1996 Gsxr 750 Wont Start : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-23-2009, 08:14 PM   #1
jspecef9
hey guys, just bought my buddys 1996 Gixxer, 750cc, 38k, the bike ran great before, sat thru this whole summer hasnt been touched, i put a new battery today, flushed and cleaned the tank, took the carbs off and cleaned all the jets and everything put fresh gas, i put everythin back together and go for a start, cranks over but wont fire up, i have spark, if i spray fuel into the carbs directly it wil fire up then dies, its most likely a fuel issue , what can cause this any help is appriciated guys
jspecef9 is offline   Reply With Quote Quick reply to this message
Old 09-23-2009, 08:32 PM   #2
Chocolate_Rain
I move away from the mic
Chocolate_Rain's Avatar
Motorcycle: 2006 R1 50th
Re: 1996 Gsxr 750 Wont Start
Give it good dose of cranking it should start. Mine sat for two months, did what you did, took a while for it to catch. Had to crank it, off and on, for a good minute.
Chocolate_Rain is offline   Reply With Quote Quick reply to this message
Old 09-23-2009, 09:02 PM   #3
jspecef9
i kinda figured that to, i tried crankin it for like 10mins and nothig wont fire unless i put gas in the carbs directly
Old 09-23-2009, 09:24 PM   #4
Chocolate_Rain
Maybe the floats need to be adjusted.
Old 09-24-2009, 10:31 AM   #5
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Before adjusting the floats. did you check to make sure the vacuum line is connected to the petcock on the bottom of the tank?
If it is not, the tank will not flow fuel to the carbs.
Also check that the fuel pump is pumping.
GSXR-Freak is offline   Reply With Quote Quick reply to this message
Old 09-24-2009, 11:54 AM   #6
jspecef9
pull the gas line that runs from petcock to carb pulled it off by the car and there is gas pooring out of it when i turn the key , witch mean , im not getting fuel into my fuel rail
Old 09-24-2009, 03:46 PM   #7
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Stock, there is a small filter (screen) located just inside the fuel rail connection. Check for it and make sure it is clear.
Old 09-24-2009, 07:03 PM   #8
jspecef9
so i was messing around today with the carbs,pulled them off again, and what i noticed was that the fuel isnt getting into the carbs at all , so i took it apart tried pooring carb cleaner into the fuel inlet rail, and blowing it out wit a compresor, and still nothing, i put a little bit of fuel into the fuel rail niple and it just stays in the niple, doesnt flow thru into the float bowl, what should i do ?
Old 09-24-2009, 08:19 PM   #9
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
The fuel pumps on these srads are almost suicidal.
They frequently seize up from inactivity and i suspect yours has done just that!
If it was running fine pre season and you cleaned the carbs and it appears to not be getting fuel, then the pump is definitely suspect here!
Raise the tank and give the fuel pumps base plate:
1-A stern look-see
2-A tongue lashing
3-A verbal bashing
4-A few taps with a plastic mallet
5-50 swings with a 5lb sledge
I'm no expert but i'd opt for #4 first!
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 09-24-2009, 09:10 PM   #10
jspecef9
1-A stern look-see
2-A tongue lashing
3-A verbal bashing
yeh but i hear the pump priming, and i check the gas line for gas and gas is flowing
Old 09-24-2009, 09:56 PM   #11
THE SRADIATOR
Gas is flowing from the fuel line but the carbs bowls are dry?
Most curious.
Flowing like dribbling out, as in gravity fed or FLOWING, as in squirting across the room under pressure?
Old 09-27-2009, 10:15 PM   #12
jspecef9
so i put everthing on , now i have fuel goin to my carbs it was some wiring issue, bike starts up but runs like crap , brand new plugs, i noticed blue flames out the exhaust and seems like it chokes out sometimes when i give it gas , wat can cause this ?
Old 09-27-2009, 10:30 PM   #13
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Do you have the air box on and connected to the vent tube? The vent tube connects under the front of the air box.
Old 09-27-2009, 10:42 PM   #14
jspecef9
air box is connected, all the vaccum , and vent tubes are hooked up
Old 09-28-2009, 07:11 PM   #15
jspecef9
i tried starting it today , and fired up i reved it died, wouldnt start, then cranked it for about 30second full throttle bam fired up ran like shit full throtle at 1100rpm, then it catches revs fine not missing then it does dies again ? wat will cause this ?
Old 09-28-2009, 07:20 PM   #16
Chocolate_Rain
Cold engine, let it warm up first.
LEAVE the throttle alone.
Old 09-29-2009, 03:45 AM   #17
Dencho
Dencho's Avatar
Motorcycle: 1998 GSX-R 750 SRAD (SOLD)
^ Haha, yea man. Don't rape the bike.
Maybe your bike is running rich, and that could be the reason it dies when you open up the trottle alot.
Dencho is offline   Reply With Quote Quick reply to this message
Old 09-29-2009, 05:28 PM   #18
jspecef9
went to start it today , didnt fire up , i pulled the tank off , cylinder 1 and 2 throtle boddies were soaked with fuel tried starting it fired up and ran and IDLE'd by it self for a good minute :S, really weird, wha im guessing is the float needles were siezed i had to use a pin to get them out, most likely the rubber piece on the end of it got damaged and thats wha most likely the problem is
Old 09-29-2009, 05:57 PM   #19
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Sounds like a float needle problem for sure
Old 10-03-2009, 07:35 AM   #20
Ephry
Have something similar on the 97 750. Sradiator and I were looking at the bike and trying to get it started for almost two hours. Make sure the plug wires are in the right order. vacuum lines need to be freed up. I'm giving the bike a looksey today to make sure everything is plugged up how it should. Give us an update if you've figured it out.
E
Ephry is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
