i ran over a chunk of asphalt in the middle of a 60mph curve, it started a violent slapper and when i finally got it handled i was almost running off road. there really is not much you can do but let the bike work it out. Never try to wrestle it straight. when i pulled over, my front wheel was bent.
So just basically the same thing as a slide? Steady throttle light grip?
Speaking of slides, I was out in the rural Salinas, CA area last week... if anyone is familiar with that the roads are covered in dried mud. I went to make a free flowing left turn onto a cross street going maybe 20 mph and the tires just slid right out from under me. I kicked the ground with my left foot mx style and the bike just popped right back up and regained traction. I don't know how the hell it worked but it did.
20th Anniversary GSX-R750
"If you fantasize about being shot from a cannon, we'd recommend riding a literbike as a marginally safer alternative."
Someone correct me if I'm wrong, but I think I read here you should accelerate to take some weight off the front rather than just hold the throttle steady.
In a tank slapper? Ideally yea. Realistically it is unlikely to happen. You just want to avoid death gripping the bars. That will transmit the shake into your body, which will put it into the rear of the bike and it can start to swap ends. Bad deal.
There is a HUGE difference in some head shake (easy to accelerate out of) and a tank slap.
Not much you can do in a tank slapper other than ride it out, be sure your grip is loose, and not panic. Friend had one so bad that it broke the tab off of the triple trees that stops the forks and only lets them turn so far side to side.. It broke off that tab and the handlebar dented the frame, but he was very lucky and didn't wreck.
