How to remove stripped bolt : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-10-2012, 11:07 PM   #1
jdubgixxer
jdubgixxer's Avatar
One of the bolts on my wind screen is rounded out on top it's the windscreen bolt that goes through the part connected to the gauge cluster too
jdubgixxer is offline   Reply With Quote
Old 12-11-2012, 12:04 AM   #2
2007gsxr600
2007gsxr600's Avatar
Motorcycle: L1 750
Re: How to remove stripped bolt
take a picture of said bolt.... and they are made of plastic right??.... heat up a philips screw driver until hot enough to partially melt the top of said screw. then carefully press the screw driver into top of bolt to make philips pattern.... wait for plastic to cool off and remove the screw. replace said screw with new one.... try it out... just thought of this but I'm a bit inebriated.... lol good luck
2007gsxr600 is offline   Reply With Quote
Old 12-11-2012, 06:23 AM   #3
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
Liquid genius.
TeflonTrout is online now   Reply With Quote
Old 12-12-2012, 12:01 AM   #4
jdubgixxer
jdubgixxer's Avatar
It's a metal screw
Old 12-12-2012, 12:19 AM   #5
2007gsxr600
Motorcycle: L1 750
post a pic of the bolt pls....
Old 12-12-2012, 01:08 AM   #6
youngblood750
Motorcycle: gsxr750y 2000
I've done pulling stripped bolts twice.. that's something that I really want to avoid in the future. well, experienced and skillful person can do this smoothly. but I wasn't.
anyway I succeeded it.
I heard there are a few different ways to do this. welding was one way.
I used bolt extraction kit.
procedure will be like this.
http://youtu.be/NtIvXYdVvBM
youngblood750 is online now   Reply With Quote
Old 12-12-2012, 01:11 AM   #7
jdubgixxer
jdubgixxer's Avatar
Old 12-12-2012, 02:47 AM   #8
Slaki
Slaki's Avatar
Motorcycle: 2007 GSXR 1000
You sure thats a metal screw?
Looks like the standars ones, they are plastic...
If its not, you will have to use a drill bit and drill the head off or use easy outs. If you drill, you have to be super carefull not to touch the fairing...
Slaki is offline   Reply With Quote
Old 12-12-2012, 12:52 PM   #9
MacBayne
anyone else smell poop?
MacBayne's Avatar
that looks OE to me. you can buy this tool: http://www.sears.com/craftsman-3-pc-...p-00952154000P
if you don't want to buy that tool, you could take a set of pliers to the bottom, twist it out, then cut the bottom off once the damaged threads make it to the well nut.
MacBayne is online now   Reply With Quote
Old 12-12-2012, 11:46 PM   #10
2007gsxr600
Motorcycle: L1 750
thats a plastic screw man..... 12's
Old 12-12-2012, 11:48 PM   #11
2007gsxr600
Motorcycle: L1 750
you would use that on a plastic screw???
Old 12-13-2012, 12:00 AM   #12
MacBayne
MacBayne's Avatar
hmmm... considering that the head is stripped i would be replacing it anyway, so why the fuck would i not?
Old 12-13-2012, 12:11 AM   #13
Goobersbro
Goobersbro's Avatar
Motorcycle: 07 GSX-R 600
Take a grinder cut a slit use a flat head....
Old 12-13-2012, 01:29 AM   #14
Skilla
Skilla's Avatar
Motorcycle: GSXR 750 K7
+1
had the same problem when replacing my screen, I just used my little pneumatic porter to grind a slot
worked like a charm,
Skilla is offline   Reply With Quote
Old 12-13-2012, 01:43 AM   #15
2007gsxr600
Motorcycle: L1 750
Hmmm maybe considering that its plastic would make me not use it but hey not my bike..... Fuck up your own shit....
Old 12-13-2012, 08:44 AM   #16
Zippysport
It's a plastic screw, fastening plastic items together. Why shouldn't it be plastic? They work fine for their purpose.
Zippysport is offline   Reply With Quote
Old 12-13-2012, 04:32 PM   #17
MacBayne
MacBayne's Avatar
my shit is not fucked, good sir.
Old 12-13-2012, 07:25 PM   #18
2007gsxr600
Motorcycle: L1 750
Old 12-18-2012, 08:21 AM   #19
youngblood750
I'm sharing my experience..
tool that I bought for this job..
stripped head... (actually this is my moped..)
you need to drill it first.. but I forgot to take a picture.. well I couldn't..
anyway I pulled that out.
tiny bolt with broken head... it was really tiny one...
made a hole with drill... I couldn't take a picture cuz both of my hands was busy drilling..
rotating counter-clock wise..
it came out...
personally, I really hate this job.. it's really PITA..
So I learnt a lesson that I always should be really careful with bolts..
hope this will be resourceful to somebody..
Old 12-18-2012, 09:00 AM   #20
Cazperz
Cazperz's Avatar
Motorcycle: 2009 gsxr1000, 2006 gsxr750 track bike
Only legit response for a plastic screw. Dont even need a grinder could use a pocket knife... or drill it out with a smaller drill. You don't need to go by some fancy kit to fix this prob.
Sent from my SPH-L710 using Motorcycle.com Free App
Cazperz is online now   Reply With Quote
