PAIR Valve mod/remove : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 08-12-2008, 04:34 PM   #1
Cajun
Cajun's Avatar
Motorcycle: 2004 GSX-R 600, 2006 RSV-R 1000
The below pic is from the yoshimura site, with the yoshi 'Second Air Blind Plugs', i couldn't find anything like these in nz so used something else
picked up these bungs from para rubber, for $0.50c each, the pipe external diamater size is something around 12-13mm, they are hard plastic (eg things like bottom of steel chair legs)
Pretty simple job to do.
1) lift tank up
2) remove air box(1 bolt up front, 4 clamps holding on to throttle bodies, with 2 plugs and 3-4 hoses going in)
3) PAIR valve is a unit up front of frame, it has three hoses coming out of it, two top of cylinder head, one to air box.
4) Pull the plugs that go in to cylinder head(the one in airbox, already remove to get it out)
5) Plug the 1 holes, in the air box with the bung brought earlier.
6) Plug the 2 holes, in the top of cylinder with the bung brought earlyer. (1 & 2 in below pic)
You can stop here, or continue if you want to remove the PAIR valve totally, for this you will also need a resistor 18-22 Ohm, 5-10wat ($1 or so from Dick Smiths)
7) Remove the Pair valve (one bolt, and plug going in to it)
8) Put the resistor in the plug where pair was plugged in to. (above pic #3)
9) Turn bike on, make sure Fi light is not showing
10) Put bike back together and go riding.
With Pair valve is removed/disabled, this will stop your bike backfiring, lose about 2ish kgs of weight, and meant to give 1/2-1ish HP. The pair valve should be blocked before bike is dynoed.
2004 Suzuki GSX-R600K4 Yellow/Black
Full S/S Yoshimura shorten RS3 carbon, Yoshiumura Em-Pro ECU, BMC Race Filter, NYK Iridums, 520 Stealth & DID, Ohlins(front 25mm NIX/rear/damper) , Speedohealer, Rider Custom Seat, Driven Grips, Stomp Grip, R6 Throttle, R6 Calipers, Yoshi Rearsets, Pairvalve removed. Hugger, Undertail with build in signals, PP 2ct's, Yoshi Bar-ends, Yoshi quick shifter, Yoshi oil catch tank.Coming soon - Yoshi cams & pistons
Cajun is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 10:25 PM   #2
IllmicIll
Supersport Racer
IllmicIll's Avatar
Motorcycle: ill_sixR
Re: PAIR Valve mod/remove
nice... i will be doing this while I have my motor apart.
IllmicIll is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 10:29 PM   #3
Cajun
Cajun's Avatar
nice one, pretty simple mod.
the pair valve is useless since installed the Yoshi em-pro since it does not use it, and no more back firing thru the full system
Old 10-27-2008, 10:33 PM   #4
surreal5150
Has tiny penis.....still acts like a big dick.
Motorcycle: gsxr 600 k4 race / Ducati 1098r
Are those plugs heat resistant ???
Good find otherwise, looks very neat.
surreal5150 is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 02:23 AM   #5
Cajun
Cajun's Avatar
hard plastic, meh, heat be fine, might cause a problem when hot, but i got a spare cam cover.
But best to find thsoe plug things like i put in the first post, thats what the yoshimura use
Old 11-01-2008, 08:50 PM   #6
Joe333x
Joe333x's Avatar
Motorcycle: 2005 GSX-R 600 converted to a 750
I did this mod recently because I swapped out my 600 for a 750 and the 600 pair valve hoses don't line up with the 750 engine, I just went to auto zone and in the radiator aisle they have radiator rubber hose caps, I think that they will be able to hold up with the heat.
Joe333x is offline   Reply With Quote Quick reply to this message
Old 11-01-2008, 10:27 PM   #7
surreal5150
Did you guys notice any difference to exhaust sound ???
The 1-2hp is a bonus but not real noticable.
Being that the cases are now in vacuum does the engine rev more freely or noticably.
I never bothered with this mod, It was always at the back of my mind to do , but never did.
Now with a new bike to play with , i'll have time to do some more tinkering on the 600.
Old 11-02-2008, 01:17 AM   #8
Cajun
Cajun's Avatar
nah no real notice with exhaust sound that i remember, didn't help i installed a em-pro at the same, and removed pc3.
only thing i noticed was no more backfiring
Old 02-22-2009, 11:42 AM   #9
tpham86
i cant find an 18-22 ohm 5-10 watt resistor for the life of me! are you sure this is correct?
tpham86 is offline   Reply With Quote Quick reply to this message
Old 02-22-2009, 11:49 AM   #10
Cajun
Cajun's Avatar
not looking very hard go to radio shack or somewhere.
Old 02-22-2009, 01:20 PM   #11
tpham86
i went there, the closest thing they had was a 10watt 10ohm resistor
Old 02-23-2009, 05:49 PM   #12
KuleZero
Motorcycle: '04 600
Here you go
http://www.unicornelex.com/detail.ph...ba8a7f4d7b86b1
KuleZero is offline   Reply With Quote Quick reply to this message
Old 02-23-2009, 10:51 PM   #13
MPA
MPA's Avatar
Motorcycle: '09 ZX6R
Thanks for posting this - I bought some pair block off plates and didn't realize I'd need a resistor.
MPA is offline   Reply With Quote Quick reply to this message
Old 02-24-2009, 12:13 AM   #14
Cajun
Cajun's Avatar
don't really need plates, only need resistor if plan on total removing the pair vavle unit
you can just disconnect the pair vavle pipes, so no need on the resistor
Old 02-24-2009, 11:03 AM   #15
IllmicIll
Supersport Racer
IllmicIll's Avatar
you can get those pink plugs from suzuki.
part # is 13859-41B10
Old 02-24-2009, 11:15 AM   #16
subee13
subee13's Avatar
You are awesome. I have been trying to find the plugs that I can clamp on. How many will I need? 3 right?
subee13 is offline   Reply With Quote Quick reply to this message
Old 02-24-2009, 12:48 PM   #17
Cajun
Cajun's Avatar
yep 3, two for top of engine 1 for airbox
Old 02-24-2009, 03:10 PM   #18
IllmicIll
Supersport Racer
IllmicIll's Avatar
yep 3... it doesnt come with those whack clips though. I just safety wired mine.
Old 03-18-2009, 01:30 PM   #19
OttawaGixxerMark
OttawaGixxerMark's Avatar
I couldnt find any plugs around to fit..so I just filled the holes with epoxy!
OttawaGixxerMark is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 05:32 AM   #20
flufferguy
Rusty Trumpeter
flufferguy's Avatar
Motorcycle: 2005 GSXR 600
thats this one right?
http://www.ronayers.com/Search/N/687...1B10/Source/SU
flufferguy is offline   Reply With Quote Quick reply to this message
Real Name
What is your real name?
Search this Thread:
Advanced Search
