06 1000 forks swap to an 01 1000 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 03-21-2007, 12:08 AM   #1
chad468
chad468's Avatar
Motorcycle: Custom 2001 gsxr 1000, 2000 Custom TL1000R
Did Searches but didn't find any specifics:
What all is needed to swap an 06 GSXR 1000 front forks and brake setup onto a 01 GSXR 1000. I've got an 06 set on its way. Details if you have them please.
Thanks
chad468 is offline   Reply With Quote Quick reply to this message
Old 03-21-2007, 12:17 AM   #2
Re: 06 1000 forks swap to an 01 1000
Forks and calipers for sure
Clamps and clip-ons possibly because the upper diameters are changed slightly on the 06's I believe.
May need a spacer for the front wheel depending on the clamps you need to run.
The front rotors on the 01 are 320mm, the rotors on the 06 are 310mm so you will need some 5mm caliper spacers.
SPL170db is offline   Reply With Quote Quick reply to this message
Old 03-21-2007, 03:10 PM   #3
jimmy g
jimmy g's Avatar
Motorcycle: jimmy g
i have 05 forks on my 01 you need forks calipers wheel spacers & axle from 05/06 & 5mm spacers unless you use 05/06 rotors then the stock spacers are fine.the clip ons & tripples off your 01 will fit no problem.i would suggest a master cylinder from a 05/ 06 also unless you can afford a brembo.
jimmy g is offline   Reply With Quote Quick reply to this message
Old 03-22-2007, 09:24 PM   #4
chad468
chad468's Avatar
what is the difference in the axles and spacers? Is it the diameter of the lower attach point of the 05/06 forks that differs from the 01 forks? It must not be the wheel bearings since there is no mention of needing an 05/06 wheel.
Thanks
Old 03-23-2007, 06:54 AM   #5
jimmy g
jimmy g's Avatar
Motorcycle: jimmy g
axle diameter is the same the bottom of the forks & spacers are set up entirely different 01 thru 06 wheels will work maybe even 07 but i dont know for sure.
Old 03-26-2007, 07:46 PM   #6
chad468
chad468's Avatar
Nice, just won an 05 axle and spacer on ebay for $16 shipped!! Almost ready to rock n roll!
Old 03-26-2007, 11:50 PM   #7
jimmy g
jimmy g's Avatar
Motorcycle: jimmy g
you will probably be real happy with it i know i am it really shines on the track.i get a lot less brake fade when pushing hard then i did with the old six pots.
Old 03-27-2007, 09:46 PM   #8
chad468
chad468's Avatar
That's what I'm hoping for, thanks for the info
Old 04-28-2007, 06:29 PM   #9
chad468
chad468's Avatar
done it! i do really like it. now i gotta dial the front suspension in. Anyone have good settings (preload, rebound and comp.) to start with for the 05-06 forks on the 01 1000? I hate messing with suspension settings!!
Old 04-28-2007, 07:56 PM   #10
Turn the rebound in - 1 or 2 from full stiff. Comp about 10-11 out from full stiff. Preload to whatever your weight is.
Old 08-13-2007, 10:31 AM   #11
CoZmO
CoZmO's Avatar
Motorcycle: 2001 GSX-R 1000
I am looking to do this swap myself, any helpfull hints or feedback from those who have had it a while?
CoZmO is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 06:59 PM   #12
CoZmO
CoZmO's Avatar
I just recieved my 06 forks today, just have to make the caliper spacers and figure out the spacing for the rear shock, and should i get some caliper bolts that are longer to compensate for the spacers??
Old 08-21-2007, 08:11 PM   #13
boostenlebaron
Motorcycle: 01 gsxr 750 mongrel, 2010 r1, rd350, sportster
stock bolts are long enough for the spacers but if its gonna be long term with the spacers probably better to source longer ones.
boostenlebaron is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 10:28 PM   #14
LJSmithK21000
LJSmithK21000's Avatar
Motorcycle: 2002 GSXR 1000
are there differences in forks (spring rate or valving) from 600 to 750 to 1000 or in the braking systems?
LJSmithK21000 is offline   Reply With Quote Quick reply to this message
Old 08-21-2007, 11:21 PM   #15
CoZmO
CoZmO's Avatar
I have been told alot of different things on the rear shock adjustment, but the most consistant is that i will need a couple to three washers stacked between the shock and the top mounting bracket to drop the rear height some because the 06 forks are shorter. I measured and they are bout 3/16 shorter. For the most part I will be hitting twisties and back country roads so i am looking for the most user friendly setup.
Old 08-22-2007, 07:38 PM   #16
boostenlebaron
their are differences between all model forks. springs being the most noticable but all will work. as far as brakes go i think only the pads are different, im not sure about the calipers but i know they are interchangable. as far as the rear goes you want to raise it abit. 5mm is usually the standard, just get real spacers or go to home depot and get some large washers and stack them. as far as the front is concerned you generally wanted a little of the forks going through the triples anyway (again 5mm is about standard starting point). start with the front flush and try it but i think youll end up at 5mm showing anyway aling with the 5mm out back. makes the bike much more responsive and easier to turn but its all up to the rider how they like their bikes. either case the bike will be fine to ride leaving the back alone and just have the front flush but i think youll want to maxamize the suspension.
boost makes everything better
01 gsxr 750 -sebimoto kevlar bodywork, pvm rims, 06 1000 front end, brembo master, ti rear rotor, braided brake lines, 1000 ti header, wileyco slipon, pair, tre, secondaries removed, many things drilled, 520 conversion, ceramic bearings, ohlins this and that, penske triple clicker rear, everything woodcraft sells, pc3.
Old 08-22-2007, 10:20 PM   #17
triplestack3
Official Sponsor
triplestack3's Avatar
Motorcycle: 2006 Mladin Motorsports Superstock GSX-R1000
pads are the same 04 and up 6/7/1
K3 1000 has a different pad setup though
triplestack3 is offline   Reply With Quote Quick reply to this message
Old 08-23-2007, 09:23 PM   #18
CoZmO
CoZmO's Avatar
thanks for the input guys!!
Old 08-29-2007, 12:49 AM   #19
CoZmO
CoZmO's Avatar
so I finally got everything back together and I love the brakes!
only one problem, my brake lever is hitting my farring stay when at full left turn?!?
its like the master cylinder is too long
anyone else have this problem?
Old 08-29-2007, 07:46 PM   #20
boostenlebaron
yup, its gonna happen. you can grind the lever or the stay. or you can leave it. i use an r1 master and ground off the adjuster lever and it works fine. much better that the stock one too.
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
