94 GSXR 1100 ignition ? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > Water Cooled Gixxers
Old 05-31-2007, 03:52 AM   #1
partsguy1
Exclamation 94 GSXR 1100 ignition ?
My tach drops to 0 then bounces back up when I'm on the highway. I thought it may be a carb issue. But when this happens I can downshift and open the throttle up and I have no problem, that is until I let off the throttle. It really bucks when this happens. It's not fun doing 90 and your bike shuts down for a split second and then resumes the speed and then shuts down again. Talk about getting jerked around. Talked to a Suzuki service manager who said it sounds like ignition. But of corse he wouldn't go any further into what to check. So any help would be much appreciated.
Thanks
partsguy1 is offline   Reply With Quote Quick reply to this message
Old 05-31-2007, 05:52 AM   #2
crzoomb
Supersport Racer
crzoomb's Avatar
Motorcycle: 94 1100 WR,'74 Triumph Trophy Trail,'04 RM 250
Re: 94 GSXR 1100 ignition ?
Ignitor module maybe
crzoomb is offline   Reply With Quote Quick reply to this message
Old 05-31-2007, 08:22 PM   #3
bcjohn
bcjohn's Avatar
Motorcycle: gsxr1146wp
Igniter boxes don't actually fail all that often. They are fairly robust. The coils can be problematic, but tend not to do the sudden on/off thingie. What can result in this is a leak between the #3 carb intake runner and the gas petcock. The number three carb supplies the vacuum which 'runs' the stock petcock. Does it still do this on the Prime setting? If not, then for sure its the vacuum line etc.. Good luck!
bcjohn is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 02:15 PM   #4
ribbitism
ribbitism's Avatar
Motorcycle: GSXR 1100 WT, K2 Bandit 600
The boxes might not fail often, but the connectors on them and the loom sure can. They're not very well hidden from the elements and water can be flung up onto it from the rear wheel (just take a look at where it is from underneath!) so personally I'd check the connectors there for corrosion..
ribbitism is offline   Reply With Quote Quick reply to this message
Old 06-02-2007, 03:31 AM   #5
partsguy1
I'll check all of these things and report back. Thanks for the help.
Old 06-12-2007, 04:29 AM   #6
partsguy1
I tried running the bike on prime setting and it does the same thing. I havent had time to check the connectors for corrosion.
Thanks for the help
Old 06-12-2007, 08:45 AM   #7
albart
Motorcycle: GSXR1100WR
Hi,
try check your side stand and the side stand switch, also check your interlock systems. and dont forget the logic diode.
same thing happened to me last year, i checked everything (including ignitor box) and the problem was just with the side stand and the side stand switch. when i pull 90mph the tacho drops zero and came back to normal in split seconds. it was happened because the roads were bumpy so the side stand did't touch the side stand switch properly when i rode on a bumpy roads..
albart is offline   Reply With Quote Quick reply to this message
Old 10-01-2007, 07:42 PM   #8
partsguy1
Does anyone know how to test the ignition componets??????
Old 10-02-2007, 09:05 AM   #9
jabroka
jabroka's Avatar
Motorcycle: 1993 GSXR 750 - 1992 DR 800 BIG
id check the small diode on the left side of the bike just below the seat too.. where the neutral and side stand connectors are.. happened something similar to me once, check that its clean and not covered in a greenish gunk like mine was..
jabroka is offline   Reply With Quote Quick reply to this message
Old 07-08-2008, 02:42 AM   #10
partsguy1
does anyone have a used ignition box for sale? I searched ebay but could not find anything for my 94. What other years could I use if any?
Old 07-09-2008, 07:43 AM   #11
Knight2211
Unstable SuperMod
Knight2211's Avatar
Motorcycle: 92 GSX-R 750R Liquid
http://cgi.ebay.com/ebaymotors/Parts...3286.m20.l1116
Knight2211 is offline   Reply With Quote Quick reply to this message
Old 07-09-2008, 10:00 AM   #12
fireforeffect49
fireforeffect49's Avatar
Motorcycle: '98 GSX-R1117, '92 FXSTC
Intermittantly means its electric and like Dave said, start w/ routine cleaning of all the connector plugs w/ spray electrical connector cleaner (avail at any autoparts store). If it's the ECU, it'll do it all the time. Suggestion of the kickstand switch makes sense, check the spring on it to make sure it isn't sprung. If it is and the kickstand is able ot bounce up and down at speed, the switch will open and close momentarily and shut the motor down, and then allow it to restart from compression as the switch closes again when teh stand comes back up the full upright position. That makes more sense than anything. If you've got a stand (or have someone help hold the bike upright) put the kickstand up and then press down on it w/ a single finger. If it moves w/out much effort, the spring is shot and needs to be replaced. Not something we ever give much thought to, but given that the kickstand switch controls the juice to the coils, it's something that has to be routinely checked.
1998 GSX-R1117: J&E 1117|FCR39|Yosh +4|Busa swingarm/shock/rear wheel|RaceTech 1.0Kg springs|530/16/43|D&D|750 W/C rearsets/shifter|K2 1K tail mod|working TLR fairings & Busa fender
1992 HD FXSTC: Edelbrock Performer heads|Wiseco 10.5:1 pistons|Mikuni HSR42|Andrews EV27|Dyna S|BDL 3"|120/70/21|180/55/18|530/23/48|18" apes|Thunderheart boards
fireforeffect49 is offline   Reply With Quote Quick reply to this message
Old 07-11-2008, 05:52 AM   #13
partsguy1
I checked the side stand and it is tight. I've cleaned the connectors on the right side of the bike(the yellow and black connectors) both had some corrosion. Still have same issue. When the tach bounces back and forth, I can pull the clutch in and rev the engine or I can down shift and open the throttle up and everything is fine. It's just when your cruising around 5500 RPM it happens. I also cleaned the carbs thinking it may be a jet. Nope, it wasn't.Thanks for all of your help.
Old 07-11-2008, 11:42 AM   #14
fireforeffect49
Carbs won't contribute to the tach dropping to zero. Electricity cutting out will. Did you check the little switch on the kickstand? It's a momentary switch. When the kickstand is up (or neutral when the stand is down), the circuit is closed, allowing power to the coils. When the kickstand is down and the bike is physically in any gear other than neutral, the switch opens the power circuit to the coils and cuts off electricity.
Old 07-12-2008, 01:06 AM   #15
redstain
redstain's Avatar
Motorcycle: 1993 GSXR 1100
my SV did that in the middle of my experimental jetting days. had 162 mains, and it ran great until i'd let it sit @ about 6500 rpm's for about a minute. the motor would briefly shut down, kill the tach, and backfire as it jumped back into action. it was running way too rich in that range, and it seemed to foul the plugs for a second. dropped it back to the 157.5's and never had the problem again, until i rode to south dakota and was in the higher elevations, where it would foul again. i rejetted my bike on I-90 miles from anywhere, and i mean bumfuck wyoming.
sounds like the same problem.
redstain is offline   Reply With Quote Quick reply to this message
Old 07-13-2008, 02:53 PM   #16
Bobbychet
Superbike Racer
Bobbychet's Avatar
Motorcycle: Sold my Soul
There's one on e-bay
same guy that that's selling the other 1100 stuff that crzoomb found
Also Warren (Sradiator has one up for sale.Check your PM's
Bobbychet
Bobbychet is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 08:43 AM   #17
SlyFox69
Thanks
Had sort of a similar issue, and it was caused by the kill-switch in the kick stand. The spring had gotten loose and would allow the stand to come down slightly when I would hit a bump while accelerating, triggering the engine kill...
Hope this helps.
Sly
SlyFox69 is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 01:45 PM   #18
RoamingBison
Fortunae Nihil
RoamingBison's Avatar
Motorcycle: 1994 GSXR-1100W(R)
Hope this helps.
Sly
Ummm, Welcome to the Forum!
That is a four-year-old thread...
RoamingBison is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
