Should I add fuel injector cleaner/additives to my gas? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-10-2007, 04:06 PM   #1
GM Gixxer
GM Gixxer's Avatar
Motorcycle: '91 GSX-R 750 & now a '06 GSX-R 1000
Just thinking, is it a good idea to run fuel injector cleaners in my '06 1k every couple of tank fulls..:confused?
GM Gixxer is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 04:10 PM   #2
Quick Gixxer 750
Quick Gixxer 750's Avatar
Motorcycle: 07' GSXR 1K
Re: Should I add fuel injector cleaner/additives to my gas?
Dont know about cleaners but I use Lucas Octane Booster quite often . Great stuff !
Quick Gixxer 750 is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 05:17 PM   #3
GsxRSilly
Motorcycle: 05 gsxr600&07 gsxr1000
Interesting, what are the benefits of adding Lucas Octane Booster IYO?
GsxRSilly is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 05:18 PM   #4
j_fukin_t
j_fukin_t's Avatar
Motorcycle: 09-12 ZX6R mutt fer now
only one i would use would be seafoam
j_fukin_t is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 05:34 PM   #5
565Customz
565Customz's Avatar
Motorcycle: k5 1000
i use lucas octane booster when i ride the street and use about half a bottle of gumout fi cleaner when i change the oil.
565Customz is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 09:31 PM   #6
perry
perry's Avatar
Motorcycle: 2005 GSXR 1000
thats all i use in my bike,car,and truck
perry is offline   Reply With Quote Quick reply to this message
Old 08-10-2007, 10:41 PM   #7
gixxbynite
gixxbynite's Avatar
i would not add anything until the mileage is up there. i totalled my 05 with 30k on it. ran just like new. getting the 07 but only because the 05 was totalled. just ride it. and keep the oil changed. maybe later add some fuel additives only if its been sitting. just my 2 cents.
gixxbynite is offline   Reply With Quote Quick reply to this message
Old 08-11-2007, 07:18 AM   #8
2THRU
2THRU's Avatar
I use a fuel injector/system cleaner made by PJ1. I treat a tankful about every 1500 to 2000 miles. Not a major change in performance, but throttle response is better and idle is smoother. I think it's a pretty good bang for the buck...basically a "maintence" kinda thing
2THRU is offline   Reply With Quote Quick reply to this message
Old 08-11-2007, 08:52 AM   #9
Quick Gixxer 750
It made my bike run smoother and added just a tad of throttle response .
Old 08-11-2007, 09:44 AM   #10
mpp12
Motorcycle: K6 and a xz12r
FP60 here, nice on my KTM 520, excelent on my Sti, and use it on the K6 for maintenance and here the gasoline is very greasy.
mpp12 is offline   Reply With Quote Quick reply to this message
Old 08-13-2007, 04:47 PM   #11
Roadrunner1
Bottled Fuel injector cleaner is a waste of time. If you want your injectors totally clean get them taken out and ultrasonically cleaned. Not a lot of people realise but fuel cleaners can actually bung up the injectors. The reason is it breaks up the gunge your fuel filter in your fuel pump would normally strain out and thus allows it to pass through the filter and clog your injectors. It's basic but most people haven't got a clue. This is why many manufacturers don't recommend fuel cleaners, because they usually don't get rid of a problem they just move it elsewhere along the fuel system. Hope this helps.
Roadrunner1 is offline   Reply With Quote Quick reply to this message
Old 08-13-2007, 05:05 PM   #12
B-TownGixxer
B-TownGixxer's Avatar
I run Lucas, great stuff
B-TownGixxer is offline   Reply With Quote Quick reply to this message
Old 08-13-2007, 06:40 PM   #13
AdidasMan
AdidasMan's Avatar
Motorcycle: Gixxer
okay sure. I've ridden many a GSX-R cross country, which anyone that has done it will tell you, it's real easy to get bad gas. after a tank with a little lucas fuel injector cleaner it runs like new. every time. i run some through about every six tanks
AdidasMan is offline   Reply With Quote Quick reply to this message
Old 08-13-2007, 08:01 PM   #14
d207gp
d207gp's Avatar
Motorcycle: '06 G1K, '08 CBR1000RR, '13 Ducati MTS 1200
I asked this not too long ago: http://www.gixxer.com/forums/showthr...jector+cleaner
d207gp is offline   Reply With Quote Quick reply to this message
Old 08-13-2007, 08:15 PM   #15
Sucram
Sucram's Avatar
Motorcycle: ( . Y . )
Are you guys adding seafoam to your crank case as well?
im a bit skeptical on something that suggests its a fuel injector cleaner and can be used for engine internals...
to me its one or the other, the latter im not convinced about...
Sucram is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 12:10 PM   #16
perry
perry's Avatar
havent tried it in my crank case yet just in the tank
Old 08-14-2007, 01:02 PM   #17
frag_man
frag_man's Avatar
Motorcycle: 01 GSX-R1000
i hear seafoam can cure cancer....
frag_man is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 07:16 PM   #18
RCMURDOCK
Motorcycle: (05) GSXR-1000
When the price of gas went above $3.00; the stations in the mountains started adding water to their gas. I spit and sputtered home on more than one occasion when I got a tank of bad gas. One time I got kerosene in my gas and it gunked everything up badly. It took about 5 tanks with injector cleaner before the motor came back. But as a preventative measure; I don't use it.
R.C.
RCMURDOCK is offline   Reply With Quote Quick reply to this message
Old 08-14-2007, 07:31 PM   #19
orangeapeel
orangeapeel's Avatar
Motorcycle: K5 GSXR 1000
I have used seafoam a time or 2. Seems to work good in all combustion engines.
orangeapeel is offline   Reply With Quote Quick reply to this message
Old 08-15-2007, 09:42 AM   #20
d207gp
d207gp's Avatar
No no, that's Chuck Norris.
Search this Thread:
Advanced Search
