Lightest tires for 1K???? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 04-28-2008, 11:35 PM   #1
adam_sean
adam_sean's Avatar
What are the lightest tires in the stock size for a GSXR-1000? It is time for tires and I am on the street, not the track. I live in Florida so turns aren't super important but rotating mass is!
adam_sean is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 05:07 AM   #2
COMEBACK
Superbike Racer
COMEBACK's Avatar
Motorcycle: K5 & 07 750 race bikes and 08 Honda CBR1000RR
Re: Lightest tires for 1K????
..................get some lighter wheels instead
COMEBACK is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 05:16 AM   #3
therock2689
therock2689's Avatar
Motorcycle: 98 GSX-R 750 SRAD
Ummmm, what??? IF i where to guess, i would say the narrowest tire you could fit on the rim(170 maybe) and with the least tread on it. This seems like a strange Q.
I dont think anyone weighs the tires. I think the weight of the tires in the same size are more or less the same. I also live in Fl and got some 2ct's. And if you think there no good roads in FL, you should look a little harder, i find them just fine.
therock2689 is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 05:24 AM   #4
gsxr movistar
gsxr movistar's Avatar
Motorcycle: gsxr1000k6 & gsxr600k2 telefonica
fill them with helium.
gsxr movistar is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 05:25 AM   #5
gsxr movistar
+1
or wave discs
Old 04-29-2008, 10:12 AM   #6
Palomartian
Palomartian's Avatar
Motorcycle: 05 KLX 110
Dunlops tend to be the heaviest. Pirellis are light. There is significant difference in tire weight. See if you can find one of the old posts where someone put up a copy of a tire review. Might have the weight of the tires in it.
Palomartian is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 10:18 AM   #7
Land-Shark
Land-Shark's Avatar
Motorcycle: 07 1k track,09 R6 track, Wifes 07-600 track
Use some 180/55 SC pros. They are going to work better than a 190/50 and be lighter as well. While Pirelli doesn't publish street tire weight the DC3 is heavy enough to be felt when holding them with a SC Pro. Also a set of take offs will be even lighter since the side rubber will be less.
Land-Shark is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 11:14 AM   #8
Why are you concerned then if it is as you say, for the street and riding in straight lines? If anything, lighter weight tires would be a bigger concern for someone that needs to corner better.
SPL170db is online now   Reply With Quote Quick reply to this message
Old 04-29-2008, 09:40 PM   #9
georgewa
georgewa's Avatar
Motorcycle: K5 GSX1000R 00 TL1000R 96 FZR
IF you're not carving much, go with some SC2/3 Take-offs, much cheaper than new and will last just about as long and will be lighter for sure. I always run take-offs on the commuter...
georgewa is offline   Reply With Quote Quick reply to this message
Old 04-29-2008, 11:36 PM   #10
Stocky
Stocky's Avatar
Motorcycle: GSXR1000 K2
There is good science in this.
Light weight wheels make a significant difference to a bikes acceleration.
One of the reasons the BST's are so good is not just that they are light but the rim is light (where another wheel may be nearly as light but it's heavier in the rim and lighter in the hub)
The light rim is better as it makes more difference to the moment of inertia.
In simple terms, the further from the axle the weight is the more effort required to get it spinning.
This makes the tyres even more important.
The tyre is even further away from the center of the wheel so any weight reduction is even more significant than the wheel.
Obviously there needs to be a decent amount of weight difference but I'd be interested to see if some tyres are significantly lighter than others.
Dirty old K2 1000
Stocky is offline   Reply With Quote Quick reply to this message
Old 04-30-2008, 05:11 AM   #11
adam_sean
adam_sean's Avatar
It is nice to see an intelligent response. Moment of inertia is critical to acceleration. Rotational mass is more important than static mass and yes the farther from the center of rotation, the more critical. Also, tires don't all weight the same, I just don't have the resources to purchase numerous sets and put them on a scale. I don't want take offs so that is out. Wheels might come later but right now, I am a couple of rides from needing a new set of buns and thought that for the street, in my part of Florida (or my riding style), the actual compound / brand is not as important to me as weight of the tire. About 10 years ago when I was just getting started with sport bikes (900RR when it was new and fast not a stunta byke) Pilots were over a pound less than the competition for both front and rear. That is two pounds of rotating mass that is way out from the center.
Old 04-30-2008, 05:14 AM   #12
Stocky
Stocky's Avatar
Someone must have weighed some tyres somewhere along the line
Old 04-30-2008, 12:23 PM   #13
jimpittsburgh
When Sport Rider Mag does a review, they list weights, also the European Mags ( BIKE, Superbike etc )that do tire reviews list the weights also...
jimpittsburgh is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 05:29 PM   #14
R-1000
Motorcycle: 06 ZUK 1000
The lightest street tire I know of the Pilot Power 180-55-17 which
is 12lbs 2oz front is 9.0lbs stock is 13.8lbs rear and 8.5lbs front but
total saving would be less than a pound complete.
Take care.
R-1000 is offline   Reply With Quote Quick reply to this message
Old 05-10-2008, 10:04 AM   #15
adam_sean
adam_sean's Avatar
can someone send me a link to a test that shows mounted diameter and weight for all the common sport bike tires?
Old 05-10-2008, 10:47 AM   #16
Peter3746Gixxer
Peter3746Gixxer's Avatar
Motorcycle: 2005 GSXR 1000
Did you mean to write Wheels....not Tires??? thats at least what i hope you did
Peter3746Gixxer is offline   Reply With Quote Quick reply to this message
Old 05-10-2008, 10:48 AM   #17
Jaeson
Motorcycle: The only KFC race replica with Gold Galespeeds. They call me "Chicken Run"
Pirelli's are light. About every other tire change or so i get a pirelli that is light and balanced perfectly. NO weights on the wheel looks good too.
Jaeson is offline   Reply With Quote Quick reply to this message
Old 05-11-2008, 05:19 PM   #18
adam_sean
adam_sean's Avatar
Nope, I mean tires. Why is that so hard to believe?
I don't need to buy wheels now but I do need tires soon. I said screw it and bought a scale ($60 at BBB). The local dealership has 5 brands in my size. I am going to have them weighed. I will post results.
Old 05-11-2008, 05:37 PM   #19
Anthony D
Super Pipe-Laying Moderator
Anthony D's Avatar
Motorcycle: None currently...
hold on, i have an old sportrider here that did this...
Anthony D is online now   Reply With Quote Quick reply to this message
Old 05-11-2008, 05:41 PM   #20
Anthony D
Anthony D's Avatar
ok, the lightest front tire is the bridgestone bt-014 at 8.51lbs.
the lightest rear tire in a 190 width is the pirelli diablo at 12.78lbs.
the lightest matching set of tires is the pirelli diablo at 21.68lbs. total.
Search this Thread:
Advanced Search
