07 750 Speedo only reads half : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-18-2012, 08:43 PM   #1
usmcpi9504
First, I'm not new to sportbikes. Just sold my 03 GSXR1000 in February. And yes, i searched, no answers. And no, this isn't a speedo healer problem...
Today i went to go look at a couple bikes. 1 guy has both an 05 CBR600 and a 07 GSXR750. So i took the GSXR out for a test ride, noticed speedo said I was going a lot slower than it felt like I was going. Figured I had just been away from my 1000 too long.
So then i took the CBR out and went about the same speeds, although the speedo was right and said i was going 50-60mph. So hoped back on the GSXR, sure enough, it wasnt me, it really was the speedo only reading about half of what I was going. For example, at 7k RPM in third, it said I was going 30mph.
Also, the FI light is on, not sure why. Everything stock except levers, 520 chain (stock geared), etc. He thinks it's because it needs an oil change, but as far as i know, there is no sensor/FI light for that.
Any ideas?
usmcpi9504 is offline   Reply With Quote
Old 11-18-2012, 08:57 PM   #2
rp94pj
rp94pj's Avatar
Motorcycle: 2007 GSXR-750
The FI light wouldn't be on because it needs an oil change.
Sent from my Galaxy Nexus using Motorcycle.com Free App
rp94pj is online now   Reply With Quote
Old 11-18-2012, 08:59 PM   #3
Ironhead401
Ironhead401's Avatar
Motorcycle: 2004 GSXR 600
Re: 07 750 Speedo only reads half
Not sure about the Speedo, maybe somethings up with the Speedo sensor. For the FI light it's not because it needs an oil change. Compete bullshit. Have him pull the code and find out what is wrong.
Old 11-18-2012, 09:05 PM   #4
usmcpi9504
yeah, i know its not because it needs an oil change...
When doing the dealer mode jumping, if it has multiple codes, will it just go through all of them on its own or is there something i have to hit to advance to next code?
Old 11-19-2012, 06:36 AM   #5
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
It willl cycle through all the codes automatically and repeat.
Bike might have the final drive ratio changed drastically, or might have a loose speed rotor, or the rotor is damaged. Hard to tell without seeing it.
TheGeek is online now   Reply With Quote
Old 11-19-2012, 07:43 AM   #6
le skid
This is an interesting one. The speedo is a solid state instrument that measures the number of induction pulses from the speed sensor / rotor. IE It either works or it doesn't work. Not sure how it would work but give an incorrect reading.
If it's measuring exactly 1/2 as you say, I'd be curious to pull the front sprocket cover and take a look at the speed sensor rotor. This is just a wild guess but maybe the previous owner ground-off 2 out of 4 of the 'teeth' on the rotor to reduce the miles being recorded on the odometer?
That would explain how it's working but reading 50% of the pulses that should be coming from the speed sensor / rotor at any given speed.
I acknowledge that this is a longshot but it's all I can think of.
this isn't from a gsx-r but it's what I could find with a quick image search. This sits over the front sprocket. See the four 'teeth'? If you ground-off two of them, that would result in what you're reporting.
It would be an easy mod for a sleezebag long distance rider who wants to dishonestly retain more resale value.
le skid is offline   Reply With Quote
Old 11-19-2012, 08:47 AM   #7
TheGeek
TheGeek's Avatar
Ever see a proximity switch (the actual sensor) get flaky and not pickup every pulse? I have. Ever see one of those speed sensor rotors missing an arm? I have. Ever see a loose speed rotor that spins freely on the counter shaft? I have.
Old 11-19-2012, 08:53 AM   #8
Also seen them come loose and hit the sensor giving odd readings
Old 11-19-2012, 09:43 AM   #9
le skid
Then the question is: is it reading sporadic / inconsistent or is it steady at 1/2 speed?
Old 11-19-2012, 11:34 AM   #10
usmcpi9504
yeah, i read about how that front sprocket nut has the 4 teeth used by the speed sensor. I was also thinking that maybe some of the teeth had broken off. The speedo also reads smoothly, just at the pace of a Civic.
