Check Stays on display 1999 GSXR : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-11-2012, 04:24 AM   #1
pf9660
Hi
Hope someone can help & shed light on a problem I have. My bikes starts on the button & rides faultlessly but my clocks constanty displays the word CHEC & never displays the temp. I read that if i put a wire on the 2 conectors to the fault reading plug under the rear seat this should give me my fault code.
Tried this & it still just displays the word CHEC & does not display any codes. I do not have the red warning light come on either only when I first turn the key on which is normal. Please help!
Thanks
pf9660 is offline   Reply With Quote
Old 12-11-2012, 06:03 AM   #2
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
Re: Check Stays on display 1999 GSXR
Check the bonehead mistake first (the one I could see myself making): Did you bridge the two wires that enter the plug, and didn't accidentally put the wire in one of the empty slots? I don't want to be insulting, but I can see myself doing that- it's the simple things that get me the most often.
TeflonTrout is online now   Reply With Quote
Old 12-11-2012, 06:30 AM   #3
oshweeken
Yaah I know!
oshweeken's Avatar
Motorcycle: 1999 GSXR 750, 2002 CRF450R, 1974 CZ250, 1996 Yamaha Wavebalster
_+1
oshweeken is offline   Reply With Quote
Old 12-11-2012, 07:37 AM   #4
pf9660
lol yeah I did bridge the 2 wires & not an empty socket but nothing happened when I did this.
Old 12-11-2012, 08:34 AM   #5
TeflonTrout
Ass Packer
My knowledge=exhausted
Old 12-11-2012, 08:52 AM   #6
Do a detailed search on here. Been a lot recently with this maybe that will shed some light
Old 12-11-2012, 08:56 AM   #7
TeflonTrout
Ass Packer
HAHA! Shed some "light"! I don't care if it was unintentional, I love me a bad pun.
Old 12-11-2012, 04:32 PM   #8
GSXR-Freak
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
I assume that this is a 750 then?
If so, your check on the dash points to a sensor or safely check that did not pass.
with the key turned off, jump the wires then turn on the key, it still says check?
GSXR-Freak is offline   Reply With Quote
Old 12-12-2012, 01:52 AM   #9
pf9660
I guessed it was down to a sensor & tried jumping wires to get fault code but these do not get displayed just the word chec stays on. Guess going to have to book it into a main dealer to get my fault code ouch
Old 12-12-2012, 02:29 AM   #10
Couldn't be a dodgy display on the clocks?
Old 12-12-2012, 05:09 AM   #11
scooby601
scooby601's Avatar
Motorcycle: Srad 750 + SRAD 600
Mine did that when the fuel pump was disconnected (apart from the running part of your 1st post!), I have a feeling that doesn't throw a fault code, but when jumped would come back as 00.
scooby601 is offline   Reply With Quote
Old 12-12-2012, 06:38 AM   #12
pf9660
Cant be my fuel pump as it buzzes when I turn the ignition on. Also when I jump the wires on fault box it still wont remove the word Chec to display any fault codes or wont even state 00 ect
