600 SRAD - cuts out with new Rectifier : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 05-23-2008, 11:37 AM   #1
Dbl-R
Dbl-R's Avatar
Motorcycle: 98 600 SRAD F/R Sprockets, Full Yoshi Exhaust, Jetted, Braided Breaks, RaceTech Front, Awkward Side Damper, and a few Custom Scratches.
Just replaced the rectifier, and still it cuts out on me. Looked at the plug from the wiring harness and its fine. The bike did go down once, and since then its been an issue, not consistent, just random acts of shutting down or sounding like a Diesel or a sound that you might get when a engine runs on 3 cylinders. Any ideas would help. Thank-you.
Dbl-R is offline   Reply With Quote
Old 05-23-2008, 12:43 PM   #2
Lean With It
Superbike Champ
Lean With It's Avatar
Motorcycle: 1999 GSXR 750 F.I.(modded - street/track) - 1997 GSXR 600 race bike (modded)
Re: 600 SRAD - cuts out with new Rectifier
how hard did it go down?
might be:
SIMPLE -
- loose kickstand
NOT SIMPLE -
cam chain tensioner
clogged fuel injector (if you are FI)
sticky / dirty carbs (if you are carbed)
tip sensor may be faulty
the fall may have let loose some gunk in your fuel path...check everything.
or perhaps your piston rings have gone bad.
mine is in the shop for the same reason
Lean With It is offline   Reply With Quote
Old 05-23-2008, 03:54 PM   #3
Dbl-R
Dbl-R's Avatar
cool thanks man, i'll look into all that.
it was low speed endo/crash.
the funny thing is that it runs fine (10min - well over an hour) and then out of the blue it will start stalling out. i wait a few min and then ride for another 30min. then stalls out again, after that it need a good hour cool down. dont know what to say.
Old 05-23-2008, 03:56 PM   #4
Dbl-R
Dbl-R's Avatar
btw its carbed
Old 05-24-2008, 07:29 AM   #5
jermattak
Superbike Champ
jermattak's Avatar
Motorcycle: 05 GSXR 1000, 05 KX250f, PW80
look at the sticky in this forum about cam chain tensioners, that might be your problem if it sounds like a diesel motor
jermattak is offline   Reply With Quote
Old 05-24-2008, 05:13 PM   #6
Dbl-R
Dbl-R's Avatar
if its the cam chain tensioners, would it happen all the time, not just randomly. cuz it runs super smooth for some time and then it cut out/starts stalling out.
hmmm....
but i will look into that, thanks.
Old 05-25-2008, 01:02 PM   #7
Dbl-R
Dbl-R's Avatar
talked to my friend about it and he says it sounds more like a twin not a diesel. if that helps.
Old 05-27-2008, 10:34 AM   #8
Dbl-R
Dbl-R's Avatar
i changed the CDI, we will see what happens. keep your fingers and toes crossed.
