Throttle mod hard facts R1 vs R6! (pics) - Page 25 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-17-2012, 12:09 AM   #481
Brian2006
Wears Girly Gear
Re: Throttle mod hard facts R1 vs R6! (pics)
Originally Posted by Zippysport View Post
Get as much slack from every adjuster as you can. I had to grind down the lock nuts to get enough slack at full lock. I have the same combination you do. I have a 2007 750 and the R6 throttle tube. Some people have put both lock nuts on the same side of the adjuster down at the throttle body, but I wanted to be a little more professional and proper about it. Having a throttle that snaps back properly seems to me to be pretty important.
I was getting very frustrated with mine as I almost gave up trying to get any slack from the adjusters. FINALLY, at the very end of the adjustment with both cables backed ALL THE WAY OUT, there was a little bit of slack. I was almost on the verge of putting stock back on.
Another problem I had is I couldn't put my grip all the way at the end of the tube. Since there isn't a second cam for the grip to rest on outside of the housing, the grip would stick.
Brian2006 is offline   Reply With Quote
Old 09-25-2012, 11:24 PM   #482
4BTS12
Motorcycle: 2007 GSXR750
Is this the same throttle tube?
Motion Pro Throttle Tube Yamaha R6S YZF R6S 2006-2009
I want to do this mod but want to make sure its the write tube. Thanks
4BTS12 is offline   Reply With Quote
Old 11-19-2012, 02:59 PM   #483
ErikGSXR
ErikGSXR's Avatar
avoid r6s i think. i just did this and got a 2007 R6 tube and its a noticable difference
ErikGSXR is offline   Reply With Quote
Old 12-10-2012, 10:41 AM   #484
Olkka
Olkka's Avatar
Motorcycle: GSX-R 1000 K7
Received my R6 throttle and gonna do this mod to my GSX-R 1000 K7 next spring. Thanks a lot for this awesome thread!
Olkka is offline   Reply With Quote
Old 01-21-2013, 10:57 PM   #485
j23a45m
great write up i just ordered a R1 tube today for my K7 750
j23a45m is offline   Reply With Quote
Old 01-22-2013, 09:15 PM   #486
nitrous36
Taught Goatsee everything he "knows"
nitrous36's Avatar
Motorcycle: K4 GSXR 600
FWIW I think its worth rementioning that, if you want your new grips to stick well, use CA glue. Most bar grip adhesives dont work well and take hours to dry, and/or can become undone again. I tried first using grip adhesive a few times with no luck, as did others. Just wouldnt bond well, or if it did bond it wasnt long. That was my experience.
So if anyone encounters this problem, then head down to your local hobby shop and get CA glue. Its usually used to bond R/C tires to rims. It bonds strong and dries fast. So you can be out riding and not waiting 6 hours for something to set up.
I could be wrong. Don't quote me on that.
Originally Posted by I Fuck My Mom and Love It View Post
Ban me, that shit makes me fuckin hard!!!
Originally Posted by Ceiling Cat View Post
Prepare to get hard then.
nitrous36 is offline   Reply With Quote
Old 01-28-2013, 07:46 PM   #487
vaser21
would this throttle tube work on my 06 gsxr 1000.. is it the same as the oem part. anyone have any experience?
http://www.ebay.com/itm/Motion-Pro-T...8ccb6e&vxp=mtr
vaser21 is offline   Reply With Quote
Old 01-28-2013, 08:42 PM   #488
MacBayne
anyone else smell poop?
MacBayne's Avatar
"OEM Replacement," so i would vote yes.
MacBayne is online now   Reply With Quote
Old 01-28-2013, 11:03 PM   #489
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
R6S tube is like R1 tube. R6(R) has 40mm...
-JK750- is offline   Reply With Quote
Old 01-29-2013, 12:32 PM   #490
vaser21
thank you very much will go ahead and just order the oem part
Old 02-27-2013, 05:00 PM   #491
j23a45m
did a R1 tube today and wow what a difference
Old 03-21-2013, 10:54 PM   #492
stariondriver
I did a r1 too, thought I did an r6 lol. just took mine back apart and its a 36.5 mm cable pulley .
stariondriver is offline   Reply With Quote
Old 04-02-2013, 07:57 PM   #493
Lindr6
Lindr6's Avatar
Motorcycle: 07 r1, 11 Gsxr 750, 08 Zuma
I did the 06 r6 tube. Thanks to this thread I dremmeld the housing works great. On my 07 r1 I have the motion pro revolver throttle kit. But this feels way better then that one. Thanks
Lindr6 is offline   Reply With Quote
Old 04-03-2013, 12:14 AM   #494
-JK750-
-JK750-'s Avatar
You must be joking? Or your R1 has some weird throttle system compared to a GSXR.
Old 04-15-2013, 04:15 PM   #495
stariondriver
update. r6 tube is in and works great. the housing did not need modified on my k4 gixxer, but the threaded extension did. I cut with a dremel and the slotted it so it came off nicely.
Old 04-16-2013, 02:37 AM   #496
DAKKAD
DAKKAD's Avatar
sticky
DAKKAD is offline   Reply With Quote
Old 05-10-2013, 08:29 AM   #497
Originally Posted by DanielSVT View Post
Did mine last night along with vortex clip-ons and crg levers and OMG... Night and day difference with throttle control. Seriously, I highly advise this. I got mine for like 15 bucks shipped from bikebandit.com
did you have to mod the housing?
I ordered one off ebay from an 07, I was just riding on the freeway the other day and entering I was like jeez this thing could use a shorter throw, no problems taking off from a stop?
Old 05-14-2013, 06:25 AM   #498
Olkka
Olkka's Avatar
Did the R6 tube mod to my K7 GSX-R 1000 with -1/+2 sprockets. What a difference! Just a bit Dremelling needed. Bang for buck mod, highly advised! Thanks!
