Ring Gap 750 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-01-2012, 09:32 AM   #1
suzy1052
Motorcycle: 02 Busa 00 Gsxr 725
Ring Gap 750
Does anybody know what the ring gap is supposed to be when they are in the bores ? The 96-99 Suzuki manual says 0.50mm is the limit but doesn't give a minimum gap. I measured mine approx 3/4 inch up from the bottom of the bore and I can barely get a .10mm feeler in it.
suzy1052 is offline   Reply With Quote
Old 12-01-2012, 10:18 AM   #2
Re: Ring Gap 750
Free ring gap:
1st ring 6.9mm
2nd ring 8.7mm
Installed :
. 10-.25mm
Installed approx 1inch up the bottom of the bore and squared with a piston crown
Old 12-01-2012, 10:39 AM   #3
suzy1052
Re: Ring Gap 750
Hey thanks ccm but Im talking about the min. closed gap as if they are on the piston while in the cylinders.
Old 12-01-2012, 10:44 AM   #4
Re: Ring Gap 750
And that would be the latter set of specs I listed, rings squared up and installed approx 1inch in cyl (uou like 3/4) std is:
.10-.25mm, wear limit is. 50 mm
Old 12-01-2012, 11:01 AM   #5
suzy1052
Re: Ring Gap 750
OK got it. Thanks.
