How do you test a stator and rectifier on a 2007 gsxr 600 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-10-2012, 12:42 PM   #1
Zachdani337
Motorcycle: 2007 GSXR 600
Getting closer to my charging problem I have a multimeter I have the tank pried up I AM NOT TECH SAVY AT ALL PLEASE NO CRAZY TERMS LOL anyways I kno ur suppose to use the multi Meter and put it into the statins harness thing but what readings are good/bad then how do you test the rectifier again I kno nothing about this stuff so pictures are amazing if u could
Zachdani337 is offline   Reply With Quote
Old 12-10-2012, 12:51 PM   #2
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
First thing you need to do is download the service manual. It tells you how to do it step by step.
Sent from my mind
Old 12-10-2012, 12:59 PM   #3
yaksha79
yaksha79's Avatar
Motorcycle: 09 GSXR 750 Black/Blue, cat delete, set valve and pair valve delete, moto gp shift, flashed ECU, R6 throttle tube, K&N, Underbike Yoshi r77, 520 conversion -2in front, HID, Billet levers, braided lines.
Re: How do you test a stator and rectifier on a 2007 gsxr 600
Sent from my mind
And has illustrations (pictures since you don't like crazy terms) lol
yaksha79 is offline   Reply With Quote
Old 12-10-2012, 01:47 PM   #4
john kinzell
Motorcycle: gsxr 1000
this is quite simple:
Make sure the battery is in good condition, fully charged. Set the meter on DC volts in the range of 10-20v, start engine and rev to ~4000rpm, volts should be approx 14+.
If this fails then:
Remove and check the pin connector between the alternator and r/r for any melted/over heated connections, if these are good..
set the meter on AC volts (50-100v), start engine and check volts between 1-2, 1-3,2-3 wires an about 4000 rpm, ya should get about 50-60v on all 3 readings.
if any are low the problem is with the stator, if all 3 readings are good the problem is with the r/r. doing a test on the r/r is a waste of time.
Also when/if replacing the stator its a good idea to hard wire the alternator to the r/r, eliminating a common problem of corrosion with the pin connectors.
luck
08 KLR 650
07/1k 30000 kms
no one has ever bean stoned to death by an atheist..
I can identify UFO's..
john kinzell is offline   Reply With Quote
Old 12-10-2012, 02:11 PM   #5
Ironhead401
Ironhead401's Avatar
Motorcycle: 2004 GSXR 600
Follow this flow chart to test your electric system. http://racetechelectric.com/files/pd...flow_chart.pdf
Old 12-10-2012, 02:32 PM   #6
Zachdani337
What is the pin connectors when u say alternator u mean stator right?
And btw it doesn't get to 14 it doesn't even move is replacing the stator difficult?
Old 12-10-2012, 02:55 PM   #7
Zlow28
16.8@186.1
Zlow28's Avatar
I personally think replacing the stator is easier than testing it. But thats cus im not as good with electronics and cicuits and batteries and stuff like that. However, if you dont test it to see if its working, youre pretty much risking wasting a bunch of time and money. So unless you have a giftcard for a free stator, id check it first IMO.
However, heres the yellow pin you need to locate under the black airbox located under the gas tank.
Old 12-10-2012, 02:57 PM   #8
Zlow28
16.8@186.1
Zlow28's Avatar
And yes, alternator uncorrectly means stator in this case.
Old 12-10-2012, 05:07 PM   #9
Zachdani337
So I put the multimeters inside the prongs? Of that yellow pin? And that yellow pin comes from the bike or from the stator?
Old 12-10-2012, 05:17 PM   #10
Zlow28
16.8@186.1
Zlow28's Avatar
It comes from the stator. Did you download the service manual yet?
Old 12-10-2012, 08:07 PM   #11
Zachdani337
*****UPDATE**********
No its confusing :P lol LIKE I SAID EARLIER your picture help me like crazy good was able to identify it easily the clip was a bitch to get off though
BUT i tested it and 1-2(the two next to each other) gave me 56 volts...check.....1-3(top left and bottom alone prong) gave me 54 volts...check.....but 2-3(top right and bottom one)...gave me 1.3 volts?!?!??!
All of this was done at 4000rpm
Okay so that one didnt work so does that mean the whole stator is fried?
ZLow you have been a great help thanks!!!!!! so whats the next step zlow?
Old 12-10-2012, 09:01 PM   #12
Zlow28
16.8@186.1
Zlow28's Avatar
Ok try this, remove the rectifier completely, and set your multimeter to 20v AC. Find a good ground for the black and the red will go in the stator clips.
Turn your bike on and test all three wires at idle. Then Perform the same test at 4000rpm.
The numbers should jump up. If they remain the same and become really inconsistent, then the stator is bad.
Id highly recomend you write them down so you dont confuse numbers.
Old 12-10-2012, 09:03 PM   #13
john kinzell
Sunny, its time to replace the stator, ya got one phase burnt out.
Take a bucket full of $$ to the local steeler and trade it for a new stator.
Luck
Old 12-11-2012, 04:28 PM   #14
Zachdani337
****UPDATE*****
Problem almost solved!!!!!!!!!!!
Here is the picture of the stator i just pulled out of my gsxr i cant be more happier found out what the problem is it was indeed the stator
On the other hand i still bought a new rectifier just for good measure going to buy my stator tonight
Thanks everyone for the help i will continue to update when i get the stator in the mail thanks!!
Old 12-11-2012, 05:45 PM   #15
Zlow28
16.8@186.1
Zlow28's Avatar
Glad you found the problem!
