Help!! Bike wont start just clicks : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-12-2012, 12:58 AM   #1
dotun
hey i know this topic has been covered before but mine is a bit different. i think. sorry i dont mean to upset anyone im just ignorant to the way bikes work.
the other day i started my gsxr 750 srad twice without pullin the clutch, it was in nuetral. it was a bit chilly in the garage. it struggle to come one and idled a bit high the first time, then the third time it just made a wierd wiring niose when i hit the start then it clicks. then it went from that to just clicking sound comming from the rear area of the bike were the battery is located.
is the battery dead
is there a bigger issue i should be alot more concerned about
what should i do/ or what can i do to get it started
dotun is offline   Reply With Quote
Old 12-12-2012, 01:11 AM   #2
Re: Help!! Bike wont start just clicks
Could be starter solenoid, or fuse.
The boys will chime in.........Could even be the clutch switch being dodgy, as it shouldn't start with the clutch not depressed.
Old 12-12-2012, 01:23 AM   #3
dotun
haha i hope they do. if it is the starter soleniod, how hard would it be to replace?
and also i thought they were alright to start without clutch just as long as it was in neutral. i guess i was wrong.
Old 12-12-2012, 01:37 AM   #4
Check fuses first.........main one is under the seat.
The guys are probably sleeping right now....
Old 12-12-2012, 01:56 AM   #5
dotun
alright i will do that when i get back. if the fuses r alright and dandy then is it the soleniod. deng i hope seems like a pain to fix
Old 12-12-2012, 02:31 AM   #6
What year 750. Could it be flooded engine?
dj_smurph is online now   Reply With Quote
Old 12-12-2012, 03:33 AM   #7
dotun
Its a 99
Old 12-12-2012, 03:54 AM   #8
Roeland.Vlok
Motorcycle: GSXR 750 k6
Check the fuses and the clutch switch. Also measure the battery voltage. It should be good enough to crank the motor around 11.5v and more. If the battery is too "flat" the solenoid/relay that engages the starter circuit wil "bounce" and make the clicking sound... Let us know what you find!
Roeland.Vlok is offline   Reply With Quote
Old 12-12-2012, 04:11 AM   #9
dotun
alright will do!!!! you guys r super helpful, thanks a ton!!!
Old 12-12-2012, 04:55 AM   #10
Adsuzukiboy34
Adsuzukiboy34's Avatar
Motorcycle: 1996 Gixxer 750 + K4 1000
Charge the battery, or get a new one.
Cheers, Ad
Adsuzukiboy34 is offline   Reply With Quote
Old 12-12-2012, 05:35 AM   #11
kizza
kizza's Avatar
Motorcycle: 2000 GSXR 600
sounds like you're batterys flat dude, the clicking will be the solenoid trying to flick the starter motor over but as there isnt enough juice it wont. as for the clutch id take the connectors off the switch and give them a good clean, im pretty sure you shouldnt be able to start it without pulling the clutch in lol
kizza is offline   Reply With Quote
