Need help testing charging system : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-16-2012, 03:59 PM   #1
Brian2006
Wears Girly Gear
Recently, my bike would not start in the cold weather and I had to bump start it to get home. The battery would not hold a charge and it would eventually die. At one point, the gear identifier would not change as I shifted. This made me think it was R/R but it was apparent the cluster stopped functioning as the battery was dyeing.
So I go to test the stator. However, I am not absolutely certain I had my multimeter setup right. Can someone help me out here?
Measuring voltage at the battery:
When I rev up the bike to 5000 (warm) the voltage does not change and stays at 12V.
Measuring AC voltage at the the stator wires:
When revved to 5000rpm, this configuration shows 68 volts
Measuring resistance (ohm) from the battery to the stator wire:
I am not completely certain I have the right configuration setup here. However, the next 3 or 4 selections up for ohm does not change. Only the place of the decimal. It always showed 1.
I was fairly certain my stator was bad because it does not appear I have an overvoltage issue but a problem with the battery staying charged. Can someone check over the way I tested the stator and if I did it right? Do I need a new stator? I was surprised to see 68 volts (if I measured right) at the stator. Minimum for my bike is 65 volts I believe.
Brian2006 is offline   Reply With Quote
Old 11-16-2012, 04:28 PM   #2
Knight2211
Unstable SuperMod
Knight2211's Avatar
Re: Need help testing charging system
You need to move the red lead to the Ohm port. 1st one to the left of the negative (black) lead.
Knight2211 is offline   Reply With Quote
Old 11-16-2012, 05:04 PM   #3
Brian2006
Wears Girly Gear
Is the dial in the correct position?
Old 11-16-2012, 06:43 PM   #4
Ironhead401
Ironhead401's Avatar
Motorcycle: 2004 GSXR 600
Follow this flow chart. It tells you what setting for the multi-meter.
http://racetechelectric.com/files/pd...flow_chart.pdf
Ironhead401 is online now   Reply With Quote
Old 11-17-2012, 10:22 AM   #5
Brian2006
Wears Girly Gear
Okay it turns out I have zero resistance at the stator Does this mean my R/R is shot? I checked and there are no melting/burnt wires.
Old 11-18-2012, 08:59 PM   #6
Brian2006
Wears Girly Gear
I was really thinking I would get a little bit more insight on this. Maybe I should post in the general section
Old 11-19-2012, 02:03 AM   #7
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Check your manual. It gives you a chart with all the numbers you should be getting and what settings to use in your multimeter.
