Can't open gas tank? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Tech Tips & Tricks
Old 10-27-2010, 06:12 PM   #1
Zleepertt (MD)
Red face Can't open gas tank?
Hey,
Yup, I know it sounds really silly. But I was at a gas station today to fill up, I stick the key in the socket, but the key will only go about half way into the socket.
I tried to turn the key, with a little force, but it would not turn. Has anyone experienced this before? Any response is appreciated.
Thank you,
Dean S.
Zleepertt (MD) is offline   Reply With Quote
Old 10-27-2010, 06:23 PM   #2
The Turk
Track Pimp......who hates njracer and his love for BACON!
The Turk's Avatar
Motorcycle: 2009 Gsx-R 750
Re: Can't open gas tank?
Originally Posted by Zleepertt (MD) View Post
Hey,
Thank you,
Dean S.
While you turn the key did you try it the push it down and turn it
Turk
The Turk is offline   Reply With Quote
Old 10-27-2010, 08:51 PM   #3
cpd419
Spunk Gargling Knob Gobbling Squid
cpd419's Avatar
Motorcycle: 08 gsxr 1000 -- 03 Honda Ruckus -- 06 kawasaki Mule-- 05 CRF 100 pit bike
Try a little WD in the hole. Also make sure your key hasnt been bent of twisted, just a little can cause that.
cpd419 is offline   Reply With Quote
Old 10-27-2010, 08:53 PM   #4
Countryboy
WSB Champ
Countryboy's Avatar
Motorcycle: your mama
dont use wd40 that makes the tumblers stick
use graphite and or try blowing it out with some compressed air. probably just a tumbler caught up
Countryboy is offline   Reply With Quote
Old 10-28-2010, 01:52 AM   #5
cpd419
cpd419's Avatar
Yeah I haven't had much experience with motorcycle locks sticking although I can see it being straight up and down and water getting in after being washed and all. I do know we have a fleet of crown vics and have to spray wd in the locks about once a year because the keys wont go all the way in and turn the lock and it always works.
Old 10-28-2010, 07:40 PM   #6
Zleepertt (MD)
Turk
I tried to push it down, but it won't go down. Something is stuck. I forced it a little and I don't want the key to bend.
Old 10-28-2010, 08:43 PM   #7
yvaiwhy
Motorcycle: Gixxer 750 Srad '97 ,Honda NX 125, Kawi Zxr 250 1990, Yamaha Jupiter 135
push the gas cap inwards and try to open it...mine got stuck and i had to almost pry it open but after spraying it with lube 40 (same thing as wd40 i believe) its now workin fine.
yvaiwhy is offline   Reply With Quote
Old 10-29-2010, 01:21 PM   #8
GsxReese
GsxReese's Avatar
Motorcycle: 02 Gixxer 600
Hey,
Thank you,
Dean S.
Shoot some compressed air in there that may blow some dirt/objects out
Dont use WD 40!
GsxReese is offline   Reply With Quote
Old 11-20-2010, 01:29 PM   #9
Tongan
Tongan's Avatar
Motorcycle: 89 7/11
Dont use WD 40!
+1
WD - 40 May make things slip but only for a short time and it attracts Dirt and dust. Cause it will stick to the wd - 40 as it drys
Tongan is offline   Reply With Quote
Old 12-01-2012, 12:27 AM   #10
La Banna Klip
Cool Re: Can't open gas tank?
In my expierance water/moisture/weathering got into the mechanism and probaly Seized it in one piece just like my k5 1K was left outside for a year and ended up bending the key cus it wud only go halfway, i had to pry out switch from tank , i then took off both of the Cross screws after i relized that the lock/unlock Lever that moves was Rusted and conjoined in one piece to the base i new something was wrong cus of all the rust, after remiving those screws i saw the housing with the spring nd it was all jammed cus of the corrosion i them took off the second mechanism flat round cover and yup more corrison and water residue which was alot, after having the 3 pieces i poured a shitload of wd-40 and Brushed everything clean which included grinding all parts with water residue more wd-40 and put all together and Now turns like Butter
All the white in the pic is water residue and rust
La Banna Klip is offline   Reply With Quote
Old 12-01-2012, 01:11 AM   #11
Samantha750
Scandinavian Mod with PMS
Samantha750's Avatar
Strong first post, dig up a year old thread.
Samantha750 is offline   Reply With Quote
Old 12-01-2012, 02:09 AM   #12
Goobersbro
Goobersbro's Avatar
Motorcycle: 07 GSX-R 600
Old 12-01-2012, 02:43 AM   #13
Motionelco
Motionelco's Avatar
Motorcycle: 2011 gsxr750
+1 wd40 also eats up oil ....
Motionelco is offline   Reply With Quote
