bike died while riding just installed R-55 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 08-13-2008, 08:07 PM   #1
Pauluch
Motorcycle: GSXR 750 K8
Just installed my R-55.full system with pc3, I wa riding just now and the bike FI light came on the the engine shut off, I'm thinking the its the spark plugs, the pc3 was mapped for the bike, anyone have any idea what it could be other than the plugs?
Pauluch is offline   Reply With Quote
Old 08-13-2008, 08:21 PM   #2
THUNDERCAT
THUNDERCAT's Avatar
Motorcycle: K8 600 Black
Re: bike died while riding just installed R-55
This just happened once or a recurring problem ??( engine killing)
THUNDERCAT is offline   Reply With Quote
Old 08-13-2008, 08:22 PM   #3
THUNDERCAT
THUNDERCAT's Avatar
Did you get the map online or have custom tune done?
Old 08-13-2008, 08:25 PM   #4
Pauluch
Just happened for the first time, and I got the map online.
Old 08-13-2008, 09:08 PM   #5
Pauluch
Old 08-13-2008, 09:22 PM   #6
THUNDERCAT
THUNDERCAT's Avatar
I wouldn't sweat it if your bike killed once. Have you ridden the bike since?
Old 08-13-2008, 09:27 PM   #7
Pauluch
No it, won't start right now, I've tried. It's trying to turn over, but seems like its not getting a spark.
Old 08-13-2008, 09:39 PM   #8
THUNDERCAT
THUNDERCAT's Avatar
Could be a problem with the map or pcIII. Try disconnecting it and then try starting it. At least that will narrow it down a little
Old 08-13-2008, 09:42 PM   #9
Pauluch
Alright, I'll try that tonight it stillon the back of my buddies truck, had to a to stop for a drink snd watch the game after this.
Thanks for the help
Old 08-13-2008, 10:09 PM   #10
kyle4213
Motorcycle: 07 GSXR 600 blue/white
Yea try unplugging the pc3 and starting. If still nothing next thing to check would be your fuse. Just keep filling in and im sure your be able to troubleshoot the problem here.
kyle4213 is offline   Reply With Quote
Old 08-13-2008, 10:55 PM   #11
Pauluch
i checked all the connection, everything was perfect. pulling it off my buddies truck it started but while trying to ride up the driveway the engine cut out, re mapped the pc3 started fine, but is there something else that could be the cause here?
Old 08-13-2008, 11:22 PM   #12
almano
The Crazy Hungarian
almano's Avatar
Motorcycle: 2008 GSX-R 750
Check the TPS wire T-tap.
almano is offline   Reply With Quote
Old 08-14-2008, 12:13 AM   #13
kuruptracing
kuruptracing's Avatar
Motorcycle: 08 GSXR 750
did you do the SET valve uninstall? you pulled the #5 wire right?
put the plug in the o2 sensor?
yes, check tps wire...
go over all the injector connections...
kuruptracing is offline   Reply With Quote
Old 08-14-2008, 03:38 AM   #14
aussie lee
Motorcycle: K8 750 B/W
try unplugging p/c, replug original see if it at least starts !!!! only a thought..
aussie lee is offline   Reply With Quote
Old 08-14-2008, 07:56 AM   #15
Pauluch
i removed the set valve, pulled the #5 wire out, the o2 plug is disconnected, i went over every connection they are all secure.; the only connection i have yet to check is the tps wire tap. my other problem is my pc3 doesn't power up for mapping unless the bike is running. Even after connecting a 9volt battery to it, at first i thought i had a dead battery so i bought a brand new 9volt.
Old 08-14-2008, 07:58 AM   #16
Pauluch
the bike was running perfectly for about 30 mins. Then a cloud of smoke was blowing out of the pipe before it died on me, i'm thinking that was due to the bike running to rich?
Old 08-14-2008, 11:40 AM   #17
kuruptracing
Make sure you put the blank connector in the o2 sensor, although i'm sure that has nothing to do with it. The pc3 should only power up when you switch the bike to the on position. I'm not sure where you would have connected a 9v to it??? You don't have the battery cord attached to the pc3, while it's on the bike do you?
Ya sounds like it's running way too rich... I don't think it would be your TPS wire, though. Sounds like you either have the wrong map flooding the engine, or you have something that's not connected that should be...
Actually, bike sounds like it's being flooded. Probably the reason why it won't start afterwards. Either you don't have the right map correctly loaded and the pc3 is making it run extremely rich, or you changed the adjustment on the pc3. Once you have the correct map you won't need to adjust anything on the pc3...
Also, make sure there are not cuts into the wiring harness. They can also create a short. Go over all the wires and make sure they look ok. Tape them up if need be...
Old 08-14-2008, 12:43 PM   #18
rraiderr
Buys OG's Depends
rraiderr's Avatar
Motorcycle: 2012 1000
Make sure the correct set of injectors are connected.
rraiderr is online now   Reply With Quote
Old 08-14-2008, 01:33 PM   #19
Friettreffen
Motorcycle: GSX-R 750 K8 for the road, GSX-R 750 SRAD on the circuit
It's difficult to resolve this from a distance... I've installed my full system and pc3 and everything went great (without any experience!). I guess something isn't plugged in right but what...that's the question...!
Friettreffen is offline   Reply With Quote
Old 08-14-2008, 02:35 PM   #20
kuruptracing
If you went over and made sure everything was correctly installed including the map, then I bet its something with the wiring harness. It's either picking up interference or something is cut.
