What rpm do you change gears at? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 11-30-2006, 02:25 AM   #1
Texas Stalker
under normal cruising acceleration?
Texas Stalker is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 03:13 AM   #2
xt falcon
Re: What rpm do you change gears at?
i normally change around 7k to 10k
xt falcon is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 03:42 AM   #3
hokl
Motorcycle: 2006 750gsxr
4-6k on my 600 srad
hokl is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 04:16 AM   #4
crashgordon73
crashgordon73's Avatar
Motorcycle: 06 GSXR 1000
5-7k on my 1000 in town just cruising. 14k if I'm really on it
crashgordon73 is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 09:49 AM   #5
Baldy217
Baldy217's Avatar
Motorcycle: 2000 GSXR 750
6k - 7k
Baldy217 is offline   Reply With Quote Quick reply to this message
Old 11-30-2006, 10:34 AM   #6
mikeb12
Motorcycle: 03 6
shift when warranted. if you are cruising around, you can shift at 5-6 and the bike is not going to accel hard, but it will not bog down either. if you are getting on the freeway, run up a few more thousand to keep the bike in more of the meat of its powerband. if on the track, redline or near redline. as you get to the higher gears, it is better to shift a bit sooner. maybe 1-2k below redline for 4-5 and 5-6. this will keep the bike off the overrev.
mikeb12 is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 12:21 PM   #7
gsx-r-guy
gsx-r-guy's Avatar
5-6k
gsx-r-guy is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 12:30 PM   #8
dJt3xtbook
Superbike Racer
dJt3xtbook's Avatar
Motorcycle: 2010 Triumph Street Triple R
have you tried rev-matching? that should be the optimum RPM to shift gears. while travelling in first gear at low rpms, accelerate while holding your foot (slight pressure) against the shift lever towards 2nd gear (up or down depending). without the use of the clutch, you should slip into the next gears at the optimum revs. for regular street riding, i don't use the clutch at all for upshifts.
dJt3xtbook is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 01:20 PM   #9
Texas Stalker
You dont even have to use the clutch?! You just press up and switch?
Old 12-01-2006, 01:24 PM   #10
DavidK6
Motorcycle: 06 GSX-R1000
5-6k
DavidK6 is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 01:55 PM   #11
Mister Tee
Motorcycle: 05 GSXR 750
I do the same thing. I usually do partial-clutch downshifts, though. I'm shifting at higher RPM's on my girl's 600 than I do on my own 750.
Mister Tee is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 05:41 PM   #12
Texas Stalker
Ill have to try that next time I ride!
Old 12-02-2006, 10:45 PM   #13
MarcJ241
6k-7k
MarcJ241 is offline   Reply With Quote Quick reply to this message
Old 12-02-2006, 11:04 PM   #14
Booenson
eh'hole
Booenson's Avatar
Normal cruising around town, 5-6k, moving at a brisk pace, 7-8k, hauling ass at 13k.
Booenson is offline   Reply With Quote Quick reply to this message
Old 12-04-2006, 04:33 PM   #15
Ianarian
Motorcycle: 03' GSXR 750 - 04' GSXR 1000
I follow the recommendations in the owners manual. Dosnt everyone?
1-2 12mph
2-3 25mph
3-4 35mph....or something.
haha ...right....
answer -- just feel it!
Ianarian is offline   Reply With Quote Quick reply to this message
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
