Corbin Pacific Inc.
Soupy's PerformanceDel Amo MotorsportsBikeBanditDennisKirkGixxer Boys1CarbonTech.comLevel One RacingCycleGear.comBazzaz Performance2 Wheel KitsMotorcycle.com Classifieds!Advertise With Us
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > General Discussion > Non-Motorcycle Forums > Health & Fitness
Please Visit our Site Sponsors Page
Old 10-01-2008, 10:56 AM   #1
OlDirtyRobb
OlDirtyRobb's Avatar
Motorcycle: 06 1000
Pec Deck is bad
So Mens Health says pec deck is bad, which sucks cuz I use that at least once a week. Actually I use all 3 of those machines :P
So whats a good alternative to pec deck? Are cable crossovers ok? Its the same kind of motion?
OlDirtyRobb is offline   Reply With Quote
Old 10-01-2008, 02:38 PM   #2
RPG76
Motorcycle: 05 GSXR750
Re: Pec Deck is bad
Other than flys just with the dumbell, one of my old faves was to put a bench in the middle of the cable cross rig. Then with the cables in the lowest position and me, back down on the bench do a cable fly. Advantages: forces you to keep better form than just standing cable crosses or flys, ie. no leg or back movement. Gives a better burn right at the top as your still fighting the weight on the cables, unlike when you use bumbells. Disavantages: Little hard to keep good form at first ie. arms moving around and/or not following the whole movement smoothly. Not sure how well this works the muscle in the lower part of the movement as compared to dumbells.
You can change it up a bit by using an incline or decline bench as well. Give it a shot.
RPG76 is offline   Reply With Quote
Old 10-01-2008, 03:25 PM   #3
gixx1000
gixx1000's Avatar
Motorcycle: 2001 GSX-R600 (sold), 2003 GSX-R1000, 2008 ZX-10R
Re: Pec Deck is bad
By "bad" do they mean unhealthy or ineffective? From my own experience, I don't think there's anything wrong with it, provided it's done correctly.
gixx1000 is offline   Reply With Quote
Old 10-01-2008, 04:25 PM   #4
wtchtwr
Motorcycle: wtchtwr
Re: Pec Deck is bad
I use the pec deck frequently - I alternate with cable fly - never had any problems...
wtchtwr is offline   Reply With Quote
Old 10-02-2008, 09:00 AM   #5
k6zook1k
Faps to Fantasy Football, and fails at that even
k6zook1k's Avatar
Motorcycle: Bugman approved k6 silver n grey gixxer thou
Re: Pec Deck is bad
a lot of the fitness magazines contradict each other, and even themselves. If its not hurting you.. and you like it, then keep doing it.
k6zook1k is offline   Reply With Quote
Old 10-02-2008, 09:31 AM   #6
MechaniX
MechaniX's Avatar
Motorcycle: Soozookee GSX-R 600 2k1
Re: Pec Deck is bad
Dumbell flyes are a good alternative, dips for lower pecks. I've read and heard many stories about the Pec Deck being bad and mostly that the machine places strain on the shoulder/rotator cuff. I never had any issues, I think that if you go heavy not to overextend on the negative, so basically stop at the 180 degree point.
MechaniX is offline   Reply With Quote
Old 10-03-2008, 01:23 PM   #7
Tractionless
Re: Pec Deck is bad
After ortho. shldr. surgery both the surgeon and the PT said no Pec. Deck. Any motion that closes up the shldr. joint will cause torn rotator cuffs etc. The surgeon also said painters who work over their head have problems with the rotator cuff. I do ZERO over the head work now, I won't let my hands get above my shldr.'s The joint just wasn't built for it.
Also no shldr. raises with hands very close together, keep them at shldr. width. No militaries, and when doing any fly's etc. I keep my elbow bent to keep the force down off the shldr. joint.
Keith
Tractionless
'00 GSXR 750 - Street
'05 GSXR 750 - Track
'01 GSXR 600 - CCS AM #12 SOLD!
'99 R6 - SOLD!
Toys Not Tots
Tractionless is offline   Reply With Quote
Old 10-04-2008, 11:00 AM   #8
matte220
matte220's Avatar
Motorcycle: 78 Kawi KZ650 (sold) 00 R1 (sold) 02 GSXR1000 (sold) 06 GSXR1000 (sold), 04 V-Rod (sold) 08 R1
Re: Pec Deck is bad
Mens Health sucks.....LOL Well ok, actually I think it really does.
Nothing wrong w/ a pec deck as it's a nice contraction exercise where you can really control the FEEL of the pecs.
matte220 is offline   Reply With Quote
Old 10-06-2008, 07:07 AM   #9
silversv1k
silversv1k's Avatar
Motorcycle: 2003 Suzuki SV1000s, 2004 Kawasaki ZX-10r
Re: Pec Deck is bad
agreed, when i use the pec deck machine i definitely feel a deep burn when i pause at the peak of the exercise and squeeze together! i also love that machine now because i also use it to smash the rear delts
silversv1k is offline   Reply With Quote
Old 10-06-2008, 08:24 AM   #10
mcdozer44
the gun show
mcdozer44's Avatar
Re: Pec Deck is bad
I also agree with silver. I've been a personal trainer for over 10 years and there is always contradictory advice given by different mags. The bottom line is FORM. A pec deck is effective and not harmful if used properly.
Tip 1, raise the seat up higher than you think is correct. This will bring your arms down below the line of your shoulders so you're not putting strain on your shoulders. Your hands should then be at a height about even with the bottom of your pecs.
Tip 2, don't stretch back further than what is comfortable for your shoulders. The exercise is most effective for the contraction of the pec which is when your hands are coming closer together, at the peak of contraction, not when you are stretched out. You don't need to go that far back.
Tip 3, slow and controlled. Keep the weight down, you don't need to go too heavy. An exercise that is aimed at peak contraction does not require a lot of weight. You may see the juice monsters going really heavy on this exercise..those are the guys who are going to cause damage to themselves. Breathe and make sure to get a good concentrated squeeze. Pause and hold for a moment at the peak contraction, then slowly return. You will feel strain on your shoulders when you go too heavy for yourself.
Tip 3, don't grasp the handles. Rather place the base of your palms against the handles. This can allow your arms to rotate slightly in their natural motion. Keep your elbows slightly bent.
Cable crossovers are great if done properly as well. Dumbell flys are also good, though at the peak of contraction when the dumbells are up, you're loosing resistance due to gravity. The resistance is down toward you instead of pushing your arms away from each other. I'm not saying to keep away from this exercise, just keep that in consideration. RPG's suggestion is a great exercise. My gym has a cable peck press machine where you're seated and I use this machine for crossover flys.
Men's health is aimed at the beginner/intermediate, so take their advice with a grain of salt. Be careful who you take advice from at the gym. Just because a guy is huge, doesn't mean he really knows what he's talking about. Steroids take the place of proper form.
Make it work or break it tryin'
mcdozer44 is offline   Reply With Quote
Old 10-06-2008, 05:49 PM   #11
phreak260
phreak260's Avatar
Motorcycle: nothing thanks to some white trash in an escort
Re: Pec Deck is bad
MOST IMPORTANT TIP OF ALL:
quit using machines and relying on them to "feel" your muscle doing the work. grab a set of dumbells, lie on either a flat or incline bench, and learn how to use your pecs to complete a flye. you will get more out of less.
brief, intense, and frequent training sessions using basic, free-weight movements will produce the best results. every time.
leave the machines for the old folks, chicks, and fairies.
ever notice how the machines are always being used and the free weights are almost always available? there's a reason for that.
people are pussies. don't be a pussy.
phreak260 is online now   Reply With Quote
Old 10-18-2008, 12:19 PM   #12
brienjen
brienjen's Avatar
Motorcycle: 92 seca 2 and k7 1000
Re: Pec Deck is bad
F... mens health.The pec deck is by no means bad in general.Just make sure YOUR getting progress from it...thats all.
brienjen is offline   Reply With Quote
Old 11-16-2008, 05:38 AM   #13
denso1
denso1's Avatar
Motorcycle: Black K8 600
Re: Pec Deck is bad
That's a sweet machine. We have one similar to it at the gym I go to.
denso1 is offline   Reply With Quote
vB code is On
Powered by vBadvanced CMPS v3.0 RC2
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
Copyright © 2008 — 2009 Gixxer.com
