GSXR 750 specs (wt and hp) : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 03-03-2001, 03:22 PM   #1
**DONOTDELETE**
Ok Gixxer friends, who knows where I can get accurate HORSEPOWER and WET WEIGHT numbers for my bikes?
1986 GSXR 750 and
1992 GSXR 750
**DONOTDELETE** is offline   Reply With Quote Quick reply to this message
Old 03-03-2001, 03:48 PM   #2
imported_jeff
Superbike Champ
Motorcycle: jeff
Re: GSXR 750 specs (wt and hp)
numbers will vary a bit, but these are close:
stock 86 750 - 85-90rwhp, ~455 lbs wet
stock 92 750 - 95-100rwhp, ~510 lbs wet
imported_jeff is offline   Reply With Quote Quick reply to this message
Old 03-13-2001, 01:09 PM   #3
doug
Motorcycle: doug
the stock 86 is listed at 388LBS dry figure 10lbs for gallon of oil 6LBS/gal for gas or about 24lbs and 2lbs for fork oil or about 424lbs total.
86 totally non stock
doug is offline   Reply With Quote Quick reply to this message
Old 03-13-2001, 03:02 PM   #4
Pod99966
Pod99966's Avatar
Motorcycle: 03 Kawasaki Z1000
http://www.ophetweb.nl/rhouse/SpecSheets/1992.htm
http://www.ophetweb.nl/rhouse/SpecSheets/1986.htm
a neat little source for manufacture's spec.
The Last of a Breed
91/2 GSX-R 750N Vance&Hines Exhaust, V&H open air filters, jetted carbs, ported and polished heads, crappy color custom paint, Lockhart flush c/fiber blinkers yadda yadda yadda...
Pod99966 is offline   Reply With Quote Quick reply to this message
Old 03-13-2001, 03:09 PM   #5
Pod99966
Pod99966's Avatar
The Last of a Breed
Old 03-13-2001, 05:44 PM   #6
imported_jeff
Superbike Champ
Motorcycle: jeff
that dry weight figure is optimistic (as factory weight specs usually are). trust me, a bone stock fully wet 86 750 weighs closer to 455 pounds.
Old 03-13-2001, 07:03 PM   #7
Pod99966
Pod99966's Avatar
I did say for manufacture's spec.
and Jeff i'd trust you over Suzuki Spec sheet
The Last of a Breed
Old 03-13-2001, 07:11 PM   #8
imported_jeff
Superbike Champ
Motorcycle: jeff
i was responding more to doug's wet weight figure.
the manufacturer's dry weight doesn't include ANY fluids - including battery, brake fluid, air in the tires, etc. gets kinda silly but they're trying to make that number as small as possible without lying outright.
[This message has been edited by jeff (edited 03-13-2001).]
Old 04-02-2001, 09:00 PM   #9
**DONOTDELETE**
You mean to tell me, the 92 750 is 500 lbs wet??? wow!! Compared to, say a 96, what are we looking at for a difference?? Thanks.
Jeff
Old 04-02-2001, 11:04 PM   #10
imported_jeff
Superbike Champ
Motorcycle: jeff
the fully wet stock weight difference between a 92 and 96 750 is about 50-60 pounds.
Real Name
What is your real name?
Search this Thread:
Advanced Search
