1st gear Clunk! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 04-18-2008, 08:21 AM   #1
BackOn2Wheels
BackOn2Wheels's Avatar
Motorcycle: 04 1k Mladin Rep
1st gear Clunk!
I have been getting really hard shifts into first from neutral when first starting my bike and sometimes at stoplights. It doesnt happen in any other gear...just 1st.
It has been so bad that I have been starting her in 1st to avoid the hard shifts! This works ok but is a pain to wait for the bike to warm up whil holding the clutch in.
As far as I know the clutch is stock and there is only 6500miles on the bike. I bought the bike a year ago (haven't ridden it much since) and this issues is gradually getting worse. Bike is an 04 1k.
My clutch is a pretty hard pull so I took it to the local Suzuk shop and one of the techs adjusted the clutch and lubed the cable. This did not help so much.
Any thoughts?
BackOn2Wheels is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 08:27 AM   #2
Land-Shark
Land-Shark's Avatar
Motorcycle: 07 1k track,09 R6 track, Wifes 07-600 track
Re: 1st gear Clunk!
What is the idle? Also are you bliping the throttle before you shift out of neutral. If so the trans shafts are still spinning and that is causing the clunk.
Land-Shark is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 08:35 AM   #3
Carnage
Embed? Fuck off,I aint embeddin' shit
Carnage's Avatar
Motorcycle: ALL SOLD:Racebike included
Re: 1st gear Clunk!
Yeah...make sure your idle is not too high and change your oil. A little "clunk" going do into first from neutral is perfectly normal though.
Carnage is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 08:36 AM   #4
BackOn2Wheels
Re: 1st gear Clunk!
Idle was seriously low @ ~800rpm so I bumped it up to just over 1100. It was stalling at hard stops and this stopped it.
As for any throttle when starting it....no...and this also happens at stoplights sometimes.
Old 04-18-2008, 08:40 AM   #5
BackOn2Wheels
Re: 1st gear Clunk!
The clunk is seriously rough at times! Not the normal clunk I've experienced with my bikes over the years.
One other thing I noticed is that sometimes when I start up in first gear now the bike has an extremely slight movement forward like it was thinking of getting up and going...even though I have the clutch pulled to the bars.
Old 04-18-2008, 08:49 AM   #6
Carnage
Carnage's Avatar
Re: 1st gear Clunk!
That means your clutch is never completely disengaged which of course would explain that abnormal clunk. It most likely just needs to be adjusted. I can't remember if that 04 1k had a cable actuated clutch or a hydro cluth. I'm pretty sure it's a cable one and you'll just need to adjust it until the bike no longer creeps forward while in gear.
Old 04-18-2008, 08:51 AM   #7
Land-Shark
Land-Shark's Avatar
Re: 1st gear Clunk!
Well it is an 04 so hows the clutch adjustment? Perhaps you can tighten it up some.
Old 04-18-2008, 09:06 AM   #8
BackOn2Wheels
Re: 1st gear Clunk!
Ive adjusted it at the Pazzo lever and so did the Suzuki tech at the shop that also adjusted it. Didnt help any. I dont know if there is any other adjustment that can be made. There is absolutely no slack in the clutch lever...it is adjusted all the way out so it will surely engage the clutch all the way (or so I would think)
The bike doesnt always try to creep forward when put in first gear....seems like it only when I first start the bike when its cold.
Old 04-18-2008, 10:37 AM   #9
Palomartian
Palomartian's Avatar
Motorcycle: 05 KLX 110
Re: 1st gear Clunk!
Just hold the clutch in for a second or two before you shift into first. This will let the tranny spin down and it should drop right in. There is a window you need to find. Too short and clunk, too long and it won't go into gear if the shafts are completely stopped. If hold the clutch in for a long time (more than 10 seconds) does not stop the clunk then yes, you have issues with it fully disengaging. If the clutch adjustment is even close, it's likely something else. Try a different oil, take the fibers out and clean them with Berrymans, live with it...
Palomartian is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 11:30 AM   #10
IndiGIXXER
Turd Burgler or Twat Waffle...your call.
IndiGIXXER's Avatar
Motorcycle: 2003 GSXR 600
Re: 1st gear Clunk!
Your Suzuki technician sucks! Go somewhere else!!!!!! He should be able to properly adjust the clutch or tell you if you have a problem with it.
Bike pulling in neutral is definitely a clutch related problem. Fix it soon or you're gonna burn your clutch plates (way more expansive fix than adjusting a clutch).
IndiGIXXER is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 11:41 AM   #11
oldfart01
is actually Fab from Milli Vanilli...
oldfart01's Avatar
Motorcycle: Dromaius Novaehollandiae, ...XR650R .K7-1000
Re: 1st gear Clunk!
I was thinking the same thing, I'm picturing some tech standing there scratching his nuts with a confused look on his face. He's a tech & it's a clutch for christ sake. What would he do next, burn some f**cking incense & chant!
oldfart01 is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 03:36 PM   #12
Dread
Dread's Avatar
Motorcycle: 2006 SV650S 50,000+ Miles (Now a track bike), 2006 GSXR-750 Street
Re: 1st gear Clunk!
Your clutch is dragging for sure...due to either improper adjustment, or your plates are already warped.
Dread is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 07:59 PM   #13
loco
loco's Avatar
Motorcycle: K6 1000, 97 Fantic Section 250 Trials, 84 Yamaha Seca 400
Re: 1st gear Clunk!
I always pump the clutch once, then again and into first, habit I've been doing for years, but I never get a big clunk, I also don't skip gears, with blips on downshifts and my tranny is like butter. Shnick, schnick.
loco is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 08:24 PM   #14
slack0Yd
Supersport Racer
slack0Yd's Avatar
Motorcycle: 1000k5
Re: 1st gear Clunk!
I say its normal. My YZF600R did it too.
slack0Yd is offline   Reply With Quote Quick reply to this message
Old 04-18-2008, 09:52 PM   #15
loco
loco's Avatar
Re: 1st gear Clunk!
Any thoughts?
A video would help, it's hard to know how big of clunk you're talking about.
It's always going to make a clunk, but it should be more of a click/shnick, get me?
Friend had a Honda CBR 1000 Repsol and it made a viscious kinda clack noise, sounded fucking awsome actually, like he was engaging for flight. Sometimes mine won't make any noise, it's wierd, smooth as a babies ass.
Post a vid if you're really concerned.
Old 04-18-2008, 10:15 PM   #16
Geesxara
Geesxara's Avatar
Motorcycle: 06 GSXR1000
Re: 1st gear Clunk!
A new clutch kit doesnt sound like a bad idea(not too costly) and also check for notches in the basket & clutch hub where the plates make contact.
Geesxara is offline   Reply With Quote Quick reply to this message
Old 04-20-2008, 01:01 AM   #17
BackOn2Wheels
Re: 1st gear Clunk!
Good tips...I will definately try these this weekend and see if I can narrow it down a bit more.
I just may do this if I cant nail it.
There is only 6500 miles on the bike. Do you really think the clutch is bad this soon?
Old 04-20-2008, 01:39 AM   #18
Geesxara
Geesxara's Avatar
Re: 1st gear Clunk!
Ive had to replace entire clutch fibres & metals in less than 10K miles on more than one GSXR that has come in the shop. It just depends on the rider I presume. If you were the first owner it might be a different reply. Heaven knows what that bike might have seen before you bought it. Why was that bike sold with such low miles? Are you 100% sure those are the original guages?
Many thoughts come to mind. It could also just be a a small problem causing the whole thing, just threw that out there, since it seems to be an on-going situation thats all
Lifer professional mechanic, please shoot me
Old 04-20-2008, 01:48 AM   #19
DrGixxer1000
DrGixxer1000's Avatar
Motorcycle: 2004 GSXR 1000
Re: 1st gear Clunk!
I have a 04 1K and I get a clunk when the bike is cold, and it is in first gear only, but that is it. I have also had a 03 1K and it did the same thing. The main problem I am seeing here is that you say your clutch has no slack in it at all. There should be a little slack in the lever when you are not using the lever. This makes sure the clutch is fully engaged. If you have no slack at all, you are riding around with the clutch just partially engaged... which will only get worse the longer you do it. Not to mention, the bike should never keep pulling forward in any gear with the clutch pulled in. If this is happening, it may be to late or the clutch is not disengaging all the way.
The tolerance is like 10-20mm of play at the end(outside) of the lever. Make sure this is right before you start ripping apart your bike and installing new clutches.
DrGixxer1000 is offline   Reply With Quote Quick reply to this message
Old 04-20-2008, 03:09 AM   #20
vaffanculo403
Motorcycle: 2K1 Seven Fiddy
Re: 1st gear Clunk!
Well it may pull forward a little when in first and the clutch is pulled in when it's cold and the oil is still thick. Depending on the oil it may be just thick enough to get friction and pull the bike forward a bit.
I say change the oil before you do too much else. I had a problem when I first for my 750. 1/2 the time I had to stomp on it to get it into gear and it made this wicked bang/clunk (sounded horrible) and sometimes I couldn't down shift into first when coming to a stop light. I changed the oil and used Shell Rotella-T full synthetic and WOW what a difference. The clunk was almost gone (just the normal clunk now), shifted like new or better, and the motor ran smoother and quieter! I'd try the oil change before I went spending 100's of dollars on getting a new clutch put in...
vaffanculo403 is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
