removing seat/cowl without key? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 02-05-2008, 03:09 PM   #1
King07/750
King07/750's Avatar
Motorcycle: 07 GSXR 750
So i learned allot this weekend. picked up a new bike after mines was stolen a couple weeks back. have to pretty much put her together (cosmetically anyways). so swapped out tank this weekend. finally learned how to do the exhaust. it amazes/upsets me how much i paid the shop to do some of this crap before. then again that’s why im tryna learn. anyway in my haste in putting things on. i put my new tail section on but forgot to swap the key/lock and well i put the seat on . so as you can figure its stuck on there. any suggestions to getting it off. cant take the tail section off now cuz the seat is locked on. i tried taking off the under cowl to the tail section but cant get to where the seat lock release is.
anyone
The only mod i have is seat time
King07/750 is offline   Reply With Quote
Old 02-05-2008, 03:51 PM   #2
OGs750
Clothing Optional
OGs750's Avatar
Motorcycle: k6 750
Re: removing seat/cowl without key?
are you sure you don't need this info to get a spair set of tools out of your buddies bike?
OGs750 is offline   Reply With Quote
Old 02-05-2008, 03:55 PM   #3
rocgixxer
rocgixxer's Avatar
Motorcycle: 07 GSXR 600
Cant say I can help but just wanted to say good luck and good on ya for learning to do stuff on your own. One of my goals is to get proficient in some more repair/maintenance areas this season. Anyway, its your thread. Good luck dude and congrats on getting a new bike
rocgixxer is offline   Reply With Quote
Old 02-05-2008, 03:55 PM   #4
stefanos
stefanos's Avatar
Motorcycle: Cbr 1000 08
man it hapent to me also wile i was changing fairings....not exactly but i had remove the lock to fix something and then i put the seat on....so i dint have any key to open it...
what i did i dont know if will help you couse i dint have any fairings on...
but if youmanage to unscrew the bolts of the Seat that holds the helmet holder then you remove the seat easy...but youneed to remove the back side fairings i dont know if you try bending them a bit will help.
Where is your back up key??
stefanos is offline   Reply With Quote
Old 02-05-2008, 03:58 PM   #5
King07/750
King07/750's Avatar
lol guess it does sound kinda fishy but naw. i just didnt put the new key/lock into my new tail section. so if you know tell me!!!!!!!
Old 02-05-2008, 04:02 PM   #6
King07/750
King07/750's Avatar
i have my keys. its the actual lock that is missing. i was swapping them out and was getting frustrated tryna put the lock in (bitch is tricky) so just put the fairings on and put the seat on to0, not thinking that i wouldnt be able to get it off. i just dont want to start pulling apart fairings. i just bought em.
Old 02-05-2008, 04:03 PM   #7
King07/750
King07/750's Avatar
Its amazing how easy most this stuff is. As soon as i learn somthin i get pissed i ever took it to shop. like paying 120 for them to put on slip on. took me 20 min minus taking off fairings. thought taking tank off and the pump out would be hard as hell. 15 min!!!!!
Old 02-05-2008, 04:05 PM   #8
Aramis
if the cable is connected and you just don't have THAT key cuz it's a fairing you bought second hand, well, you can try picking the lock, shouldn't be too hard...
I did that mistake when putting my tail back on last weekend, but I had the cowl on, and I had forgotten to clip the cable back. The cowl is easier because there's an indent so you can hang a helmet, I managed to grab the release mechanism from the indent with a folded metal rod...
Good luck!
Aramis is offline   Reply With Quote
Old 02-05-2008, 04:17 PM   #9
King07/750
King07/750's Avatar
the cable is discconected. there is a hole where the lock/key should go. i took out the lock/key from my old set and just didnt put it in new ones yet. so cant pic lock.
think ill try gettin a hanger and seeng if i cant grabit somehow. dont care bout the seat just dont want to mess up the fairings.
Old 02-05-2008, 04:21 PM   #10
RIDER4EVER
RIDER4EVER's Avatar
Motorcycle: 08 GSXR 1000
Man that sucks you can try taking the under tail off and reaching in the side if you hands can fit.
RIDER4EVER is offline   Reply With Quote
Old 02-05-2008, 04:25 PM   #11
King07/750
King07/750's Avatar
tried that already. thought i had a pretty good shot with that but you cant reach the pull thingy that unlocks it. ill spend a couple hrs this weekend on it. mite cut up seat as a last resort. see if i cant break it bit by bit till i get where i can get to the pull tab to release it.
Old 02-05-2008, 04:57 PM   #12
cinder99
Superbike Champ
cinder99's Avatar
Motorcycle: METRO
get a flash light, long screw driver I think If you can push down on the tail section, U will see the lever that u need to push to the opposite side.
cinder99 is offline   Reply With Quote
Old 02-05-2008, 04:58 PM   #13
787
Motorcycle: k4/k6 600
remove the bolts from right fairing tail.than you can put your hand..works for me.5 min max.
787 is offline   Reply With Quote
Old 02-05-2008, 05:10 PM   #14
cinder99
Superbike Champ
cinder99's Avatar
Motorcycle: METRO
Old 02-05-2008, 08:32 PM   #15
GSXRjohn
Motorcycle: 2006 GSXR 750
I took the tail section off my bike once and never hooked up the cable from the lock cylinder. I installed the cowl, not the seat without the lock working. I was able to pry it up a bit on the left side and slide a coat hanger in there to pop it loose. Took some time and a lot pf patience though!
GSXRjohn is offline   Reply With Quote
Old 02-05-2008, 09:03 PM   #16
King07/750
King07/750's Avatar
yea im pretty sure ill get it off. just gona take some time. rite now it has a small wood stick going through it to help pry it open. need to wait till mourning thoough. cant see shyt. need a flash light. i was thinking coat hanger but go figure no wire coat hanger in the house (the wood stick is from a coat hanger)
Old 02-05-2008, 09:07 PM   #17
Hoots
Humboldt Hooter Tadaaaaa
Hoots's Avatar
Motorcycle: Feet
Time to brush up on your lock picking skillz
Hoots is offline   Reply With Quote
Old 02-05-2008, 09:09 PM   #18
00rngr
Motorcycle: 06600Gsxr
do wat cinder sed i actually used a hanger but it just pulls toward you........plus theres a gap from the seat cowl and stuff already just slide it in jiggle jiggle and wallalalalalala
00rngr is offline   Reply With Quote
Old 02-05-2008, 09:11 PM   #19
King07/750
King07/750's Avatar
THERE IS NO LOCK!!!!
Thats the problem lol
Old 02-05-2008, 09:14 PM   #20
King07/750
King07/750's Avatar
yea ill get it. just wanted to hear hat ther mmbers have done. should have saw my fce when i realized i couldnt just take the seat off
