Smart car Hayabusa - Page 2 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > General Discussion > Anything Goes
Old 11-25-2012, 05:42 PM   #21
SmartZuki
SmartZuki's Avatar
Motorcycle: SmartZuki
Re: Smart car Hayabusa
For oil, I run Motul because I get a bunch of it from them when I do track days at Schwantz School. Phil, you don't have to be in neutral on this setup...when it's in first, I let out the clutch about 1/2 way while pulling this lever under the seat and it falls into reverse...then as it's backing up, just before it stops rolling, I push the lever back in and it falls into first. Once you get the hang of it, it works pretty smooth.
SmartZuki is offline   Reply With Quote
Old 11-28-2012, 08:18 PM   #22
SmartZuki
SmartZuki's Avatar
Just a short video of us going through a few of the gears the other day on a test ride....we'll probably try installing the engine damper as a chain tensioner over the weekend and see if that helps out.
Old 11-28-2012, 08:35 PM   #23
oldfart01
Dope With A Rope
oldfart01's Avatar
Does Florida do emission inspections? In PA you must pass an OBDII test. I was wondering how you get around that.
Old 11-29-2012, 06:43 AM   #24
SmartZuki
SmartZuki's Avatar
No inspections that I know of in FLA
Old 11-29-2012, 11:48 AM   #25
RidersDiscount
Official Platinum Sponsor
RidersDiscount's Avatar
Pretty cool I have to say, a ton of work though!
RidersDiscount is offline   Reply With Quote
