Lower my bike with dogbone : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-17-2003, 01:37 PM   #1
PDan
Motorcycle: Dan Phan
Hi! I want to lower my bike 3 inches in the rear. Should I also lower the front 3 inches also by sliding the fork tubes 3 inches up of the triple clamp? Is this relatively easy done? How would it handle? Has anyone done this? What dogbone should I buy that would lower it 3 inches. Which dogbone is the best? Thank you!
PDan is offline   Reply With Quote
Old 12-17-2003, 05:42 PM   #2
gixxerman
Motorcycle: 97 gsxr 750
Re: Lower my bike with dogbone
Try the searching the forums. Its been discussed many times. Is it worth it, no way. Lowered bikes . Besides they handle like crap lowered.
gixxerman
gixxerman is offline   Reply With Quote
Old 12-17-2003, 06:22 PM   #3
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
IMO, don't do it... if you do lower the rear anyway, lower the front equally. But you can't lower the front 3". The fender and the fairing would hit each other all the time when riding
SVS is offline   Reply With Quote
Old 12-17-2003, 06:36 PM   #4
PDan
what is the most I can lower? What if I lower it 2 inches both front and back?
Old 12-17-2003, 10:30 PM   #5
SVS
SVS's Avatar
Dunno I don't have stock suspension on my SRAD. I don't think I would lower it more than 1" - imagine lowering it 2-3" up front, hitting a bump in the road and cracking your fairing and/or fender... However, I have lowered the front of my SV 20mm (4/5"" - along with raising the rear about 4" with another shock to make it more flickable ) - no problems there.
Why do you want the bike lowered? To reach the ground better or for looks? If your legs are short, look into shaving the seat first (lots of posts about that on GdC), before you mess with the suspension. If it's for looks, don't do it - only good for drag racing... Lowering the bike BOTH front and rear will limit your ground clearance in turns severely - ever seen a cruiser going through a turn dragging all sorts of parts without really leaning? Lowering the rear only will also really f*ck up the handling
Old 12-18-2003, 03:58 AM   #6
Riden420
Motorcycle: 04 1000
Hey, gixxer store just got dogbones in, order them up!!
D
Riden420 is offline   Reply With Quote
Old 12-18-2003, 08:13 PM   #7
SVS
SVS's Avatar
Oh yeah - if you DO lower the bike anyway, check the side stand length - you might have to shorten it or the bike will fall to the right when parked
Old 12-19-2003, 12:19 AM   #8
l-w
l-w's Avatar
Motorcycle: LWatts
Well You will not crack the bottom with a 2 inch drop as far as kickstand goes you can not have it chpped but your bike will set up higher rather than a lean (possible to fall over so beware) You can buy adjustable kickstand and adjustable dogbones they have diffrent types some that are easier to adjust than others. If you get adjustable which makes sense to me atleast you can alway up the height of it. If you get that i suggest get the adj kickstand as well. This should set you back anywhere between 50 bucks to 200 bucks depending on what you want so You can drop it for your everyday riding or adventures to the strip and raise it back up for the Canyons
sites You can contact cycle concepts he will be able to give you good deal on those and more options also think the board has some as well
l-w is offline   Reply With Quote
Old 12-19-2003, 01:46 PM   #9
PDan
WIll lowering the bike 2 inches in the front and 2 inches in the back make the bike handle worst? If so how?
Old 12-19-2003, 01:50 PM   #10
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Not worse, but you have a LOT less clearance, so when you lean the bike over you will drag hard parts with less lean angle.
GSXR-Freak is offline   Reply With Quote
Old 12-19-2003, 02:10 PM   #11
PDan
Would 2 inches in the front hit the front fender when I go over bumps?
Old 12-19-2003, 02:27 PM   #12
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
I would think so. You dont have that much room up there.
Old 12-19-2003, 05:13 PM   #13
GiXxXie
how tall are you ??? 3 inches is alot to lower your bike.
My 97 gixxer 600 is lowered 1.5 inches at the rear and 1 inch at the front. Im 5'2 and with my leathers and riding boots on I touch just fine.
I got my lowering links from
www.watsendesign.com
And it doesnt handle like crap. it handles great, I also take the bike out to the track and it handles great there as well.
GiXxXie is offline   Reply With Quote
Old 12-19-2003, 06:13 PM   #14
99 suzuki gsx-r 750
i got a 1, 2, and 3 inch pingel lower dogbone on mine.. mine is set at 1 inch and it's already too low.. i'm thinking of raising it back up.. my front is down 10mm or 1cm.. i had my kick stand cut and welded back on.. the guy who did the weld said the welding is stronger..
johnny
99 suzuki gsx-r 750 is offline   Reply With Quote
Old 12-19-2003, 07:08 PM   #15
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Dude. If yo lower the back of the bike more then front, it jacks up the handling of the bike. Makes it turn slow and crap...
I have the rear of my bike RAISED like 3/4" over stock, and the front about 2mm taller then stock. And it is great for getting on the gas.
I bet you have a hard time on the exit of turns. Like it wants to run wide. But if you are not a very fast rider you might not notice it...
ANyhow... I WOULD NOT do what you are talking about. Anyone that really knows there shit about bikes will tell you the same thing, if you lower it you are taking away ground clearacne, and if you lower the back more then the front you will push wide in the exit, and turn slow.
But what do I know???
Old 12-20-2003, 06:13 PM   #16
jp233
Superbike Champ
jp233's Avatar
Motorcycle: YAMAHA TZ-250
I agree. I had my gsxr raised up 9mm in rear and dropped 5-6 mm in front. it dived into corners like a demon, geometry is all relevant with lowering you gotta watch for the sidestand and dragging stuff. try it out and if it works for you, great. John's right in what he said. but what do i know?
hehe bad geometry can hinder you from doing hard riding....
jp233 is offline   Reply With Quote
Old 12-20-2003, 07:24 PM   #17
Fujiwara Takumi
Fujiwara Takumi's Avatar
I gotta agree with everyone, after lowering a bike it feels like crap, because a buddy of mine lowered his srad 750, and it feels like crap compared to mine.
Fujiwara Takumi is offline   Reply With Quote
