bike runs terrible after rain : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-25-2009, 10:02 PM   #1
gsxr60006
gsxr60006's Avatar
Motorcycle: 2006 GSXR 600
anyone know what would cause a bike to run really poorly after being ridden in heavy rain or being hose washed...? I plan on using di-electric grease on all connectors, but is there anything else I can do to both diagnose this problem and or fix it...? This all concerning an older carbed bike.
gsxr60006 is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 10:40 PM   #2
LynnM
Re: bike runs terrible after rain
Does the air filter get wet ?? Could have water puddeling on the spark plugs
LynnM is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 11:28 PM   #3
TheLonebiker
TheLonebiker's Avatar
Motorcycle: K8 750
i ride in the rain all the time, my bike runs fine. Give us some more details so we can help.
TheLonebiker is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 01:32 AM   #4
Bobthebutcha
Bobthebutcha's Avatar
Water/moisture has obviously caused a short somewhere. I would start with the SP wires & trace the short. Unfortunately unless there are obvious signs such as cracked wire shielding etc...there are not many shortcuts!
Try and dry out the bike by leaving it in the sun for a few hours with seat, tank & fairings etc...off to dry it out faster.....
Once its running again use dielectric grease as mentioned on all electrical connections to head off corrosion and shorts like this......
Bobthebutcha is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 11:54 AM   #5
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B
didn't get water in the gas did u?
Bagherra is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 01:17 PM   #6
750 Gixxer 21
Motorcycle: 02 GSXR 750
I agree need alittle more info. How is it running poorly? Missing out? Lack of power? Hard to start? Or what?
750 Gixxer 21 is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 01:49 PM   #7
phpsteve
+1 to the air filter possibly getting wet. That will definitely do it.. especially if it is the stock filter.
phpsteve is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 07:44 PM   #8
gsxr60006
gsxr60006's Avatar
its a 92 600r. And it was running at like 1/3 power and just feeling like shit, really bogging whenever you get into the throttle and breaking up. It would start and idle fine anything over 1/4 throttle it ran BAD. The air filters are k&n indiv filters and they were not wet, and maybe the spark plug boots got wet but I pulled them last time it started doing this and replaced them and it still ran poor. I unplugged every electrical connector and they we all dry the next day but still ran bad.
I am pretty confident this is an electrical prob. I check all the mechanical problems i think. And I drain the carbs and the tank and none of it helped. On the third day after we washed it, it finally started running right again. now it runs 100%. any ideas
Old 08-26-2009, 08:04 PM   #9
Spitz04
Motorcycle: K7 1000
Water really doesnt "short" a 12v electrical system, it may "short" something like a spark plug boot where its trying to hold in tens of thousands of volts however. I've heard water entering the fuel tank after a rain via the gas cap on some bikes, try an addtive in the fuel to rid water .
Spitz04 is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 10:44 PM   #10
gsxr60006
gsxr60006's Avatar
i am not so sure you are correct spitz04. I have had water reak havoc on the computor systems in my cars before. I was wondering if it could be affecting the coils or something. but i will check the sp wires and boots.
Old 08-26-2009, 10:48 PM   #11
chrisdizz22
Supersport Racer
chrisdizz22's Avatar
Motorcycle: 06 gsxr 600 (SOLD)
sounds like what my old bike was doing when the battery went bad.... it would start and idle fine, but went to hell when you tried to rev it... i would get your battery, and charging system checked out..
chrisdizz22 is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 10:52 PM   #12
gsxr60006
gsxr60006's Avatar
its a new battery and it runs perfect for like weeks but once it rains really hard or we wash the bike it runs bad for a day or two.
Old 08-27-2009, 09:21 PM   #13
gsxr60006
gsxr60006's Avatar
any other things to check....?
