Potentially dumb question..... Does WD-40 dry out? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 01-23-2007, 11:58 PM   #1
Will Goes Boing
GDC's Martha Stewart
Will Goes Boing's Avatar
Motorcycle: 2008 Yamaha WR250x
As the title stated.... I'm wondering if WD-40 dries out over time or does it act as a lubricant and stays "slippery".
Reason I'm asking is because I got a techmount stem mount for my gps/camera and I was suppose to push the "probe" with the rubber O rings into the stem hole. It recommended using a little water but it was damn near impossible to get even 1/4" in.
So I got pissed off and used WD-40.... even with that I had to use 100% elbow and shoulder grease to get that thing in. It's in now but the problem is if I firmly try to move it... it will move a little to the left or right.
So I'm wondering if the WD40 will dry out so it'll fit in there nice and tight... or if it will act as a "lubricant".
Shut up or I'll punch you in your ovaries
I am the ovary punching extraordinaire.
Originally Posted by ESanders2
Will Goes Bowling, if you're out there, I know you've been looking for a fix to this.
Will Goes Boing is offline   Reply With Quote Quick reply to this message
Old 01-24-2007, 12:03 AM   #2
Booenson
eh'hole
Booenson's Avatar
Re: Potentially dumb question..... Does WD-40 dry out?
Imo WD40 is a penetrant, not a lubricant, and because its not designed to continually lubricate something, it'll dry out sooner or later.
Booenson is offline   Reply With Quote Quick reply to this message
Old 01-24-2007, 12:35 AM   #3
cnlevo
cnlevo's Avatar
Motorcycle: K6 GSX-R 750
it will dry out....no worries. not as fast as water, but it will. give it a day or two.
cnlevo is offline   Reply With Quote Quick reply to this message
Old 01-24-2007, 12:47 AM   #4
Will Goes Boing
Alright
Old 01-24-2007, 01:12 AM   #5
HOLLYWOOD33
HOLLYWOOD33's Avatar
Motorcycle: 2006 GSXR 1000
Use some good old "spit" next time.........
HOLLYWOOD33 is offline   Reply With Quote Quick reply to this message
Old 01-24-2007, 02:09 AM   #6
Will Goes Boing
I'll be sure to keep that in mind dude
Old 01-24-2007, 08:21 AM   #7
Maybe a dry graphite lube would work good for that. Similar to what is used in the ignition tumbler, doesn't attract dirt.
SPL170db is online now   Reply With Quote Quick reply to this message
Old 01-24-2007, 08:36 AM   #8
down_on_monday
Superbike Racer
down_on_monday's Avatar
Motorcycle: 750 something
It's a little trick I learned to use on our radios when I was in the Army....for connectors that are made of rubber. Something about your spit makes it work? Sounds weird, I know.
down_on_monday is offline   Reply With Quote Quick reply to this message
Old 01-24-2007, 10:12 AM   #9
Will Goes Boing
I was wondering if they made something like that.....
Acts as a lube initially and dries out as an adhesive. But I probably should leave it the way it is because it's on there pretty snug. And if I use that I probably wouldn't be able to remove it anymore if I ever wanted to.
Old 01-24-2007, 10:13 AM   #10
Will Goes Boing
I know spit does work as a lubricant for dry pussies
Old 01-24-2007, 10:17 AM   #11
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600 & Million Edition 1000
Clean it all off and use window cleaner to install it.... just like grips.
TheGeek is online now   Reply With Quote Quick reply to this message
Old 01-24-2007, 11:57 AM   #12
wtchtwr
Motorcycle: wtchtwr
Come on kids - Hairspray - Its what I use on my grips ever since the I could ride a bicycle.
wtchtwr is offline   Reply With Quote Quick reply to this message
