how streetable are lockup clutches : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Racing & Stunts > Drag Racing
Old 02-18-2009, 05:48 AM   #1
old gsxr
Superbike Racer
old gsxr's Avatar
has anyone used one on a street bike ?any disadvantages?
old gsxr is offline   Reply With Quote Quick reply to this message
Old 02-18-2009, 08:24 AM   #2
gsxrstephen
gsxrstephen's Avatar
Motorcycle: K7 1000
Re: how streetable are lockup clutches
i use mine on the street. you just cant pull the clutch in at high rpm. other than that feels just like the stock clutch
gsxrstephen is offline   Reply With Quote Quick reply to this message
Old 02-18-2009, 03:28 PM   #3
old gsxr
Superbike Racer
old gsxr's Avatar
thanks stephen , that will work with my ignition kill shift setup i'm also planning-ken
Old 02-18-2009, 05:38 PM   #4
perry
perry's Avatar
Motorcycle: 2005 GSXR 1000
i have been running mine on the street also with no problems. the only con i found is you want to do a roll on make sure you a alot of rpm and you are not in a higher gear or it may just run right through the clutch depending how much static you have. if i stab mine im in 1st or 2nd.
perry is offline   Reply With Quote Quick reply to this message
Old 02-19-2009, 05:54 AM   #5
old gsxr
Superbike Racer
old gsxr's Avatar
so that's iff you adjust to get not too hard a hit off the line , is there any
clutch release at all or is it like a moped clutch? i've only seen pictures on ape's site -thanks for your information . i'm looking at nearly 200 hp and wondering how else the clutch will cope unless i go lockup -ken
Old 02-22-2009, 12:09 AM   #6
old gsxr
Superbike Racer
old gsxr's Avatar
THERE doesn't seem to be anywhere on the clutch outer with finger weights of a lockup clutch for the clutch pushrod to dissengage against? so WTF?
Old 02-22-2009, 09:24 PM   #7
ZR28
ZR28's Avatar
Motorcycle: 2001 GSXR 1000 2006 GSXR 1000
The lock up arms push on the pressure plate. If you pull in the clutch, the pressure plate is pushed off of the clutch steels and fibers. But as mentioned above, if you are in the higher RPMs then it will be harder to disengage the clutch.
ZR28 is offline   Reply With Quote Quick reply to this message
Old 02-23-2009, 06:33 AM   #8
old gsxr
Superbike Racer
old gsxr's Avatar
THANKS ZR28 ,http://gsxrzone.com/clutches.html
THE ONE FOR MY 1100 HERE MUST BE STAGE2 LOCKUP THE SIZE OF THE CENTRE HOLE MUST BE 2". -KEN
Old 02-23-2009, 10:47 PM   #9
ZR28
ZR28's Avatar
Not too sure about the MRE lockup. I've never seen one installed but I'm sure it releases similar to the MTC.
Old 02-23-2009, 10:57 PM   #10
Chuckles05
Redneck Rider
Chuckles05's Avatar
Motorcycle: 2009 Yamaha Zuma 155 2010 Yamaha Zuma 125
Go with MTC in my opinion, 2 stage is a simple lockup at high speed, multistage you can adjust and set multiple stages for more control. Unless you have the new Gen II multistage the lockup is controlled by speed, mine is setup so that above 45-50 MPH the first stage engages when engaged do not use the clutch lever you will bend and wreck parts. any were below your lowest set stage engagement its just like a stock clutch unless you have weak springs in in which case it will be very soft and slip.
Chuckles05 is offline   Reply With Quote Quick reply to this message
Old 02-23-2009, 11:07 PM   #11
gsxrstephen
Motorcycle: K7 1000
set up right you will love it. i had mine set soft so i can just throw the clutch here's a video of my bike throwing it at 10k
Old 02-24-2009, 01:38 AM   #12
old gsxr
Superbike Racer
old gsxr's Avatar
thaks for your advice fellas,and the video stephen much appreciated , i'll be doing some engine mods and swingarm ext soon , i'll be going all out when i get the chance to change to watercooled rods later but i'll post when i get the sucker down the track -ken
Old 02-27-2009, 11:25 PM   #13
Money shot
Motorcycle: K4 and K7 GSXR1000R's and a 2005 Velocity powered Hayabusa
I was wondering what was the 60 foot time on that pass. I just got a lock up for my K4 and in the process of getting it set up.
Money shot is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 02:32 PM   #14
gsxr boyz
Motorcycle: gixxer 1000
Hey dude i have a mtc stage2 and i cant get it to work right.Im riding a 04 gsxr 1000,when i make a pass it spins comming out the hole and clutch slips in second and third.What do u think is going wrong,also are u using factory clutch fibers and springs?
gsxr boyz is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 07:54 PM   #15
d3coy
d3coy's Avatar
Motorcycle: 72" Black/Orange GSX-R 1000 K7
it could be a few things. your stack height is probably too low. if the gap between the lockup arms and the pressure plate is too much the lockup won't apply the correct to amount of pressure when the arms are fully extended.
d3coy is offline   Reply With Quote Quick reply to this message
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
