CAMs MUST READ! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 08-06-2008, 04:22 PM   #1
GIXXER THE KID
GIXXER THE KID's Avatar
Motorcycle: GIXXER THE KID
CAMs MUST READ!
I'm fresh off the phone with Web and KWS and here is the skinny.
01-06 gsxr1000 intake cam have the same pin location
07-08 1000 cam pin location is different
01-05 gsxr 750 have the same pin location and its the same as the 01-06 1000
06-08 gsxr 750 have the cam pin in a different location. Its in the middle of the cam. Forgot to ask if its the same as the 07-08 1000
so if you have a 01-05 750 you can use the 01-06 1000 intake cam
GIXXER THE KID is online now   Reply With Quote
Old 08-10-2008, 08:01 PM   #2
brooksie69
Re: CAMs MUST READ!
What would you gain by fitting 1000 inlet cams to a 750?
Are the cam profiles different between the two or is it just the same cam fitted to two different models?
brooksie69 is offline   Reply With Quote
Old 08-11-2008, 07:31 PM   #3
GSXR6BOY
Can Never Be Another GDC
GSXR6BOY's Avatar
Motorcycle: 05 GSXR 600 Ann.
Re: CAMs MUST READ!
I have the 06 1000 cams in my 05 750, no issues
GSXR6BOY is offline   Reply With Quote
Old 08-12-2008, 04:24 AM   #4
GIXXER THE KID
Re: CAMs MUST READ!
the 06 1000 has the same pin location as the 05 750 as stated above if the first post. yes it will work.
Old 08-12-2008, 01:05 PM   #5
GSXR6BOY
GSXR6BOY's Avatar
Re: CAMs MUST READ!
I know
Old 08-13-2008, 10:08 AM   #6
Illusionzx
Re: CAMs MUST READ!
i have yet to see dyno sheets proving gains from the cams...maybe they are around, but nobody posted them.
Illusionzx is offline   Reply With Quote
Old 08-13-2008, 04:40 PM   #7
GIXXER THE KID
Re: CAMs MUST READ!
I had a whole bunch on here years ago. I'm sure they are gone by now. Dont have those dyno runs on my computer anymore an it's been years ago. You wont see much gains on the 05-08 1000 and I'm sure no one will posted them as they dont gain much from cams as those motors are really just cammed out 01-04 1000. Busas and 750 you will see the most gains from. A busa can put up 15hp from cams very easy. Did you know the exhaust cam on a busa has less lift then the stock 750 exhaust cam?? yes in deed
The 1000, there is not much to be gained but you do get some thing from a set of cams it wont be anywhere the types of gains a busa cam gets. They have big cams already. More lift the a stock Busas.
why do you think a 05-08 1000 make about 10 to 15 more hp then the 01-04 1000..? Bore is only .5mm bigger. that wont do it! it's the cams and the head man.
the 750s, well there is afew people that has cams in there bikes. Most dont spend the money on motor stuff as 1000 bucks can get you a 1000 motor.. or they dont have the know how to install the cams and dont want to pay some one to do it for them. Cams are expensive for sure and then you have to pay some one to put them in for you if you dont know how to do it. Then you still get beat up by the 1000 so whats the point?? thats how most people see it. But I did 3 02 750 and every one of them made over 13 hp more dynoed a week apart before and after the cams. Don't believe me?? call my dyno guy and ask him Rayn Schnitz at shnitz racing. he will still have the dyno charts from the 750s I have dynoed.
136hp on a 02 gsxr750
138hp 02 gsxr750
143hp gsxr 750 with a 2mm overbore
BryGuy
Old 08-13-2008, 08:00 PM   #8
RPG76
Motorcycle: 05 GSXR750
Re: CAMs MUST READ!
What did the graphs look like before and after? ie. on the 750, did it kill the low end to make gains on the top, did it enhance the mid and the top? Would like to know more, thanks.
RPG76 is offline   Reply With Quote
Old 08-13-2008, 09:15 PM   #9
Cajun
Cajun's Avatar
Motorcycle: 2004 GSX-R 600, 2006 RSV-R 1000
Re: CAMs MUST READ!
anyone know how you can read cams
aka i have a gsxr 600 engine sitting in my garage meant to have yoshi cams, how am i meant to know they are yoshi cams not just standard cams?
Cajun is offline   Reply With Quote
Old 08-14-2008, 03:48 AM   #10
GIXXER THE KID
Re: CAMs MUST READ!
there was a gain from 5,000 and up. mainly top end. but I used a small intake cam. with a bigger intake cam there would be more of a gain in the mid and lowend as well.
Old 08-14-2008, 03:04 PM   #11
RPG76
Re: CAMs MUST READ!
But did the bike loose anything, hurt driveablity at some spots? Buy bigger cams do you mean a 2007 GSXR 1000 intake cam or Yoshi?
Sorry I'm just trying to wrap my head around what this mod would do, thanks.
Old 08-14-2008, 03:19 PM   #12
maKe|
maKe|'s Avatar
Motorcycle: GSX-R 600 K6
Re: CAMs MUST READ!
Yoshi's have stamped Logos and cam infos on theyre camshafts.
Check this out:
http://www.yoshimura-rd.com/Video/Ca...haft_HD_2.html
maKe| is offline   Reply With Quote
Old 08-14-2008, 03:36 PM   #13
Cajun
Cajun's Avatar
Re: CAMs MUST READ!
Check this out:
cheers i have to pull the ones out of blown engine i got, and have a look
Old 08-14-2008, 03:36 PM   #14
GIXXER THE KID
Re: CAMs MUST READ!
the cams I used- did hurt the low end some. Below 5,000rpms. Anything above 5,000 had more power. Hit 7,000 and thing would just go!
I used an 02 gsxr 1000 intake cam. That cam is only about .008 more lift then the stock 750 intake cam and I went big on the exhaust cam. If you go with a bigger intake cam it wont hurt the low end at all and you will gain everywhere. At the time- the only bigger intake cam would have been a web cam witch cost money. Now you have more cams to chose from with the 05-06 gsxr 1000 having a bigger intake cam.
there is mostly always some tried off with putting new cams in a motor. where it be low end power or high end power. You can get both, but your not going to get big HP numbers that way. Depends on what you do with the bike I guess.
A road race bike you want a big intake cam and a mild exhaust cam for good mid range power.
A drag bike you want more top end power so you want a mild intake cam and a big exhaust cam. Moves the torque higher in the rpms witch makes more HP.
My set up was for drag racing and cost. The bike with a good ride would go high 9s in the 1/4 @ 142 mph with a 190pound rider. with a pro rider it could go low to mid 9s for sure.
I hope this answers your questions. anymore question call Ryan Schnitz at schnitz racing around 11:00am when he takes tech calls. He rode the bike before and did all the dyno runs. I'm sure he still has the graphs on file.
PS. the 750s that I did the swap in, where never my bikes. I have always owned a 1000. so I cant tell you how the bike felt before the swap. All I know is that it was like riding a 1000 in the upper rpms. I was really impressed riding it after the swap. And the guy that drag raced it beat up on alot of Busas down at the track. He was riding 9.7s and motor with it stretched and he is not a pro by any means.
the owners did say it lost alittle lowend below 5,000 rpms but it wasn't that bad.
After leting another 750 owner here in town ride the bike, he went right out and bought a set of cams to have me put them in his bike. He was impressed also
here is one of the old post I had posted back in the day after the swap. There should be afew more post on here to. Try searching in the Y2K gixxers and beyond forum
http://www.gixxer.com/forums/showthread.php?t=43375
BryGuy
Old 08-19-2008, 09:39 PM   #15
GSXR6BOY
GSXR6BOY's Avatar
Re: CAMs MUST READ!
It is an accel line, but here is the proof lol. Balls to the walls after 5k
Slashed lines are stock cams
Solid lines are 06 1000 cams
Both lines are with eall other mods, just different cams. The new line is before I really got into tuning as well, so A/F ratio was not 100% ideal. The curve is even better then this now (I'll see if I can find or make a new line)
Old 10-08-2008, 01:00 AM   #16
scrapiron828
Re: CAMs MUST READ!
Does this mean that I can get better performance out of my 2002 gsxr 1000 with cams out of an 2005-2006? Will they fit directly in my bike?
scrapiron828 is offline   Reply With Quote
Old 10-08-2008, 08:54 AM   #17
Luttersj
Luttersj's Avatar
Motorcycle: Race: '04 GSXR600
Re: CAMs MUST READ!
Does that apply to the 600 motor, too?
Luttersj is offline   Reply With Quote
Old 10-18-2009, 12:20 AM   #18
BarracudaBoy
BarracudaBoy's Avatar
Motorcycle: 1986 1100 GSX-R
Re: CAMs MUST READ!
Ok, I've done some reading on this cam swap business and I'm just about sold on it. (especially after seeing prices of the yosh cams. Yikes!) I have a 2005 750.
But I want to be crystal clear before I try this. So I have A few questions about this. I hope that you guys will help me out on.
I'm reading that the intake from a 05-06 1000 is the best year to drop into my bike?
How about the indexing of the cams?
Is my assumption of being able to just drop the 1000 intake cam in and lining up the index marks and running it correct?
In moving my intake to the exhaust side, what is the procedure for indexing it? Having the mark 180 out?
I have no desire to smack valves off piston heads. I’ve done that when the timing chain jumped on my 70 cuda. What a mess!
Thanks for tolerating my noobness.
BarracudaBoy is offline   Reply With Quote
Old 04-21-2010, 09:42 AM   #19
pafundi
Re: CAMs MUST READ!
barrracudaboy you need to get adjustable cam sprockets and have them degreed in and check the clearances. get a thin head gasket while your at it and a manual cam chain tensioner.
pafundi is offline   Reply With Quote
Old 12-11-2012, 08:12 PM   #20
campbell45
Re: CAMs MUST READ!
So I'm still confused about this. Can you swap in 750 or 1000 cams into a 600?
campbell45 is offline   Reply With Quote
