horsepower on 02 GSXR 750 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 09-19-2007, 03:44 PM   #1
jdrummer82
Motorcycle: 2002 GSXR 750, Yoshi RS3 Full Exhaust, Power Commander PCIII USB
Question horsepower on 02 GSXR 750
I'm new to gixxers, my last bike was an 03 R1, and I'm trying to find out the stock horsepower on a 2002 gsxr 750, along with the 0-60 and 1/4 mile times. I've looked online and I can't seem to find the info. If anybody knows or can tell me where to find it I would appreciate it.
jdrummer82 is offline   Reply With Quote Quick reply to this message
Old 09-19-2007, 03:52 PM   #2
Ogri 750
Ogri 750's Avatar
Motorcycle: 2000 GSXR 750
Re: horsepower on 02 GSXR 750
141 hp
That's the official figure, bear in mind, that will be at the crank.
Get it on a dyno and see what you get at the rear wheel
Ogri 750 is offline   Reply With Quote Quick reply to this message
Old 09-19-2007, 08:50 PM   #3
oryan20xx
oryan20xx's Avatar
Motorcycle: K1 GSX-R750, 2007 RSV 1000 R, 2000 RS 50
http://www.motorcyclistonline.com/pe...cedata/#suzuki
Quarter mile 10.26 at 135.6, other data wont be easy to find.
My 01 dynoed at 119 hp with BMC filter, 1000 header, Devil slip on and power commander.
oryan20xx is offline   Reply With Quote Quick reply to this message
Old 09-19-2007, 09:00 PM   #4
thecount
thecount's Avatar
been told about 116-121 hp in that area.maybe with a full system and a custom map you might beable to get a little more.
thecount is offline   Reply With Quote Quick reply to this message
Old 09-19-2007, 09:38 PM   #5
Madgixxerman
Madgixxerman's Avatar
Motorcycle: K2 Gixxer 750
My K2 750 dynoe'd out at 124.9 hp at the rear wheel. Has Yoshi TRS, Power commander, K & N air filter, -1 and +2 sprockets, and custom map. Never had it thru the 1/4 mile, so can't give you those figures, sorry.
Madgixxerman is offline   Reply With Quote Quick reply to this message
Old 09-20-2007, 07:10 PM   #6
cagixxer750
cagixxer750's Avatar
Motorcycle: 2006 GSXR 1000
my 02 750 put down 133 hp and 58 ft lbs or torque. this was with a Micron Serpent system, k&n filter, TRE, and a 520 conversion.
cagixxer750 is offline   Reply With Quote Quick reply to this message
Old 09-20-2007, 11:03 PM   #7
jdrummer82
Thanks guys, I really appreciate the info. I have a yoshi rs3 full exhaust and I just ordered a power commander. I'm going to put a tre and I'm considering -1 +2 on the sprockets, but not sure about that one.
Old 09-22-2007, 10:53 AM   #8
Madgixxerman
You'll like that one for sure!! Just be sure to hold on tight!
Old 09-22-2007, 03:51 PM   #9
cagixxer750
i had a -1 +1 on the 750 and i think that was about as far as i'd go for riding on the street, i just did this to my 06 1k also and i think it one of the better gear changes for street and some track use. you do lose quite a bit of top end when you make that swap and your gas milage will be a lot less but you'll definately feel adifference in performance.
Old 09-23-2007, 06:51 PM   #10
banzai13
Dead dino destroyer
banzai13's Avatar
Motorcycle: '01 750...'89 fzr 600
Most stock bikes were 120-123 hp.
Built supersport motrs with coated pistons and a good pipe were about 138 hp.
banzai13 is offline   Reply With Quote Quick reply to this message
Old 09-24-2007, 07:48 PM   #11
GSX-R 71
GSX-R 71's Avatar
I have an 01' 750, and I had mine dynoed a couple months ago. I have a full Yoshimura TRS system, PCIIIusb, and the stock air filter.
It made 132+ hp at the rear wheel on a Mustang dyno. I hear that they read low, but it's not all about the numbers. My bike runs a lot better/smoother now with that PCIIIusb on. My tire was low on pressure too at the time. The reason being the tire gauge I was using was off by ten psi! He said that might've gained another 1hp on the dyno, but whatever. It runs better than what it did, and I'm pretty happy with how much it smoothed my bike out.
Some people never have anything except ideas. Go do it!
GSX-R 71 is offline   Reply With Quote Quick reply to this message
Old 09-25-2007, 04:38 PM   #12
xtrm23x
xtrm23x's Avatar
Motorcycle: 2000 gsxr 750
Keep in mind that every brand of dyno reads different. In some cases there can be a 10 to 15 horsepower difference between brands.
xtrm23x is offline   Reply With Quote Quick reply to this message
Old 09-29-2007, 12:30 PM   #13
GSXRSE7EN
Motorcycle: 2001 GSXR750
Mine put down 129 at the wheel two summers ago.
I thought the dyno might be a little optomistic, but was told by a few others it may be pretty realistic.
Arrow Exhaust, Yoshimura EMS, K&N, Pair mod, -1 on the front...
GSXRSE7EN is offline   Reply With Quote Quick reply to this message
Old 10-01-2007, 05:34 AM   #14
gixken
gixken's Avatar
Motorcycle: 06gsxr750-street, 05gsxr600-track
02-750-- mine 118rwhp PC3 full exh on dyno
gixken is offline   Reply With Quote Quick reply to this message
Old 10-01-2007, 07:24 AM   #15
xtrm23x
xtrm23x's Avatar
I have a 2000 750 mine was 117 with aslip on. It now reads 130 after a few upgrades.
Old 10-15-2007, 09:45 PM   #16
sambam
Motorcycle: k5 1000
my 03' put down 118 stock..123 with a full yosh ..power comm. k&n filter.. not bad, it ran pretty strong back then.
sambam is offline   Reply With Quote Quick reply to this message
