Spark Plugs??? (AND WHY YOU CHOSE THEM!) : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 11-10-2008, 06:36 PM   #1
SofaKingCooool_69
Well I've searched this for the past 2 hours and although much good information, can't really get a specific answer. I got a K4 600 that's got about 10K now and is starting to bog a bit more in all gears, but especially on take off. I'm 99% sure it's the plugs but am told by a few people to get the iridiums. Most of the searches say I used "this" plug or I used "that" plug and liked it, but my question is why? I'm not taking my bike to a track anytime soon due to money, I stunt alot, and only do occasional bursts maybe a few times a month, but mostly just cruise at 7-8K and shift between 6-10, so I think I'd be fine running just NGK that came from the factory.
Please don't respond with the iridium or NGK or etc. plug worked great. My question for everyone else is when you changed your plugs, why did you go with the specific brand or type that you put in your bike??? Maybe it was friends' reccomendation, power, mileage, long lasting? What was your reasoning for you buying your plug?
SofaKingCooool_69 is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 07:46 PM   #2
NoXi0uS
Motorcycle: Flat Black '05 GSX-R600
Re: Spark Plugs??? (AND WHY YOU CHOSE THEM!)
You will not notice any performance increase or anything, but I have used CR9 and CR8 NGK Iridiums and they run great: lasted for about 10,000 miles each before I notice the bike starts to bog a bit. I've got CR9EIX in right now and just recently changed them a few hundred miles ago. I only stuck with NGK because it said in the manual it was recommended. I didn't notice a difference between the CR8 or CR9 at all, but they are reliable imo.
NoXi0uS is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 08:09 PM   #3
Joe333x
Joe333x's Avatar
Motorcycle: 2005 GSX-R 600 converted to a 750
I just go to autozone and tell them I need plugs for and my bike they look up which ones it takes and I buy the NGK for probably 2 bucks a piece, never had a problem and since I change them every winter I see no reason to buy expensive plugs.
Joe333x is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 11:10 PM   #4
Jimmy 2 Times
Is Sexually Attracted To The Guys on GDC
Jimmy 2 Times's Avatar
Motorcycle: A 92 GT VFR
open up your manual, and replace them with what is in there. If you expect any change, you will be disappointed
Jimmy 2 Times is offline   Reply With Quote Quick reply to this message
Old 11-10-2008, 11:26 PM   #5
AndrewM
Superbike Champ
AndrewM's Avatar
Motorcycle: 06 750
i use the CR9EIX NGK Iridiums.... you're supposed to be able to switch them out less frequently than regular ones.... i switch them about every 10K
AndrewM is offline   Reply With Quote Quick reply to this message
Old 11-11-2008, 08:28 AM   #6
maxpat82
Expert Racer
Motorcycle: street:05 DRZ400SM track:05 600 fun:03 XR100
I'ved used only stock replacement.
and change them at 15K whitout any almost any change.
maxpat82 is offline   Reply With Quote Quick reply to this message
Old 11-11-2008, 11:02 AM   #7
rob350
im running NGK cr9eix just put them in on sunday as i hit the 10k mark
rob350 is offline   Reply With Quote Quick reply to this message
Old 11-11-2008, 12:07 PM   #8
nitrous36
Taught Goatsee everything he "knows"
nitrous36's Avatar
Motorcycle: K4 GSXR 600
NGK makes pretty good plugs. And thats what I will be using when I change the plugs. Its approaching 10K.
nitrous36 is offline   Reply With Quote Quick reply to this message
Old 11-11-2008, 01:57 PM   #9
MikeHump
Looking for fat chicks for long walks, romance and ballast
MikeHump's Avatar
Motorcycle: 2007 GSX-R600
I change mine out with stock replacement, at the intervals recommended in the service/owner's manual; approximately every 7,500 miles.
MikeHump is offline   Reply With Quote Quick reply to this message
Old 11-11-2008, 06:07 PM   #10
SofaKingCooool_69
Ok well thanks for all the info, seems everyone in here runs NGK, some with what the book recommends and some running iridiums.
My view is a regular plug costs about $2-3 a pop and lasts 7500 miles. The iridium a bit more probably and 10K miles, but either way everyone is running NGK so I got my answer, I'll just do the stock version and of it and since no really changes other than a bit longer life, that's an easy decision, thanks everyone.
Old 11-13-2008, 09:55 AM   #11
05gixxerjockey
Sphincter Pincher
05gixxerjockey's Avatar
CR9EK's for no other reason than longer change interval.
05gixxerjockey is offline   Reply With Quote Quick reply to this message
Old 11-13-2008, 12:21 PM   #12
jermag24
jermag24's Avatar
I use NGK on all of my vehicles because they are dependable. I had Bosch Platinum's in my wife's Camry, and in less than 5k miles the engine started to miss. One of the plugs was firing intermittently. Put NGK's in, still going strong 23k miles later.
Had a Champion spark plug stop firing completely in my XR400 dirt bike, after only 3 or 4 rides. Have had an NGK in it all summer with no issues. Iridiums are nice, but not worth the money IMO, so I just go with the NGK version of the OEM plug.
jermag24 is offline   Reply With Quote Quick reply to this message
Old 11-23-2008, 09:29 AM   #13
Illusionzx
ngk cr9e, don't spring for the iridums, it is not worth it for them.
Illusionzx is offline   Reply With Quote Quick reply to this message
Real Name
What is your real name?
Search this Thread:
Advanced Search
