ama xro copey srad the build! - Page 7 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-30-2012, 09:17 AM   #121
speedy sie
speedy sie's Avatar
Motorcycle: gsxr k1 1000 184.5 rw bhp ex race bike day time mot project and xro7 project build
Re: ama xro copey srad the build!
ill tack a pic of the other side,they are machine finished both sides
speedy sie is offline   Reply With Quote
Old 11-30-2012, 12:20 PM   #122
Hootguy
Motorcycle: 89gsxr-rk,(2),,86 GSXR LTD,,86 gsxr-750 rd/blk,,85 GSXR 750,, 96 gsxr 750/rf900,,98 gsxr 750,,99yosh 750 superbike..86 RG500 Walter Wolf,,86 RG500 blue/wht,,
yup,,so are mine,,,but they seem like a better finish on the positive side,,,and on the Yosh bikes,,i have always seen them used on the plus 3 side,,,they must use them that way because of the clamps they were using at the time,,
Hootguy is offline   Reply With Quote
Old 11-30-2012, 12:33 PM   #123
cobramadness
Parts Junkie
cobramadness's Avatar
Motorcycle: 07 GSXR 1000
Oh ok, I was thinking you had 40 at the same time, haha
cobramadness is offline   Reply With Quote
Old 11-30-2012, 01:16 PM   #124
BenjaminDG
Those disc rotors remind me of my gsx-r 750w rotors, same pattern and surface (grooves instead of holes).
Do these brake harder then the rotors with holes in them?
I assume becaus of the greater brake surface but dont these also warp easier?
Old 11-30-2012, 02:09 PM   #125
speedy sie
speedy sie's Avatar
if SERT used them in world endurance id say they last longer then the brembo's of the day??
Old 11-30-2012, 04:34 PM   #126
I thought the grooves removed glazing from the pads. Drilled discs cool quicker and are prone to cracking around the holes at the constant high temps track bikes are inflicting on the brakes. This is just my thoughts based on car brakes
Old 12-02-2012, 12:13 PM   #127
kizza
kizza's Avatar
Motorcycle: 2000 GSXR 600
awsome build man cant wait to see the finished thing
kizza is offline   Reply With Quote
Old 12-04-2012, 08:14 PM   #128
HARLEYFERGUSON
Motorcycle: 2007 GSXR 1000 2004 GSXR 1000 trackbike 2001 ZRX 1200 1986 GSXR 1100 1987 Yosh Bonneville project 1986 GSXR 750 LTD 1987 Yosh/Schwantz build KTM 525 motard
Love this thread, quite the attention to detail...by any chance would you happen to know the black finish used on the XRF swing arms? I've seen some I swear were anodized, and others that I thought were painted, possibly with some type of thermo bonded polymer? I have a K7 works arm that had to be stripped to clean up a bit of "abuse" and am now in a quandary as to replicating the finish..perhaps I could give you some work if you have some answers. Cheers. Mike
Last edited by HARLEYFERGUSON; 12-04-2012 at 08:19 PM. Reason: Spelling correction
HARLEYFERGUSON is offline   Reply With Quote
Old 12-04-2012, 10:12 PM   #129
Hootguy
tremclad,,,,but you have to be sure ans shake the can really good,,LOL
Old 12-09-2012, 10:09 AM   #130
speedy sie
speedy sie's Avatar
no have a front wheel 16.5....so all go,go on the front end now.
Old 12-11-2012, 11:36 AM   #131
speedy sie
speedy sie's Avatar
front wheel here, fitted a dream mag unit..
also coming soon..
works xr clip ons very trick all titanium bits and billet ali hinged to allow q/c change
work xr bettie gusrd and titanium bolts
tokico works vented rear disk all titanium bits and carrier,so will have full tokico works set up,may have a lead on a tokico m/c
xro tubes hopfully
the works tokico callipers fitted on ,but need new carriers to get them on right,as i have brembo carriers at the moment.
so the bike will be one more step to compleation
Old 12-15-2012, 05:21 AM   #132
BenjaminDG
Simon
What are those 2 tubes coming out of the valve cover?
Extra crankcase breathers?
Isnt the crankcase ventilation located here?
Why is it located there?
On my gsx-r 1100 engine it is located here?
Would it be better to have an extra crankcase breather closer to the crankshaft like on a srad and newer gen engine?
Old 12-15-2012, 07:23 AM   #133
speedy sie
speedy sie's Avatar
the zx7r had a par rebrether system that comes off the exhaust port,taken off on the race bikes,its there because of emission laws in some countries.
Old 12-15-2012, 08:04 AM   #134
BenjaminDG
Ah those engines were not srad engines?
Would it be better to have an extra breather in a simmelar place like the srad?
Or why did the srad and newer gen engine have their breathers in that place and not ontop of the valve cover like the 1100 engine.
Doenst that remove the gasses more easily?
Old 12-15-2012, 09:08 AM   #135
Motorcycle: 96 GSXR750, 07 CBR1KRR, ZX7/9RR F-USA AMA
It was up on the valve cover on the zx7s ( and most other later models) to route it into the exhaust which allowed the unburned hydrocarbons to complete the burn and reduce emissions.
It is not a crankcase vent, just a pair valve.
Old 12-15-2012, 09:12 AM   #136
speedy sie
speedy sie's Avatar
a lot goes in to crank case presume..but just lately iv been jumped on on every forum when i post any info,so ill keep it to my self...sorry..
yep the two engines are zx7r engines, that have crank case breather on top of rear casings and 2 top "par" air set up, which is a Chris pointed is there for countries with tight emission laws
Old 12-15-2012, 09:20 AM   #137
TT750
Motorcycle: 99 750
much easier to block off too!!
Old 12-15-2012, 09:31 AM   #138
speedy sie
speedy sie's Avatar
yep here is my 7rr kit head with it done
Old 12-15-2012, 10:04 AM   #139
How did you do that? And it's not often I say that to anyone you know.....
Old 12-15-2012, 10:50 AM   #140
BenjaminDG
But would my engine benefit if i made another crankcase breather in a similar position like the srad engine?
Can the breather be a simmple hole with a hose coupling attached to it or do you need something with a labyrint in order to allow the oil not comming out of the coupling?
I would like the blueprint my engine so is it worth the look into the crankcase breathing aswell?
