Srad Cylinder Block : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-25-2012, 09:00 PM   #1
suzy1052
Motorcycle: 02 Busa 00 Gsxr 725
Srad Cylinder Block
I just bought a cylinder block that was described as belonging to the 96-99 750 Srad. It is a closed deck design. Since I havent got around to taking off the old one I have nothing to compare it to. Are some of these blocks closed ?
suzy1052 is offline   Reply With Quote
Old 11-25-2012, 09:16 PM   #2
Re: Srad Cylinder Block
Put up a picture for me.
Old 11-25-2012, 09:26 PM   #3
suzy1052
Thanks for the quick reply...if it is legit does it take a different head gasket ? I see you are in Lawton. Me and a buddy got drunk one night and left the Nco club on our bikes and ended up on the runway at Ft. Sill lol !
Old 11-25-2012, 10:17 PM   #4
It's legit, and the head gasket gets complicated. Originally, in 96, 750 had a 3 ply head gasket, then the found out that the rods were stretching and ptv clearance was an issue, so the solution was a cheap power robbing fix, a 4 ply head gasket. Your answer really lies in what you are trying to do, and your engine building savvy. Tell me more.
Yeah.... L-town sucks.
Old 11-25-2012, 10:37 PM   #5
suzy1052
My son decided he wants more power after I let him ride my R1 and now Busa. His problem is he is in that very poor stage of life called college so a straight 750 swap is out of the question and besides he needs some wrench time (anybody can swap a motor). Thru research on this forum and others it looks like a srad 750 block will fit the 600 cases and to get around the piston pin size issue the 00-03 750 pistons will fit the 600 small ends. The 96-99 and 00-03 750 pistons have the same specs clearance wise with the K pistons having more compression. My thinking is that the 1.5mm shorter 600 stroke should negate any detonation or ptv contact. Im gonna keep the 600 head and carbs for more midrange. That should take care of his ego on the street when he hooks up with his buddies on their newer 600's. And you are right...Im kinda stumped with the head gasket selection. I would welcome any tips or admonitions.
Old 11-26-2012, 06:47 AM   #6
I would buy a four ply and take off one layer, put it together with that. Then check ptv clearance on intake at 15* ATDC and exhaust at 15* BTDC, look for 1 mm clearance, if you don't have that, replace with 4 ply.
Old 11-26-2012, 07:58 AM   #7
suzy1052
Ok thanks for the info. Do you know the thickness of the 3 ply and 4 ply ?
Old 11-26-2012, 08:42 AM   #8
I have both at home, but am away for the week, can measure for you this weekend.
Old 11-26-2012, 01:01 PM   #9
Sleeper_750
Sleeper_750's Avatar
Motorcycle: 1999 750
Sorry the poop deck is closed sir.
btw what is this closed deck about?
Sleeper_750 is offline   Reply With Quote
Old 11-26-2012, 01:04 PM   #10
Open deck has passages cast in open rings around cylinder sleeves
Old 11-26-2012, 01:15 PM   #11
GSXR-Freak
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
I prefer the closed deck. For some reason, I just feel better about it when the motor is spinning at near redline all day long. lol
GSXR-Freak is offline   Reply With Quote
Old 11-26-2012, 01:18 PM   #12
Open deck
