ASV Levers play? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 08-26-2009, 10:53 PM   #1
DemianM
DemianM's Avatar
ASV Levers play?
I have received and installed my shorty ASVs, but noticed some play (up and down) on the brake lever. Should I really tigthen the bolt, or is it normal? I made it quite tight for being a flat head screw, but there is still some play....
thanks guys!
DemianM is offline   Reply With Quote
Old 08-26-2009, 10:58 PM   #2
gsxr60006
gsxr60006's Avatar
Motorcycle: 2006 GSXR 600
Re: ASV Levers play?
mine have very little play. less than stock for sure. but a little is acceptable
gsxr60006 is offline   Reply With Quote
Old 08-26-2009, 11:44 PM   #3
leveltwo
leveltwo's Avatar
Motorcycle: K8/6
the clutch side is supposed to have a bit of play, you can adjust the play in both levers if needed, the manual is floating around the site if you wanna take a look as to how to tighten the lines
leveltwo is offline   Reply With Quote
Old 08-27-2009, 08:35 AM   #4
DemianM
DemianM's Avatar
The play I am talking about is up & down, specially on the brake side.....but I adjusted them as per manual.....it would take a lot more force to eliminate it.....did not seem like it would tighten up anymore.
Old 08-27-2009, 08:43 AM   #5
MotoMummy
Parts Bitch
MotoMummy's Avatar
Motorcycle: Mummy Bike
A little play is normal as you also don't want the lever squished in there with no play as you also risk making the lever stick.
MotoMummy is online now   Reply With Quote
Old 08-27-2009, 12:38 PM   #6
yoshhhhh
yoshhhhh's Avatar
Motorcycle: k8 600
I don't if i read this right when I installed my levers. But I remember something about over tightening can damage the brake mechanism. I could be wrong, I just remember instructions said not to over tighten them.
yoshhhhh is offline   Reply With Quote
Old 08-27-2009, 05:32 PM   #7
redlinegsxr
Il Padre Guinnea
redlinegsxr's Avatar
Motorcycle: K8 600
Like the mummy said a little play is necessary so they dont cause friction and risk getting hung up
redlinegsxr is offline   Reply With Quote
