InterNatrix TW-1000 install instructions for 07 750 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Mods & How To's
Old 07-06-2009, 06:14 PM   #1
GIXXERKELLY
GIXXERKELLY's Avatar
Motorcycle: 2007 GSXR 750
I just finished up my install of this alarm. I thought this was a nice bang for the buck. I did have a couple of questions during the install and called Internatrix tech line. They were very pleasant to deal with. I hope the following will help someone with a K7 that is thinking of installing this alarm.
Here is a link to InterNatrix
http://www.internatrix.com/
First remove the plastic on the back section of your GSXR. This will make the install much easier.
The inside of the side panels is quite roomy if you want to install some of the pieces here (shown for reference only)
I removed my set valve a month ago so, I mounted the brain in the same place since they are almost the same size. The adhesive that comes with it is pretty sticky. I cleaned the area with rubbing alcohol before placing it on the bike.
Remove the exsiting screw and attach the short ground wire to the frame.
I mounted the siren and perimeter sensor under the seat.
I mounted the antenna on the left side of the bike. Clean the bike's frame before sticking to the frame. I added zip ties for extra safety.
Zip tie the main unit in place when your happy with it's location.
I drilled a hole in my license plate bracket to mount the LED light.
Locate the wiring coming off the rear center section. You will need to tap three wires.
For a switchable hot, tap the brown wire for the tail light. Attach the brown wire from the alarm.
Find the blueish/green wire for the turn signal on one side. Attach the blue wire from the alarm.
Find the black wire for the turn signal on the other side. Attach the orange wire from the alarm (DO NOT TAP THE BLACK WIRE WITH THE WHITE STRIPE!)
Locate the starter relay. It is on the right of the siren.
Locate the yellow wire with the green line. Cut this in two. Attach the black wire with the white stripe to one end and the white wire with the black stripe to the other. This will disable the starter if the alarm goes off.
Tuck any wires that are hanging down and reinstall the plastics.
I'll try and post a video of it's functions later. I didn't show the attachment of the positive/negative wires to the battery since I feel this should be easy to understand. The wiring of the perimeter sensor, LED, and siren are plug and play.
I hope this helps someone.
Cheers,
Kelly
2007 GSXR 750
GIXXERKELLY is offline   Reply With Quote
Old 07-06-2009, 07:11 PM   #2
utp216
utp216's Avatar
Motorcycle: 93/95 GSXR 750
Re: InterNatrix TW-1000 install instructions for 07 750
Nice write up dude!
BTW: What did the alarm cost?
utp216 is offline   Reply With Quote
Old 07-06-2009, 08:54 PM   #3
Hidalgo
Hidalgo's Avatar
good one. Waiting for the video. Thanks
Hidalgo is offline   Reply With Quote
Old 07-06-2009, 09:29 PM   #4
GIXXERKELLY
Originally Posted by utp216 View Post
Nice write up dude!
$157 shipped
Old 07-07-2009, 09:28 PM   #5
wowitztai
wowitztai's Avatar
Motorcycle: 2006 GSX-R 600
Thinking about putting one on. I wonder if the Vipers would work.
wowitztai is offline   Reply With Quote
Old 02-22-2010, 10:52 PM   #6
FEDXBOX
FEDXBOX's Avatar
Motorcycle: 2006 SUZUKI GSX-R 600
this is the best installation tutorial, thank a lot.........
FEDXBOX is online now   Reply With Quote
Old 05-11-2011, 03:02 PM   #7
ReasonableDoubt
Heads up; this system is now on Closeout for $130 shipped.
ReasonableDoubt is offline   Reply With Quote
Old 11-26-2012, 07:54 AM   #8
GSXRWallace
fantastic write up. Does anyone have any instuctions and how to on getting the remote start to work?
GSXRWallace is offline   Reply With Quote
