Spark plug change?!?!? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-29-2007, 09:15 AM   #1
the3kid
the3kid's Avatar
Motorcycle: 07 GSX-R600
quick question...took out my spark plugs to inspect and are perfectly fine...should i still run them for the next season??? my bike only has 2500 miles on it...and should i get hotter or colder ones, no discolor of the spark plugs(white or burnt)????
the3kid is offline   Reply With Quote
Old 11-29-2007, 09:43 AM   #2
TheCunningMan
TheCunningMan's Avatar
Motorcycle: 750k6
Re: Spark plug change?!?!?
I can't remember if the manual has Inspect or Replace at that mileage. I replaced mine a little earlier but that was due to track miles.
Useful
http://www.ngksparkplugs.com/techinf...q/faqread2.asp
Was the gap still within spec?
TheCunningMan is offline   Reply With Quote
Old 11-29-2007, 09:48 AM   #3
MdBikerBoy
inspect around 4,000 replace at 7500. if they looks good I would leave them alone personally but if you do alot of racing most would say replace every season probably.
MdBikerBoy is offline   Reply With Quote
Old 11-29-2007, 12:35 PM   #4
AndrewM
Superbike Champ
AndrewM's Avatar
Motorcycle: 06 750
If you only put on 2500 a season and they look fine I wouldn't change them until the end of next season
AndrewM is offline   Reply With Quote
Old 11-29-2007, 12:48 PM   #5
K7600_C230
K7600_C230's Avatar
Fuck you have em out, u might as well change em so you dont have to do it all over again...
K7600_C230 is offline   Reply With Quote
Old 11-29-2007, 01:22 PM   #6
JDGSXR1000
JDGSXR1000's Avatar
Motorcycle: 2005 GSXR 1000, 2003 TL1000R, Custom 1970 Shovelead Bobber
Go to Advance and pick up some NGK Iridiums they will give you a better spark...should be a CR9EIX or whatever number you have on the plug in your bike right now just add IX to the end of the number....runs a little cleaner...should be around $7.99 a piece
JDGSXR1000 is offline   Reply With Quote
Old 11-29-2007, 04:19 PM   #7
KeggeR62
KeggeR62's Avatar
Motorcycle: 2007 GSXR 750 Blue/Black
I would replace them just because you have it all apart anyways...
KeggeR62 is offline   Reply With Quote
Old 11-29-2007, 04:23 PM   #8
1qwikgix
1qwikgix's Avatar
Motorcycle: k6 gsxr 6
replace with iridium but you dont want a hotter plug unless you need one.
by the way any feedback on these?
http://www.oppracing.com/products.php?id=265
1qwikgix is offline   Reply With Quote
Old 11-29-2007, 08:06 PM   #9
billy750
billy750's Avatar
Motorcycle: 07 GSXR 750
i was looking at those plug too.. looks pretty sick.. dont know if you will feel a difference... maybe there is some.. but very small i guess... i already did my plug change at 8000 with race filter...NGK.. they seem to work pretty good..
billy750 is offline   Reply With Quote
Old 12-01-2007, 09:59 PM   #10
kbmoc
what color where the plugs when you took them out? if they are the color of a paper bag put the same cr9e back in the bike if the plug was wet and black put a cr8e in the bike. you want the plug to be the color of a paper bag and not wet or black! but since you have already taken them out go ahead and replace them. and for the iridium plugs it is a waste of money
kbmoc is offline   Reply With Quote
Old 02-20-2008, 09:50 PM   #11
dna_powersports
YOu have my attn - What is a cre8? I just bought a 06 gsxr 1000 and the plugs are black at 7500 miles. ngk cr9e is what is in them now. Whats the difference?
dna_powersports is offline   Reply With Quote
Old 02-21-2008, 01:23 AM   #12
OutOfMyDepth
CR8E is a hotter version of the CR9E std plug. If your plugs are black and wet then change to the CR8E. However if you've just bought the bike then id suggest you stay with the CR9E until you see what they are like from YOUR riding.
OutOfMyDepth is offline   Reply With Quote
Old 02-21-2008, 01:23 AM   #13
ZaXoS
ZaXoS's Avatar
Motorcycle: Suzuki GSX-R, Honda VFR, 1971 CB750, 1976 OMER 50 sport, Aprilia Habana
CR8 is a hotter plug. Same design, just runs one level hotter, which should burn better if you are running rich.
I blackish plug would indicate a rich mixture, or oil going up there. A hotter plug can cure some of that.
Cons: You got to watch your detonation. You may have to switch to higher octane gas as regular may explodes before its time due to the heat.
Also make sure that is the cause. For example, you may have a dirty air filter not allowing enough air. Consequently more fuel than air goes in and the plugs foul or get black.
ZaXoS is offline   Reply With Quote
Old 12-10-2008, 10:38 PM   #14
Smittybizzle
Smittybizzle's Avatar
Motorcycle: 03 GSX-R 600/1000
I am slipping I have to repalce mine now
Smittybizzle is offline   Reply With Quote
Old 12-10-2008, 10:45 PM   #15
Speedin4fun
Supersport Racer
Speedin4fun's Avatar
Motorcycle: 2007 GSX-R 600
along with the plugs.....Who puts antisieze on the threads and why?
Speedin4fun is offline   Reply With Quote
Old 12-10-2008, 10:55 PM   #16
MikeHump
Looking for fat chicks for long walks, romance and ballast
MikeHump's Avatar
Motorcycle: 2007 GSX-R600
I don't put antisieze on my plugs, never have and never had a problem but most recommend it so you don't strip the threads in the block.
To the OP if your plugs are fine why spend the extra money? Service and Owner's manuals say to replace every 7,500 or so miles. You can replace if you want at 2,500 to but there's really no point if the bike is still running good and they don't have any abnormal wear.
MikeHump is offline   Reply With Quote
Old 12-15-2008, 07:45 PM   #17
Velox
Velox's Avatar
hey guys,
how difficult is it to change the plugs yourself?? my plug change is pending to instead of taking it to the dealer i was planning to do it myself, i usually prefer woking on my bike myself...beeing a professional aircraft mech it usualy turns out fine...
so what u think?...is it ok to DIY?? also do we have the plug sized wrench in the tool kit?
Velox is offline   Reply With Quote
Old 12-15-2008, 07:46 PM   #18
Velox
Velox's Avatar
besides i can borrow some antisieze from the work place too
