08 750 rear preload : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 06-25-2008, 01:59 PM   #1
GIX-600
08 750 rear preload
Could someone who haven´t adjust preload measure how much is thread showing at rear shock with stock settings?
I´ll messed up mine and i want to know what was stock setting.
GIX-600 is offline   Reply With Quote
Old 06-25-2008, 02:21 PM   #2
rraiderr
Buys OG's Depends
rraiderr's Avatar
Motorcycle: 2012 1000
Re: 08 750 rear preload
Stock is not relevant as it needs to set to you on the bike in full gear.
If you are going to take the time to set it back instead use that time to set your sag.
You do not need to go back to stock to set your sag.
rraiderr is offline   Reply With Quote
Old 06-25-2008, 02:51 PM   #3
FuhQ
FuhQ's Avatar
Motorcycle: K8 GSXR750
Recommended preload is 8mm of thread showing. Stock is about 4mm.
FuhQ is offline   Reply With Quote
Old 06-25-2008, 03:12 PM   #4
GIX-600
Where did you get that recommended 8mm?
Old 06-25-2008, 03:48 PM   #5
harada
harada's Avatar
owner's manual should be able to guide you back to the original setting
harada is offline   Reply With Quote
Old 06-25-2008, 08:24 PM   #6
rraiderr
Buys OG's Depends
rraiderr's Avatar
No such thing as recommended spring preload.
Again this is determined by your body weight on the bike.
You cannot use another persons settings unless you have an identical twin and share a bike.
