RTV on the back side of the new o-ring (about a 1/16 inch back from o-ring towards the pump itself) all the way around the snout, you are creating a secondary seal behind the o-ring and follow the rest of my orig post. That black crap on the bolt and in/ around the snout and opening looks like carbonized oil from some type of oil leak. It's not chain lube cuz it would not be able to get inside the engine like that.
Old 06-27-2010, 04:38 PM   #18
k6GSXR6
C U L8RRRR
k6GSXR6's Avatar
Motorcycle: 2007 GSXR 600
how many miles does everybody have on their bikes. i have about 8,xxx on mine, started doin longer wheelies and more twisties 2 months ago and mine blew yesterday riding completely normal, riding around town.
k6GSXR6 is offline   Reply With Quote
Old 06-27-2010, 10:50 PM   #19
LatinKraze
Motorcycle: 600k7 SOLD
17k with original seal still holdin strong
LatinKraze is offline   Reply With Quote
Old 06-28-2010, 12:17 AM   #20
OutOfMyDepth
Mine went at 42,000 km (26K+ miles). I rode about 5-600 km in a day without a leak. Got up the next morning, let the frost melt, then rode 300 metres/yards to get fuel and it started leaking a LOT.
OutOfMyDepth is offline   Reply With Quote
