r1/r6 shock fits a slabby???? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-24-2008, 01:23 PM   #1
bigbike-r
bigbike-r's Avatar
Motorcycle: GsxR 7/12 TT-F1, Kawasaki gpx750r rat fighter
keep seeing this question asked on various forums it gets asked and people get told yes - they think your lying so they go ask somewhere else so......
to answer the question
secure the bike so it wont topple over and remove the slabby shock
youll need the eye out the bottom mount of the shock so take out the retaining clip from either side
and press the eye out
a quick comparrison - this shock is an R6 2001 model
press the eye into the r6 shock
attatch the shock back to the bike - i did it fastening the top first
so does it fit
yes.........
the resevoir will forl the battery box so you will need to relocate the battery - i put mine under the tank in the recess the airbox would take up
you can put it wherever you please
si there you have it - yes it fits so stop asking
I pitty the fool, that don't ride oldskool
http://suzukigsx-ryoshimuratt-f1.blogspot.com
clicky the linky to folow my build
bigbike-r is offline   Reply With Quote
Old 08-24-2008, 02:04 PM   #2
Twokaotic
Motorcycle: 06 Hayabusa, 86 & 92 GSXR 750, 00 KTM 380
Re: r1/r6 shock fits a slabby????
Nice write up.
Couple of questions though...You didn't have to take anything off the R6 bottom eye? and, do you have any problems with the bike topping out (shock being too long)?
I used an R1 shock and had to take some material off the bottom eye to get it to fit in the slabby's linkage. And, the shock was just a hair too long and took some real wrestling to get the bottom bolt through. The extra length caused the bike to top out when unweighted.
I'm not doubting you...just trying to clear some things up.
Twokaotic is offline   Reply With Quote
Old 08-24-2008, 03:48 PM   #3
bigbike-r
bigbike-r's Avatar
ove not touched the r6 shock all ive done is pressed out the eye from the slabby shock and put it in the r6 one it is a wrestle to get the shock in but it does squeeze in but is fine once everything is bolted up
Old 08-26-2008, 02:12 PM   #4
GertRam
GertRam's Avatar
Motorcycle: GSXR 750 '87, GS 1000 '78, Triumph SuperIII '96, KTM GS 500 '87
I'm looking for a longer shock myself, surprised to see R1 and R6 are compatible.
Could you tell me the lenght of both of them and if they're any different in damping / spring rate? Thanks in advance.
GertRam is offline   Reply With Quote
Old 08-26-2008, 02:30 PM   #5
GixxerRacer371
Has been Texan longer than the cheerleader
GixxerRacer371's Avatar
Motorcycle: Son's 04 GSXR 600
GSXR 1100 shock length 315mm, shock stroke 69mm, spring rate 6.1kg/ mm
GSXR 750 shock length 290.5mm, shock stroke 61mm, spring rate ???kg/ mm
R1 shock length 300mm, shock stroke 65mm, spring rate 8.6kg/ mm
R6 shock length 300mm +/- 5mm depending on year, shock stroke 65mm, spring rate 9.8kg/ mm to 10.8kg/ mm depending on year....
GixxerRacer371 is offline   Reply With Quote
Old 08-26-2008, 06:11 PM   #6
86gixxxer
86gixxxer's Avatar
Motorcycle: first gen 750's & a '99 750
wow, according to this, i would venture to say that the R6's spring rate is probably close to double the stock first generation's spring rate.
bigbike, it fits, but how does it handle? i am curious.
86gixxxer is offline   Reply With Quote
Old 08-26-2008, 06:44 PM   #7
FruitLooPs
Motorcycle: 1986 GSXR750
I tell you getting that bottom bolt through is a royal prick with the R1 into my 87, I gave up trying it on my own it was just getting dangerous.
I tried jacks, weighting it attempted to get spring compressors in i got oh so close so many times.
I'll take another crack at it when I've got a helper, shouldn't put up too much of a fight. I didn't press out the eye on mine but shaved down the material like Twokaotic and then had my local machinist turn down the hardened bottom mount bush that came in the R1 shock to match the new width
it slips into the bike no worries, just getting the holes to line up however ... >.< grr
FruitLooPs is offline   Reply With Quote
Old 08-27-2008, 11:28 AM   #8
bigbike-r
bigbike-r's Avatar
its good better than the slabby one - easy to adjust to - at first it was too soft and was really digging the back end down on accelerarion - stiffened it up now and it feels great
Old 09-05-2008, 01:23 AM   #9
grub 750
grub 750's Avatar
Motorcycle: GSXR7/11 Streetfighter
What year model is the R6 shock ?, I've got a 85 mod slabby with a 90 mod swingarm, witch i'm using the slabby shock arm and I need the shock to be 295mm long from centre to centre bolt holes, do the different year mods of the R6 & R1 vary on length, and obvioulsly the shock has to have the resovior horizontaly mounted
grub 750 is offline   Reply With Quote
Old 09-05-2008, 01:56 AM   #10
bigbike-r
bigbike-r's Avatar
the resevoir is cast into the shock so it is that way and cant be moved - that shock is from a 2001 r6 i think r1 are longer slightly - 07 models deffinately are - was looking at my mates
Old 09-05-2008, 03:57 AM   #11
FruitLooPs
Well I got my R1 shock in, bolted up the bottom eyelet instead of the top then used a scissor jack upside down thru the frame to compress the shock and line up the top bolt.
talk about round about! worked though, and it feels great. Doesn't rub on the swingarm at all, though it is close (within 0.5cm). I'd love to try it out but I don't have an engine
Old 09-05-2008, 03:17 PM   #12
bigbike-r
bigbike-r's Avatar
ueah its a good battle getting the last mount in lol - i found it easier bottom first tbh then used a long rod of metal to force it down leverage and got the missus ti sharply throw the bolt through lol - it feels really nice though makes the stock one feel like youve been riding a hardtail
Old 09-05-2008, 07:40 PM   #13
NAJ2627
NAJ2627's Avatar
so that means it'll be softer?
please explain more of that, in plain english, maybe?
NAJ2627 is offline   Reply With Quote
Old 09-05-2008, 07:45 PM   #14
GixxerRacer371
no... it means it will be harder.
Old 09-05-2008, 08:12 PM   #15
NAJ2627
NAJ2627's Avatar
noted, thanks.
Old 09-06-2008, 01:49 AM   #16
bigbike-r
bigbike-r's Avatar
the r6 is deffinately bouncier than my old stock one - but then perhaps my stock one was broke - it was 23 years old afterall - i find the r6 a lot bouncier with a lot more adjustment to it - o feel waaaay less bumps in the road with it and it gives a better ride height too
Old 09-11-2008, 05:35 AM   #17
grub 750
grub 750's Avatar
yea thanx ,I found a list of the R1 &R6 shock length's whitch are
:R6 1999-2002 = 305mm
;R6 2003-2008 = 295mm
'R1 1998-2001 = 300mm
'R1 2002-2008 = 300mm
Old 02-01-2009, 05:17 AM   #18
DiscoDan
Originally Posted by Twokaotic View Post
Nice write up.
I'm seeing the same thing, the width of the R6 shock is 23 mm but the original is 22mm which is a snug fit into the bottom mounting yoke. I'll need to take off the 1mm if it has any chance of fitting.
I have to admit I'm more concerned about the shorter shock length; the R6 unit is 20mm short than the original. Whilsy I haven't measured what that translates to in ride-height yet I'm assuming it's going to lower things a fair bit. Has anyone who's done this mod got any comments on the ride height and ground clearance effects?
cheers
danny
DiscoDan is offline   Reply With Quote
Old 02-25-2009, 05:24 PM   #19
kevan750
Does anyone know the diameters of the Slabby Shock compared to the R1 (05) shock. Reason is, I now have a K3 1000 swingarm fitted (lots of modification) and need a new shock. Wondered if the diameter of the R1 is bigger than the original, and if so will it rub on the swing arm?
kevan750 is offline   Reply With Quote
Old 02-25-2009, 08:17 PM   #20
OldGSXR-N-TX
OldGSXR-N-TX's Avatar
Motorcycle: 1991 GSXR 750
I've got a 1991 750 and I'm currently looking for a new shock as well. I've heard that a 01 - 02 GSXR 1000 shock will work with minor alteration (ie battery box). I'm just wondering if it would be easier to fit the R1 or R6 shock. I've looked into rebuilding my stock shock and with everything that it needs it will run between $500 to $600 including shipping. I'm really looking for a good alternative.
OldGSXR-N-TX is offline   Reply With Quote
