serious problem!! its a challenge!! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-22-2007, 11:57 AM   #1
northgagsxr
Exclamation serious problem!! its a challenge!!
Well ive been in every forum of every gsxr website and talked to every suzuki tech around and they have no idea what is wrong with my bike.
heres the deal I rebuilt the motor because it needed rings.about 8K miles ago and its ran fine, perfect actually, until about 500 miles ago. the problem is that when the motor is under load via throttle it bogs down and actually cuts out in 2nd gear.
heres what ive done so far.
1 cleaned/rebuilt carbs, tried every possible jetting, and swapped carbs from good bike
2 swapped coils
3 swapped cdi
4 swapped pulse generator coil
5 removed sidestand switch
6 removed clutch switch
7 new battery
8 cleaned tank and prestrainer is clean
9 fuel pump primes
10 vaccumm diaphram opens to allow fuel flow when vaccumm is applied
11 no airbox restrictions
12 power to everything
13 grounds good
14 no shorts/opens found in wiring
15 no burn marks in start/run switch and operation is good
16 no defects with ignition switch found. key turns good and no abnormalities when riding from jiggling key, pulling harness or knocking on switch.
17 no exhaust leaks
all this and it still bogs when under a load/ wide open throttle when fully warm only cutting out in 2nd gear.
I HAVE STUMPED MYSELF AND ABOUT 20 OTHERS....i need some serious help. could a slightly leaking petcock do this? i dont think so but that the only problem ive found that out of the ordinary so far. thanks for the help guys!
northgagsxr is offline   Reply With Quote
Old 08-22-2007, 04:38 PM   #2
mpdgsxr1000
Bearded Admin call him Grizzly
mpdgsxr1000's Avatar
Motorcycle: 2001 GSXR 1000 modded to the hilt, 2000 GSXR 600 race bike
Re: serious problem!! its a challenge!!
so what year bike and what is it 600 or 750?
have you checked the fuel filter inside the fuel line?
mpdgsxr1000 is offline   Reply With Quote
Old 08-22-2007, 09:46 PM   #3
northgagsxr
yes and its spotless not even a speck of trash......fun problem huh?
Old 08-22-2007, 09:48 PM   #4
northgagsxr
ohh and its a 600 with bolton yosh RS3, jet kit, and a K&N.
Old 08-22-2007, 10:33 PM   #5
mlongo99
mlongo99's Avatar
Motorcycle: 97 GSX-R750 2008 R6
Here's an idea from a similar problem I had with a Honda. Under heavy load you're pulling the most vacuum. It's possible that there's a small hole in the fuel pressure regulator's diaphragm. If the vacuum moves the diaphragm to a position that exposes the hole, fuel will get sucked into the vacuum line, dumped into the intake runners, and choke the engine.
The tell tale sign is fuel in the vacuum line. If the problem arises and goes away once the engine is idling, the fuel may dry out and not appear there. But, to be sure, you could try reproducing the problem and when it's significantly bogging down, kill the engine. Push the bike back to your garage and check the line. You may also find fuel puddling on top of the closed intake valves.
That was a tricky problem for me to diagnose, but once I figured it out, all the clues suddenly made sense. And luckily, that's a cheap and easy fix.
Mark
mlongo99 is offline   Reply With Quote
Old 08-22-2007, 11:16 PM   #6
mark_E
idiot
mark_E's Avatar
Motorcycle: 1990 GSXR1100
Does it still do it with airfilter(s) off?
mark_E is offline   Reply With Quote
Old 08-23-2007, 01:05 AM   #7
skidmark
I Love Item 9
skidmark's Avatar
Motorcycle: GSXR 7/10
hmmm... sounds like something that happened to my buddies 96 750. We spent hours trying to figure it out...
Turned out that after riding for a few miles his airbox would lift off the carbs a little bit and that would break the seal (boots on the carbs), then it would bog out under load...
We ended up cutting off the front tab that bolts the box to the frame so the front of the box would sit a bit lower and the boots would then sit at the right angle on the carbs... problem solved.
skidmark is offline   Reply With Quote
Old 08-23-2007, 08:32 AM   #8
northgagsxr
well i put a vaccum pump on the vaccum line and pulled a vaccumm on it and it opened the main fuel line but didnt notice any fuel coming down the vaccum line...HOWEVER...i do have fuel that seems to be in noticable quantity on the inside intake boots after sitting for a period of 3 days. this i believe is due to the slightly leaking diaphram for the petcock. but could a slightly leaking petcock cause to much fuel under load when the needle valves are suppose to shut fuel to the carbs?
Old 08-23-2007, 10:07 AM   #9
REARSPROCKET
REARSPROCKET's Avatar
Motorcycle: K2 1K, 98 SRAD 750 Both B/W
There was a factory recall on early 96 fuel valves, which were swapped out at the dealer. I would start by replacing the valve and see if problem gets better also check fuel pump and filter. Good luck
REARSPROCKET is offline   Reply With Quote
Old 08-27-2007, 03:04 AM   #10
Thruan
Thruan's Avatar
Motorcycle: 96 srad "750", worked
no a leaking pet cock cannot cause this.. the floats will only open when there is more then 4psi of fuel pressure.. and the stock carbs have some sort of pressure relif shit in them, thats what all the crap at the bottoms of the carbs are..
i had sorta a similar problem, i just swapped carbs and it went away, later on it happend to my mates bike with very simple carbs, easy to figure out, and it was 2 of the diaphrams werent sealing properly allowing the slide to lift to far, and extreamly lean out the bike.. but uve swapped carbs so i dont think its that.. so i sorta wasted time typeing this lol
If im not getting into heaven, there better be one long god damn twisty road to hell!!
Thruan is offline   Reply With Quote
Old 08-27-2007, 07:43 AM   #11
northgagsxr
well i still appreciate the input and comfirming its not a petcock issue. could a misadjusted cam chain do this? if it was slack (not to where it caused noise but just slack)
Old 08-27-2007, 11:43 PM   #12
Old Skool_R
Old Skool_R's Avatar
Motorcycle: 88 GSX-R 750
The gas inside the boots after 3 days of sitting sounds like a bad needle/seat.
Old Skool_R is offline   Reply With Quote
Old 08-29-2007, 09:52 AM   #13
showtime2400
showtime2400's Avatar
Motorcycle: 99 srad 600
I really hope you find whats wrong with your bike northgagsxr. Mine does the same exact thing. I havent been able to ride my bike in almost 2 years, ive had every good mechanic i know look at my bike, spent almost $1200 trying to fix it & its at the 3rd shop right now.
I cannot understand why noone can fix this. Ive tried everything & im at my last with this bike. If this shop cant fix it then my only option is to part it out, but its a shame b/c i love this bike & it really is a nice bike.
if you figure this out please let me know what the problem was! thanks
showtime2400 is offline   Reply With Quote
Old 08-29-2007, 09:19 PM   #14
northgagsxr
haha its the curse of the blue and white gixxers....i know 4 of us with same years and graphics with this issue. i cant take it to the shop....they said all they can do is part swap and ive swaped all the parts. even checked my compression and leak tested the motor and everything is perfect. i wonder if anyone on this website has contact with suzuki directly?
Old 08-30-2007, 08:05 AM   #15
00gsxr6
00gsxr6's Avatar
Motorcycle: 2000 Gsx-r 600
this may or may not be of any help but I have had very simular problem and it turned out to be gas tank venting.
00gsxr6 is offline   Reply With Quote
Old 08-30-2007, 04:24 PM   #16
northgagsxr
Yes ive explored that and it vents fine...no clogged hoses. but i do appreciate the suggestion
Old 08-30-2007, 06:41 PM   #17
stihorsepower
stihorsepower's Avatar
the fluxcapacitor is bad.... DUH
stihorsepower is offline   Reply With Quote
Old 08-31-2007, 09:49 PM   #18
northgagsxr
i wondered when the immature comments would pile in...it would be funnier if u said something other than flux capacitor. like its the incorrect installation of the crossdrilled brake lines with the lefthanded metric screwdriver
Old 08-31-2007, 10:08 PM   #19
stihorsepower
no thats just gay
Old 09-02-2007, 10:51 AM   #20
REARSPROCKET
I have seen bad ground wires or just loose and bad connections for ground do weird things. Also check the crank position and cam position sensors are tight and haven't come loose. Check these areas if you haven't yet? Good luck
