Rear wheel won't turn - Page 2 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-08-2012, 11:36 AM   #21
kevin.g
kevin.g's Avatar
Motorcycle: 20th Anniversary 750
I can't find anything about that in the manual all it has is the cable and the release mechanism. It says to pop a cover off the front sprocket cover and adjust the screw that's under it.
kevin.g is online now   Reply With Quote
Old 12-08-2012, 11:43 AM   #22
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
Re: Rear wheel won't turn
That's the 3rd adjustment, newer bikes have what Joe said.
-JK750- is offline   Reply With Quote
Old 12-08-2012, 11:45 AM   #23
kevin.g
kevin.g's Avatar
Ahh. Ok thank you.
Old 12-08-2012, 11:48 AM   #24
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
...Huh.
Kevin, thank you for posting this question. I'd likely have found out the hard way about cold clutches one chilly morning. With my luck, I would have smeared my slick orange paint all over the side of our nice silver minivan.
You very likely have saved me from having to watch as my lovely wife collapses, paralyzed by laughter at my expense, in the front yard. If you find yourself in Kyrgyzstan in the next few weeks, send me a message and I'll buy you a beer.
TeflonTrout is online now   Reply With Quote
Old 12-08-2012, 11:52 AM   #25
kevin.g
kevin.g's Avatar
Hopefully I'll never be in Kyrgyzstan again :P I'll go adjust it a bit later after I wake up fully and see what the deal is
Old 12-08-2012, 12:10 PM   #26
follow the steps on 2-17 in the manual
Most bikes the pressure plate adjuster is on the right inside a plug in the clutch cover. Yours is on the left over the sprocket cover. Same principle though
Old 12-08-2012, 12:16 PM   #27
kevin.g
kevin.g's Avatar
We must be looking at different books. My Haynes has it on 1-20/21
Old 12-08-2012, 02:23 PM   #28
Hanes is garbage, but it may be ok in this instance. I cant see it
http://www.servicemanualsgsxr.com/su...ervice-manual/
Old 12-08-2012, 02:24 PM   #29
The photo bottom right of the first page (near the crease) is of a pressure plate being adjusted FYI.
I assume that manual covers more than one bike
Old 12-08-2012, 02:36 PM   #30
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B (soon!)
I like Haynes over the factory manual. Clearer pix and i like the color coded schematics...
Bagherra is offline   Reply With Quote
Old 12-08-2012, 02:36 PM   #31
kevin.g
kevin.g's Avatar
04-05 600&750 03-08 1000
Its not the best but I've been able to do anything I wanted with it honestly
Old 12-09-2012, 08:50 AM   #32
kevin.g
kevin.g's Avatar
Did the adjustment. Didn't change a thing.
Old 12-09-2012, 12:52 PM   #33
Jd4oor
I Heart Man Sauce
Jd4oor's Avatar
Motorcycle: 2006 GSX-R 1000 2007 GSX-R 600
Did you fix the r/r yet? If so take it for a ride and see if anything's out of the ordinary. If you're really that concerned, pull the plates and inspect both steel and fibers. Check if the basket is scored, proper torque on springs etc. If nothing jumps out at you, soak your fibers in oil overnight before reassembling.
Jd4oor is offline   Reply With Quote
Old 12-09-2012, 02:31 PM   #34
kevin.g
kevin.g's Avatar
Not yet, I'll take it for a ride after I replace the r/r before I go tearing things apart should get the kit this week
