I got my manual, searched the threads, saw pics with a clear tube (that I don't have) and found lots of tips on what fluid to use. . . But the step by step hold your hand of "how to replace your brake fluid" isn't there.
And the clear tube can just be a piece of fuel hose - which you can get for next to nothing from any auto parts store. You'll need an 8 mm fixed spanner for the bleed nipples, preferably a ring type. Don't use an adjustable spanner, it will ruin that small nipple fast...
DOT 4 should be what the manual recommends but i could be wrong. thats just what I use. if you have a habor freight locally they sell a nice little kit that has a vacumm
Location: littlest biggest city in the west. (is that right?)
Motorcycle: kawazuki CB-R1
Re: Changing Brake Fluid
I'd say changing it every 2 years would be just fine if you're not taking it to the track. Once it gets darker than a good scotch is my rule of thumb.
Use 3/8" fuel line to go from the bleeder to any old container you have handy. Keep pressure on the brake lever with one hand and use the wrench to slowly loosen the bleeder with the other. Just crack the bleeder open. As the lever gets near the bar (not all the way in) close off the bleeder. Repeat until the reservoir is almost empty - you'll get into a rhythm while doing it. Refill the res with fresh fluid. Once you've filled the res 3 times go to the other caliper and repeat. Fill the res only twice this time. Top off the res, clean up, and go ride.
I use the Prestone DOT 4 in any auto store. $6 for the big bottle. And yes, I close the bottle and save what I don't use for next time (or the car, or whatever).
"Go that way really fast. If something gets in your way - turn!"
Who's Lisa Catera?
Any quality brand DOT 4 or 5.1. DOT 5 is NOT compatible with these, it's a totally different fluid and can't be used.
5.1 has a higher boiling point than 4 but that doesn't really matter on the street. That's the main difference. OTOH, the prices of the two are usually pretty damn close so I use 5.1 in all my bikes myself.
Another thing. Once a bottle of brake fluid has been opened, the fluid will start absorbing moisture from the air that's left in the bottle, breaking down fast. The brake reservoir has that membrane to keep the air gap to a minimum at all times. For that reason only buy brake fluid in small bottles (they are 250ml here or about 9 oz) and throw them away after you change the fluid. The larger bottles are for cars. Don't be tempted to buy them for economy even if the volume price is lower - it'll just deteriorate on the shelf...
And - brake fluid ruins paint and plastic so clean off immediately if you spill on the bike.
Rest in Peace, Grizz and Robs - miss you my Friends.
Yeah Dot 4 is what I'm supposed to use, they have valvoline, and store brand, no stp at this place but I can certainly look elsewhere, or the dealer. No harbor freight either.
How come one place I read I need to siphon the fluid out of my resivoir? Can't just bleed it through the valve? Guess that is what the vacuum is for?
Valvoline is just fine. You can also use car brake fluid as long as it's DOT 4 or 5.1 - same thing
And you can just bleed the old fluid, no need for siphoning.
How come you only fill the res twice for the second caliper? And which caliper are you referring to? What if I do the front first then back?
Two front calipers. While doing the first side you're changing out the fluid in the res and the lines as well as the caliper. The second side you just need to change the fluid in the caliper - the lines and res are already fresh!
Ah HA! I would have figured that out if I realized there were two bleeder valves to each wheel. I haven't even taken a look yet. Just figured I'd get everything ready first.
Be extra super careful that whatever container you're using to catch the old brake fluid doesn't move and is out of the way! Don't be a dumbass and knock it over, covering the floor and your tire in goo. Not that I would know anything about it....
Do yourself a favor and suck most of the fluid from your res. to begin with, and then refill with fresh, this should cut down on the time quite a bit. Other then that you can gravity bleed them (open one or both bleeders) and let gravity do the work! May take a bit this way, or you can do the normal pump, open, close repeat method.. Your best bet is make sure the rev. never gets empty..
