finally al done,been a mare fitting the engine,gettin all the bits for it etc etc,had to fit new piston rings/clutch/cam chain tensioner etc so apart from big ends and gears, its a pretty new engine.
Why was it a "mare" ?
The srad 750 mototr bolts directly into a srad 600 frame with No drama what so ever!
Did you use a new gen motor in a srad frame or vice versa?
1. i used the existing 600 bits to run the 750 engine, coils,ecu etc, it ran like shite.
2. The clutch was foobard, also the rings were shot, hassles of buying a 2nd hand lump i guess, so had to strip it all (twice, 1st time i did the cam chain and clutch at the same time and slipped a tooth so had to re-alaighn,then found out the rings were shot so had to totally strip it again.
3.had to source all the 750 auxilleries,coils,ecu loom etc etc.
The 750 lump fits easy enough, but gettin it runnin right is another matter
so thats why it was a mare really, bad luck and a mix of bad mechanics/long days/tired etc.
The back end is from a k4 1000.
used exisitng SRAD rear subframe and cut to suit.
will post up some pics of the process/bits
cheers
My Shit only smells when i eat spicy food.
hey where did you buy the rear tail frame @ ?? what year is that off of ??
did you have to modify/cut/anything to it to fit on the SRAD?? I have a 2000 GSXR 600 srad .... and think it looks great!
I'm thinking of swapping over to a 750 too .... how much in all did it cost you to swap?? did you take apart and re-build the 750 motor or was it plug and play??
thanks for the info bro!!!!!!!!!!!!!!!!
why dont you read the thread instead of bringing it back from the dead to ask questions already answered
Nice SRAD .. I'm thinking of doing a 750 engine change on my 600 .. just want to know . Did you use the inj model engine or the early carb model engine ? Did you change the fuel pump?
Thanks .......
Hi again .. You said you had to fit the 750 ecu and leads.. would it not run on the 600 leads and coil packs?? . which ign parts did you fit ??
just so i know wot i have to get Cheers
