GSXR 750 powered yamaha warrior 350 PROJECT : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Bugman's Projects: 02 GSX-R 1000
Old 04-17-2009, 07:32 PM   #1
WesTXwitesnake
WesTXwitesnake's Avatar
Ok.. i dont ride bikes but i have started a nice little project! The quad (4wheeler) is a 00' yamaha (yeah i know) warrior 350. The good part is it is powered by a 00' suzuki gsxr 750. And Since this has became quite a project i thought id do some research and seek some help from people who know more about this powerplant than i do. i have tons of questions.... I plan on doing a basic motor rebuild myself, i know my way around motors but this is the first bike motor i have worked on. So when the time comes any tips tricks or whatever would be greatly appriciated. For all the details on this project please check out this page http://www.fquick.com/garages/viewvehicle.php?id=15618
here are some pics:
here is the wiring harness.. the guy who origionally built this hacked it up pretty good. since this photo i have labled most of what i could find and wired in a gauge cluster.
now prepare for questions...
WesTXwitesnake is offline   Quick reply to this message
Old 04-17-2009, 07:36 PM   #2
WesTXwitesnake
Re: GSXR 750 powered yamaha warrior 350 PROJECT
ok first off i want the tach on the gauge cluster to work and possibly the speedo, what do i need to hook up for that to work? what is the speed sensor and what does it go to? ive found the connector.. whats it connect to?
Old 04-18-2009, 05:40 PM   #3
IridiumRed
IridiumRed's Avatar
Motorcycle: RIP El Toro. Long live new bike BIG FOXIE! Ex KWS AMA 08 GSXR1000
Theres a cover over the front (engine) chain sprocket. The sensor goes there.
There's one nut that secures the front sprocket, and then there is a special "castle nut" that goes on top of that (it attaches with an allen head bolt that screws into the center of the output shaft).
The sensor on the cover "sees" the posts on the castle nut going by, and calculates speed based on that
That castle nut has another purpose too, it acts as a secondary backup for the nut holding the front sprocket on (in my opinion)
IridiumRed is offline   Quick reply to this message
Old 04-18-2009, 06:56 PM   #4
WesTXwitesnake
thanks man i appricate the help. looks like im missing the sensor and the castle nut. there is one large nut like you said but there doesnt seem to be enough thread left on the output shaft for anything else to screw onto?
would a sensor from an 01 gsxr 1000 work?
Old 04-22-2009, 12:55 PM   #5
gunther1000
It burns down where I sit
gunther1000's Avatar
Motorcycle: K6
I'd be willing to bet that the 01 will work.
P.S. Looks good man! I put my 2001 Gsx-r 1000 motor in a 2002 Yamaha Raptor Frame. But it was an intercooled Turbo... 10" over swing arm wasn't near enough I think.
I sold it to the owner of off road armadilo (sp?) in MT.
He does sand drag hill climbs with it.
gunther1000 is offline   Quick reply to this message
Old 04-28-2009, 02:13 PM   #6
WesTXwitesnake
Sweet, I'll see if I can find a sensor.. thanks man. Shit I bet that quad was insane! I want this one to be more than just a drag quad tho. I'd like to tear up the dunes and haul ass on long desert trails (Baja 500 type stuff) No crazy stunts or huge jumps. I just wanna go fast
Old 07-08-2009, 11:06 PM   #7
brocklanders
brocklanders's Avatar
Motorcycle: 07GSXR750
Sweet ride! I wanna try that thing.
brocklanders is offline   Quick reply to this message
Old 07-09-2009, 04:40 PM   #8
Shanes750
Shanes750's Avatar
Motorcycle: K7 GSXR 750 K6 (track)GSXR 600
Damn! Looks awesome!
Shanes750 is offline   Quick reply to this message
Old 08-12-2009, 07:14 PM   #9
WesTXwitesnake
UPDATE:
just about finished working on the frame and suspension. still need to find a radiator to build the mounts for it. time to finish all the wiring and see if this thing will run. slowly but suely its comming together.
thinking of ditching the plastics and fabricating some body panels out of thin gauge aluminum.
Old 09-02-2009, 12:22 AM   #10
WesTXwitesnake
During some dissassembly I found out the thermostat was stuck open so i went looking for one but the 2000 model thermostat housing was different from mine, WTF?? This meant i didnt have a 2000 model motor!?!
I got the engine number and called my local Suzuki dealer... After some research i was informed that the number matched up to a 1998-99 bike. So this started a whole new parts seach. The same day i found a guy who has a 99 gsxr 750 he is parting out! Talk about luck!! I needed several parts like a radiator, speed sensor, exhaust, and a few other small parts to get this motor running like it should. I talked to the guy and he has all the parts i needed and is asking very fair prices for them so i am very excited!!!
If all checks out good i will be getting his speed sensor to get the tach and speedo to work, His custom Yoshimura exhaust with header, and complete radiator (with fan, sensors, all hoses, overflow container, thermostat and housings!)
Once i get all these parts i can finish the fabrication on the frame, brackets, and motor mounts. Once everything is hooked up and mounted perfect i will take the motor to the Suzuki dealer to get it all checked out have the valves adjusted and whatever else it needs. hopefully there wont be any serious problems with the motor!
I can see the light at the end of the tunnel! i cant wait to get this thing running!! wish me luck!
Old 11-08-2009, 01:14 PM   #11
BandheeBoy
Motorcycle: 1988 banshee with a 1997 gsxr 600 engine in it
i have a 97 gsxr 600 i got from my uncle it has been crashed... i think everything is there except the gas tank and all the gauges... im planning on putting the engine in a 88 banshee... i want to get it running before i take it out... what wires do i need to mess with for the ignition to get the key to the on position...(there is no key assembly or gauges) and so on to get the thing started?
BandheeBoy is offline   Quick reply to this message
Old 02-15-2010, 01:02 AM   #12
WesTXwitesnake
man i'd have to look at my ignition to be able to tell you. you could just get a new ignition.. maybe hook up a push button start?
Old 06-06-2010, 02:12 AM   #13
oofastlineoo
that thing must be sick to ride......
oofastlineoo is offline   Quick reply to this message
Old 08-17-2010, 08:23 PM   #14
krivs388
krivs388's Avatar
Motorcycle: 98 Suzuki GSX-R 1100
that bike must screw. talk about a roost! i can only imagine how far the roost shoots lol
krivs388 is offline   Quick reply to this message
Old 08-17-2010, 08:25 PM   #15
krivs388
krivs388's Avatar
Real Name
What is your real name?
