best gsxr 1100w carter protection : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > Water Cooled Gixxers
Old 11-16-2012, 03:14 AM   #1
tnk2k
Hello all,
I crashed my previous engine when i ran into an pedestrian. Now i don't want this to happen again (the carter beeing broke that is ). What is the best way to protect the carter?
Carter slider?
Crash pads?
Thanks.
tnk2k is offline   Reply With Quote
Old 11-17-2012, 09:41 AM   #2
Re: best gsxr 1100w carter protection
WTF is a "carter", and why do you need to protect it?
Old 11-17-2012, 09:46 AM   #3
le skid
Between Ford & Reagan?
le skid is offline   Reply With Quote
Old 11-17-2012, 09:57 AM   #4
Doesn't he have secret service protection already? Maybe we should report this guy to homeland security?
Old 11-17-2012, 10:17 AM   #5
tnk2k
I've attached the part that i'm referring about. This particulair point is very weak with the gsxr. Normally you would have your fairings but in case of an streetfighter it fails first. Oil was pouring out like mad.
I obviously want to protect it from happening again i case of sliding my bike somehow.
Old 11-17-2012, 11:50 AM   #6
BenjaminDG
I did this.
First made a aluminium plate and then attached a nylon block with velcro on it.
Old 11-19-2012, 09:48 AM   #7
Sabba
Sabba's Avatar
Motorcycle: 93 GSXR 750
Originally Posted by BenjaminDG View Post
NIce Ben...I think I've just found a little winter project for myself!
Sabba is offline   Reply With Quote
Old 11-19-2012, 10:54 AM   #8
BenjaminDG
Definitely one of the weak points of the engine.
That parts actually sticks more out the the cyllinder head and the only thing that protects from the pavement is 3mm thick abs plastic.
I took the idea from TJS's gsx-r which futures a similar protection.
Old 11-19-2012, 01:01 PM   #9
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
They should have incorporated a replaceable puck into that design but that would have cost an extra 50 cents at the production end which would have translated in 500.00 at the retail end.
THE SRADIATOR is offline   Reply With Quote
Old 11-19-2012, 01:14 PM   #10
I still want to know what carter has to do with this?
Old 11-19-2012, 01:26 PM   #11
THE SRADIATOR
I'm not going to ask him:
Old 11-20-2012, 06:57 AM   #12
BenjaminDG
Carter is dutch for (engine)casing.
Not the president i think
Old 11-20-2012, 06:59 AM   #13
BenjaminDG
The bottom bolt that hold the aluminium casing protection is special threaded.
The same thread they used for the older mirrors on bikes.
I tought M10x1 or M10x1.25 but i'm not sure anymore.
Old 11-20-2012, 10:26 PM   #14
Sabba
Sabba's Avatar
Good to know, thanks.
What is that bolt for originally, do you know?
Old 11-21-2012, 07:37 AM   #15
BenjaminDG
That bolt is acutally a plug for the oil channel that feeds oil to your crankshaft.
So make sure that bolt isnt to long or you will block off the oil lubrication for the left side of the crankshaft.
Old 11-21-2012, 09:00 AM   #16
tnk2k
I did this.
Very nice Ben. Sorry about the 'carter', yes it's the housing idd.
Old 11-21-2012, 07:29 PM   #17
Sabba
Sabba's Avatar
As I suspected...
Old 11-22-2012, 03:50 AM   #18
tnk2k
I was thinking about this last night but you could aswell just put some sliders in the lower bolt couldn't you?
Old 11-22-2012, 09:44 AM   #19
Sabba
Sabba's Avatar
I think the pressure on the slider would crack the engine casing...
Ben's method is much safer...
