2008 hot stalling problem : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-09-2009, 10:00 AM   #1
akillya
akillya's Avatar
Motorcycle: 2007 GSXR 750
I have a 2008 GSXR1000. When the bike is hot it always stalls once the RPMs are brought down to idle. When I refire the bike it will not idle, it keeps stalling. Any ideas?
akillya is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 10:20 AM   #2
Chugs
Lets go racing!
Chugs's Avatar
Re: 2008 hot stalling problem
Do u run a power commander or engine management? I've had problems on hot days as well, fires right up if I take off my yosh ems.
Chugs is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 10:37 AM   #3
akillya
akillya's Avatar
No I am not running a Power Commander or a Yosh EMS.
Old 07-09-2009, 02:25 PM   #4
oldfart01
Loves Ass Raping OG!!
oldfart01's Avatar
Motorcycle: Dromaius Novaehollandiae, ...XR650R .K7-1000
I have a PCIII & full exhaust, never had an issue even once with idling.
oldfart01 is online now   Reply With Quote Quick reply to this message
Old 07-09-2009, 02:46 PM   #5
brunobenchimol
Motorcycle: GSXR-1000 K8 (BR)
Is your bike stock? You usually get that when your lambda sensor is working bad (thats on a car) which fucks up the ECU.
If you want failing when rolling its not the injectors or anything else... anyway does your FI light comes up? You may have a leak anywhere?
Hope someone can help you better.
brunobenchimol is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 04:25 PM   #6
TVONE2
TVONE2's Avatar
Motorcycle: 2007 GSXR1000 '94 FZR1000
sounds like the ISC (idle speed control) valve is hung up.. or bad.
TVONE2 is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 07:46 PM   #7
Pretty sure the 2008's had the ISC recall done to them already.
What is your idle set at?
Should be set around 1250-1500. If it's set too low it can randomly die.
SPL170db is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 08:04 PM   #8
Anthony D
Super Moderator
Anthony D's Avatar
Motorcycle: None currently...
+1 on your idle being too low. should be around 1,300rpm when the bike is at operating temps.
Anthony D is online now   Reply With Quote Quick reply to this message
Old 07-10-2009, 12:09 AM   #9
aussie lee
Motorcycle: K8 750 B/W
ask the service dept.
aussie lee is offline   Reply With Quote Quick reply to this message
Old 07-10-2009, 09:43 AM   #10
akillya
akillya's Avatar
I already adjusted the idle up so I know its not that but it did improve the situation. I suspect it is the ISC valve so I may just plug it and reset the idle down.
Old 07-10-2009, 02:58 PM   #11
d3coy
d3coy's Avatar
Motorcycle: 72" Black/Orange GSX-R 1000 K7
are your spark plugs good? do you run a lot of race gas? the reason i ask is because some types of race gas can cause fueling problems if left in the tank for extended periods. also, how "hot" is your bike when you encounter the problem? i know if it creeps up around 200F the bike pulls timing, which makes the rpms fluctuate irregularly.
d3coy is offline   Reply With Quote Quick reply to this message
Old 07-10-2009, 03:18 PM   #12
Bobthebutcha
Bobthebutcha's Avatar
You have a vacuum leak. Look for cracks, loose/missing connections hoses etc.....
Bobthebutcha is offline   Reply With Quote Quick reply to this message
Old 07-13-2009, 01:23 AM   #13
akillya
akillya's Avatar
Checked for vacuum leaks, found none so I guess I will test the ISC valve operation via the manual.
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
