1989 gsxr750 slingshot - backfire problem : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-30-2009, 09:43 PM   #1
norcliffe
Motorcycle: 1989 GSXR750 Slingshot
First post for a newbie.Bike has not been used for a few months and decided to do some repirs. have repleced a leaking fuel line on the bike. After that , started the bike no probs. Left the bike for a few hours and then noticed a puddle of fuel on the floor. It was coming from the overflow pipe from the air filter housing. figured it was a sticking float in one of the carbies so i tapped the outside of the carbies and the leak stopped. Now when i try to start it crankes over a few times then one hell of a backfire. Tried this a few times and the same result. Engine cranks over half a dozen times and then a big bang as it backfires without starting. This has gone on for two days now as i try to fix the prob. Have taken the plugs out and the air filter out to let any extra fuel evaporate , but has not helped.
Any ideas what it could be.
Thanks
Paul
norcliffe is offline   Reply With Quote Quick reply to this message
Old 09-30-2009, 10:09 PM   #2
LEC
LEC's Avatar
Motorcycle: 86 GSXR 750 Blue
Re: 1989 gsxr750 slingshot - backfire problem
You don't have a backfire problem, you have a carb problem. You need to figure out where is the fuel coming from and see if you can stop it. Then go get new plugs. Unfortunately once those NGK's get wet they are toast.
With as many problems as I have had with mine I'm becoming really familiar with the symptoms. Unfortunately the cure still eludes me.
I know is not much to on but good luck! and welcome to the forum.
LEC is offline   Reply With Quote Quick reply to this message
Old 09-30-2009, 10:20 PM   #3
norcliffe
Thanks for the welcome LEC.
I think I have solved the fuel problem when i tapped on the outside of the carbies as there is no more fuel coming from the overflow pipe and hasnt been for a couple of days now. When i took the plugs out they were not wet and looked in good condition. I have checked to make sure i have fuel flowing from the tank and all is good.
One thing i wanted to check on is to make sure i have the ht leads on the correct plug as my manual does not say. Which coil to what plug ? sure i have them ok but just want to make sure .
Thanks
Old 09-30-2009, 11:05 PM   #4
spark11k
spark11k's Avatar
Motorcycle: gsxr's
Gday, coil on the left[ clutch side] goes too cyl no' 1+4, other coil 2+3, cheers
spark11k is offline   Reply With Quote Quick reply to this message
Old 09-30-2009, 11:20 PM   #5
norcliffe
Thanks spark11k . That is as i have got them. Didn't think i had them set up wrong as it would be hard for the ht leads to reach any other way. Just trying to eliminate things and make sure i wont do any damage when trying to fire it up. It has got me beat at the moment why it wont start and why it backfires so loud when i crank it over.
Old 09-30-2009, 11:57 PM   #6
mark_E
idiot
mark_E's Avatar
Motorcycle: 1990 GSXR1100
i'm with lec - fouled plugs
mark_E is offline   Reply With Quote Quick reply to this message
Old 10-01-2009, 03:07 AM   #7
snorse
snorse's Avatar
Motorcycle: '85 GSXR750 Streetfighter
Are you ure its not just flooding? Try holding the throttle completely open and turn the engine over a couple of times with the starter. Then try maybe half choke no throttle to start the bastard.
snorse is offline   Reply With Quote Quick reply to this message
Old 10-01-2009, 08:06 AM   #8
norcliffe
Thanks for everyones help. I have solved the problem and finaly got the old girl going. Turned out to be a 2 part problem and unrelated to the work i had been doing on it. One of the floats was stuck and hence the petrol in the overflow , a few taps with the hammer fiixed that . And the other was a fouled plug that had gone un-noticed. Once again thanks for everones help.
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
