» Site Navigation
» Motorcycle Forums
12-05-2012, 05:47 PM
#1
Motorcycle: 87 GSXR750, 88 CBR600, 03 XR400
Repurposing triples
I was kicking the idea around at work today of taking my triples into a machine shop and having them milled out from 41mm to 43mm. Has anyone tried this and has it worked?
12-05-2012, 06:47 PM
#2
Motorcycle: few gsx-r
Re: Repurposing triples
and than?
12-05-2012, 07:24 PM
#3
Easier conversion to 17' wheel. Switch from my stock to the 43mm forks, 20mm axle will be an easier swap, and takes some guess work out (I use the search function, half these threads start an idea and then never say what they did as a solution)
12-05-2012, 07:36 PM
#4
Brofessional Viking Super Moderator
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Bad idea - there isn't too much material as it is, removing a mm all the way around is significant. Change to the newer triples instead?
12-06-2012, 03:25 PM
#5
1th gen came with 200 mm between fork legs
2nd gen with trad 43 mm with 205 mm
not enough material
Linear Mode
